Question about Samsung Eternity Cell Phone
How do i fix the calibration on my phone because its so bad i cant reset the calibration
My iphone screen cant touch ?
Hello there,
There are two major reasons that could be causing the touch screen not to be responding. The first is if the phone fell and the sensor board got bad, and the best solution is to replace the sensor board. To replace the sensor board is quite sensitive so i will strongly advice you seek advice from a specialist that can assist you with that. But if you intend to fix it DIY way, then you can ask and i will direct you through the steps.
On the other, it might be the screen is weak and needs calibration. To calibrate the screen. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Thank you for using fixya.
Caseytech
Sep 21, 2011 | Apple iPhone Smartphone
My samsung s800 touch screen is sensing all touches like they are being made to the far left of the screen. can access any functions as they all require a touch in other places on the screen, had the...
The only way to get this back to normal is to re-calibrate the screen...
You can only do this through the handset menus.
If you can, go to settings > Phone settings > Calibration and re-calibrate
If you cannot even go into the menu properly, there is not a lot you can do other than a master reset or a software update (using the kies software).
You can do a reset by typing *2767*3855# if you can get to the call screen.
If not, it's a return to the manufacturer I'm afraid!
Feb 03, 2011 | Samsung Jet S8000 Cell Phone
My touch screen quit working
If the touch screen of your phone keeps working, then it means the sensor board of the phone is bad and need to be replaced, if you can access the menu of the phone, then you need to calibrate the screen first.
To calibrate the screen, you need to go to the menu, then you select settings, then you select calibrate screen then you follow the rest of the instruction from there on.
If calibrating the screen does not help you, then it means you have to fix the sensor board of the phone, if your information from the keypad reaches the screen, then it means you simply need to replace the touch sensor board of the phone.
Hope this helped.
Take care and good luck
Jan 10, 2011 | Samsung SGH-A877 Impression Cell Phone
Lg prime Touch screen is not funtioning. Its like the calibration is off but when I go to reset the touch it doesnt move. I cant text it puts the words above the letter i actually want. I have reset, and...
KINDLY MAKE A CONTACT TO SERVICE CENTRE SIR BECAUSE YOUR PHONE SENSITIVENESS MAY BE LOST. DUE TO THIS ALSO TOUCH WILL NOT WORK. THANK YOU. advance happy new year
Dec 31, 2010 | LG Cell Phones
My lg cookie wont do what i want at all :/ When i press a screen button it presses the button next to it..so i cant use the left side of the phone at all...how can i fix it ??
You should run touchpad calibration. It's in Settings->Touch Settings->Touchpad calibration. While doing the calibration you should accurately tap at the center of the black cross with a stylus. Hope this helps.
Dec 20, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Cant calibrate screen on i900 omnia.
put a blank file called welcome.not (make using notepad) onto the removable storage card this will bypass the startup screen and mean it does not jam into this look on startup
down load a file phm registry edit... (search on internet) put the cab onto the phone... in stall.. and run
set the sensitivity on this to 20, you can then calibrate the screen... you can try stepping it to 18 16 14 and 10..
this will cure the problem
Jul 22, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Reseting KA08 due to bad calibration
my KA08 mini does not respond when i press the menu button. therefore i cannot access the menu....what do u suggest
Jul 06, 2009 | Cell Phones
Touch Screen not working
ı have problems about wıth my touch screen. ıt does not works sometımes.
ı have to restart my phone to make ıt work . can ı do somethıng more?
Apr 21, 2008 | LG KU990 Viewty
Samsung Eternity  Cell Phone Logo
187 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
