Question about Whirlpool Model WHP1500SL
LTE5243DQ whirlpool washer is leaking from the bottom in the fill up cycle - average problem and cost>
SOURCE: water leaks from bottom
check for cracks and corrosion on the outer tub.thats where the water must be leaking from.good luck.
Posted on Dec 25, 2008
onthejob5130
  • 640 Answers
SOURCE: Whirlpool washer leaks out bottom
three places,,all in one area..the pump,,,the drain hose to the pump (in unit),,or the tub topump hose...one of them is defective..onthejob...if you need instructions on how to get in unit reply ..
Posted on Jan 24, 2009
  • 530 Answers
SOURCE: whirlpool washer leaks
do not remove the top panel. First tip the washer back. NOT ALL THE WAY. just enoough to see under it. you will see a pump. it is attached by 2 hoses. one to the tub and one to the drain. take the 2 clips off with the hoses still attached. tip it downward. Is water leaking oout of it? let me know thanks
Posted on Feb 03, 2009
Maytag317
  • 1136 Answers
SOURCE: My Whirlpool washer leaks when filling. We have located that it leaks from the plastic liner. Therefore leaking water onto floor.
Hi, The plastic liner you are talking about, is it the outer tub? If you could get me a model#, I could look this up for you.
Please let me know if I can help.
Vic
Posted on Jun 01, 2009
SOURCE: Whirlpool Duet Washer Model WFW9200SQ leaks
i was told that my 3 day old washing machine was being overloaded!!! i really did not put much in! if that is the case I don't want it!!!!!
Posted on Jul 08, 2009
Where do you download a manual for whirlpool thin slim
Whirlpool has the manual for the LTE5243DQ on the product site: http://www.whirlpool.com/-%5BLTE5243DQ%5D-1001396/LTE5243DQ/ . The direct link to the Use and Care manual is http://www.whirlpool.com/digitalassets/LTE5243DQ/Use%20and%20Care_EN.pdf . Note: you will need Adobe Reader or a similar program to read the manual.
If you need the installation guide, use the first link above and then click on the Manuals and Literature tab.
I hope this helps.
Dec 15, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Filling up with water after cycle. possibly, slowly leaking and filling drum.
This is usually caused by a water inlet valve leaking by or a pressure switch malfunction. The following link explains how to diagnose the problem yourself and repair:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I've included parts sources (if required) and instructions on how to replace each component. These are very simple and inexpensive repairs that you can easily accomplish yourself.
If the model number is correct, the part number for a replacement valve is 8181694. The pressure switch is 8181695. The average cost of each component is about $35.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
My washer machine Whirlpool Ultimate Care II LSQ9549L is leaking water when I fill the tub with water. I opened cabinet and there is a small white box below the tub that is dripping water. My questions are...
is it filling filling filling and not stopping. or will it fill and stop when it is supposed to. if it's fill fill filling could be a hole in the pressure hose or a faulty pressure switch. but if itt does all the cycles and is leaking you probably have a bad pump tip the unit back a little so you can see under but do not tip all the way you will see the pump. see if it leaking if so replace tha pump.
Jan 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Model WHP1500SL Logo
169 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
