Question about Kenmore Dryers
I have a Kenmore 90 Series (model # 110 79912990) dryer that has a burning smell when it is on. It is about 10 years old. Do I need a new one?
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
  • 99 Answers
SOURCE: Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Posted on Sep 24, 2009
Testimonial: "Thank you for your reply!"
  • 2118 Answers
SOURCE: 9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Posted on Nov 07, 2009
  • 2118 Answers
SOURCE: Kenmore 500 series dryer won't start. Only 2.5 years old.
turn the drum with your hand,if it feels hard to move you could have something stuck in the blower wheel that is below the lint filter and behind the duct that the filter slides into or the belt could be jammed,if it moves try starting it it might start you could have a flat spot on the motor and most likely you'll need to replace it,if it'shumming it's the motor making the sound
Posted on Feb 14, 2010
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
Kenmore 90 Series, 10 years old; Dryer was making funny noise and stopped in the middle of a cycle. There was a burnt smell when it stopped. Cannot turn drum manually either. What are possibilities?
OF COURSE SOMETHING BURNT INSIDE THE SYSTEM. YOUR MOTOR MIGHT BE BURNT. 90 SERIES, YOU MUST HAVE THE LINT FILTER ON TOP CORRECT? TAKE FILTER OUT, UNSCREWS THE TWO SCREWS, PULL TOP PANEL TOWARDS YOU AND LIFT UP. DISCONNECT LID SWITCH CONNECTOR, UNSCREW TWO SCREWS HOLDING FRONT PANEL ON, REMOVE FRONT PANEL, TAKE DRUM OUT AND CHECK THE UNIT. GOOD LUCK
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Kenmore Dryers
My kenmore 90 series dryier is giving off a smell of burning rubber and is very noisy
Bearings are going out on the motor that turns your dryer. The burning smell is possibly the lubrication leaking into the hot motor.
Dave
Jan 13, 2010 | Dryers
Nov 07, 2009 | Kenmore 63942 Dryer
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore dryer. Heats up intensely
Hi, It's an over heating motor that's cousing the thermal switch to trip, on the motor.
Motor retails for $150.
Labor for putting it in is $90.
It might just be worth replacing it.
Sorry for the bad news :(
Best of luck.
Sep 13, 2009 | Kenmore 64902 Electric Dryer
How do you check the belt?
You will have to lift the top to check the belt and also for access to change it. Burning could also be lint or wires so if it was not the belt make sure you find the reason and repair that carefully.
Eric
Jun 08, 2009 | Kenmore 63942 Dryer
Kenmore 90 Series Dryer start button humms, but that's it.
MOTOR HAS GONE BAD,IF YOU WANT TO TACKLE IT THE MODEL NUMBER IS INSIDE THE DRYER DOOR,YOU MIGHT FIND A GOOD DEAL ON EBAY OR GO TO SEARS.COM UNDER APPLIANCES,LET ME KNOW AND I WILL HELP YOU WITH IT-MIKE
Mar 06, 2009 | Kenmore Dryers
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
103 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
