I am Trying to set up the wrt54 g wireless -G broad band router on a new laptop computer and the password isn't being accepted. What should I do?
  • Louie  Role
    Louie Role May 11, 2010
    You need to initially connect to the WRT54G using a wired LAN cable to your laptop. The standard password is "admin" less the quotes and leave empty or none for the username. If for some reason this is not being accepted, you need to do a full hard reset on the router to restore it to default factory settings. Of course doing this would also erase all user settings/configurations.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
    Brigadier General:
  • 6,966 Answers
Hi again,
Ane new development(s) or updates with your concern?
Posted on Apr 08, 2008
One of the laptops on our network is getting a pop up that says that our Belkin router has had its pass word changed - it isn't accepting the password (which is working fine for our other machines
A forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router.
1.Insert the paperclip into the reset hole to push the reset button.
2.Press the Reset button for 10 seconds.
3.The wireless router will restart after one minute and reset all the router's settings using default setting.
I would recommend to keep changing the router password when required. Router passwords can easily be learnt of by other users in homes or offices. So make a case-sensitive password
Aug 26, 2012 | Belkin Basic Wireless Router
I have a wireless router (WNDR3400) connected to a switch (about 10 computer connected to switch), and the switch is connected to the modem. For the network, all the wired computers can see and share...
Make sure all the computers wired and wireless are in the same workgroup.
To share files across all the computers and laptops on your network then -
All the computer and laptop in this network group must have their hard drive or folder/s set to SHARED (a hand symbol will be placed on these folders that are shared).
If there isn't a secutity problem then these folders and easy of file sharing then do not setup users and passwords on these folders.
Apr 18, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
Im trying to use my mobile phone through wifi on my home broad band but says i need a pre shared key number how do i find that number
The pre-shared key is nothing but the password you use to connect to your home network. Just type in the password and connect
Jun 14, 2011 | NetGear WGR614 Wireless Router
Hi, my 2 wire ATT wireless broad band Internet router isn't working. Flashing red lights notes
You need to RESET router then configure it .For that press hold RESET button for 10 seconds then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Sep 04, 2010 | AT&T Computers & Internet
Hii i have a linksys2.4G broad band router .it
On the back of the router there is a recessed reset button. You need something small like a paper clip to push it. Push and hold it for 15 seconds. This will completely reset the router to factory settings.<br /><br />You will need to use the default password that came with the router to get in. It should be Admin, but refer to the manual for that. You can find it on the linsys website if you don't have yours.<br /><br />When you plug your computer directly into it, you should go to 192.168.10.1 to access the router.<br /><br />You will have to set up all your settings again.<br /><br />If by chance the default network ID was changed, and the reset did not effect it.<br /><br />Basically the fist 3 sets of numbers in the IP address is called the network ID.<br /><br />Plug your computer into the router and start it. When its up got to run, and type CMD and hit enter<br /><br />Then once the command prompt comes up type ipconfig and hit enter<br /><br />Find the line that says IP address. Take the first 3 sets of numbers from your IP address and type them into a browser, and make the last number 1 and it will access the router.<br /><br />
Aug 25, 2010 | Linksys Wireless-G Broadband Router
How can i connect the router? i got a intellinet 192.168.1.1 there is one wan and 4 ports are there.i have dialog broad band connection.how can i connect it?or iwant to install any software?
This is very easy to do and you should have no problems doing this. The first step to installing it connecting your router to your broad band router through the wan port. All you do it take your Ethernet cable that went from your broad band router to your computer and attach it to your new routers WAN port. next wile your new router is turned off, turn off your broad band router and then turn it back on wile it is booting up turn on your new router this is not always necessary but it will make sure that they sink together properly. And that's it your done just hook up all of your other computers to the remaining ports and they should work with out a problem.
PS. this is just the basics of setting up your router if it has wireless you may want to think about implementing some security measures such as encryption.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Intellinet Active Networking Intellinet...
My Netgear WNDR3300 just quit putting out a wireless signal. I just bought a new Compaq notebook and the wireless internet was working for like three days and now nothing. And it is running windows 7 and...
It seems that router wireless setting need to reconfigure,please follow steps to resolved issue
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. If WPA is selected in Security mode, then check the Password that show up in the passphrase box.
now try to reconnect wireless
Thanks for using Fixya
May 14, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
We have virgin wireless broad brand and it connects for the only computer in our house however now we have a small ASUS laptop and also want that laptop to connect to our virgin broad brand however it is...
or that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Click on wireless settings then WEP Security then if it is in * or # format then add new WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
May 08, 2010 | Computers & Internet
Can not connect ds to router
You will need to connect to the router and set up WEP. Do you know the Admin password for the router?
Jun 03, 2009 | NetGear WGR614 Wireless Router
Linksys wirless G 2.4 broad band router download driver
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Feb 10, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
