Question about Toshiba Satellite L15-S104 Notebook
System very slow and no audio for one year. When
System very slow and no audio for one year. When run/save Hotkey, system's speed increases, but still no sound (Conexant) I've used Driver Detectives, and several other software packages, also Toshiba website, and my ISP, and MS website, and NO SOUND.
    President:
  • 1,118 Answers
Have you already tried this driver?
Hope it works for you.
Regards, CArlos
Posted on May 25, 2010
Testimonial: "Dear Carlos, I have to go home and try out your recommended download. Right now I'm still at work - will be here 2 more hours (8:30 PM) Thanks my friend"
Slow save on pdf file with capture perfect3
Change the scan resolution to 200 dots per inch (200 dpi). If 300 it tajes a few seconds. If 1200 dpi, it may take really long.
Jul 29, 2014 | Canon DR-9080C Path-Through Scanner
Sound is on mute before entering ops. how to unmute
A) The hotkey is not Fn. That is the Function key. Press Fn and F8 hotkey at same time to decrease volume. Press Fn and F7 at same time to Mute volume.
B) Is 'ops' your system tray volume, or Device Manager? I suspect Device Manager.
C) Don't count on Windblows to upgrade your driver; or roll over driver; or play dead. (!O_O!)
DO count on Windoze to lose the address to the driver, though.
Suggest going to Asus Support, and download the Audio driver.
In the small window that comes up on the right, (Opening Audio_XP_xxxxxx), make sure there is a Green dot, in the small circle to the left of Save File.
If there isn't; left-click in the small circle to the left of Save File.
Then when fully downloaded in the small download window to the left; DOUBLE-click right on the file name.
In the next small window go to the far left, and click on
Extract all files.
At the bottom of the next 3 small windows click on Next, Next, and Finish.
Restart your computer if not asked to do so.
(Close all windows, go back to your desktop screen. Start > Turn Off Computer > Restart)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 12, 2012 | ASUS Eee PC 900 Notebook
Can u help me get rid of my pc running slow please?? i am losing it
Run Disk Cleanup
When PC is full of junk content or trash files it start performing slowly. To speed up your computer you need to delete all the trash data from your system. You can clean your PC using Windows pre-installed tool Disk Cleanup. To run Disk Cleanup follow the steps below:
  1. Click Start
  2. Type Disk Cleanup in search
  3. Press Enter
  4. Select the drive which you want to scan and click OK
  5. Select files to remove
  6. Click OK then Yes
NOTE: Follow above steps to clean all drives one by one
Run Disk Checkup
System full of errors also affects the speed of computer. You can speed up your slow computer by running Disk Checkup for detecting and removing errors. To do so follow the steps below:
  1. Open My Computer
  2. Right click on drive which you want to check for errors
  3. Click on Properties
  4. Click on Tools tab
  5. Under Error -Checking menu click on Check Now
  6. Select the options and click on Start
Run Disk Defragmenter
Due to huge transfer of data fragmentation occurs in Windows operating system. This also results in slow PC performance. Running disk defragmentation remove fragmentation and allow you to access data quickly. To run it follow the steps given below:
  1. Click on Start button
  2. Type Disk Defragmentation
  3. Press Enter
  4. Select the drive and click on Defragment
  5. Restart your computer after completing the process
Clean System from Virus
Computer infected by any malicious application also runs slow. In this case you have to download and install reliable antivirus program with up to date virus database. Run a complete PC scan and remove all the viruses detected by the program.
Repair Registry Errors
Windows registry keeps on storing information about programs installed on PC in form of keys. Corrupt registry keys cause a computer to run slow. In order to fix this issue and speed up your computer you need to install a System Utilities program which includes Registry Cleaner and PC Optimizer feature. These tools will allow you to boost your computer performance.
To download a reliable and professionals recommended System Utilities program click here.
Jul 17, 2011 | Computers & Internet
How can I speed up my 8 year old HP computer with xp
just increase the ram or memory to help speed up your computer.
Jun 18, 2011 | Computers & Internet
My HP Pavilion a1120n is running very slow I re formated it a few time over the years. Recently I added more ram and ran great till i clean it with air may , then ran very slow, so I remove some ram then...
Did you replace the hard drive? It is quite possible there is an issue with the drive at that age. YOu could try an application called "SpeedFan" or "HD Tune" and run a S.M.A.R.T test on it. This will help you determine the drive status. You can run a benchmark with "Hd Tune" and determine the speed of the drive. If you want to post your results, I will certainly help out further.
Jan 04, 2011 | HP Pavilion a1120n (PX759AA) PC Desktop
What does biome-1 failed mean when you run the
you kindly format the computer at once and reinstall the software. You computer is under virus attack sir
Feb 27, 2010 | Computers & Internet
Computer takes longer to boot up, plus is running very slow
1. To increase PC boot speed:
There must be too many programs automatically start when you boot your PC. To manage them, click Run, type in "msconfig", select "Boot", then you can disable unnecessary programs from that list.
2. To increase PC running speed:
* Adding RAM is the most effective method, but if the RAM is already at the maximum, then do the following.
* Run disk cleanup and defragmenter. But to be honest, the built-in Disk Cleanup and Disk Defragmenter run quite slow and they will take you quite a long time, so I never use them. Third-party programs are better.
* Run registry optimizer software and defrag. No Windows built-in tools to do this. Search on google or refer to this free registry cleaner review.
Jan 11, 2010 | Toshiba Satellite M65-S821 Notebook
Computer running very slow
Hello
Ok, firstly, the ram will not extend the life of your laptop, it will only give a slight increase in the process speed of your laptop, depending on how much you add.
You can buy the ram modules you need at any computer hardware store, they will instruct you on the best prices and how to install it. You can also try to buy it online(Ebay) where you will somwtimes get a better deal.
Kind regards
Andrea
Dec 13, 2009 | Averatec 6100 Notebook
How do i make my screen brighter on presario v2000
Decrease Brightness (fn+f7) The fn+f7 hotkey decreases the brightness of the notebook screen. The longer you hold down the fn+f7 hotkey, the more the screen dims. Decreasing screen brightness conserves power. » To increase screen brightness, press the fn+f8 hotkey.
Increase Brightness (fn+f8) The fn+f8 hotkey increases the brightness of the notebook screen. The longer you hold down the fn+f8 hotkey, the more the screen brightens. » To decrease screen brightness, press the fn+f7 hotkey.
Nov 03, 2009 | HP Compaq Presario V2000 Notebook
Toshiba Satellite L15-S104 Notebook Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
