Question about KitchenAid KAWS750L Top Load Washer
Describe your kitchenaid clothes washer KAWE450VWHO Problem will not spin or drain water.
  • 24 Answers
If it makes any noise when it SHOULD be draining and spinning, it's most likely your motor coupler. It couples the motor to the transmission and takes the place of a belt. If the machine it completely silent and just stops when it gets to the rinse/spin cycle, then it's probably the lid switch. Hope this helps.
Posted on May 26, 2010
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Spin cycle doesn't spin
what kind of washer is it top load or front load and brand.?
May 26, 2012 | KitchenAid KAWS850L Top Load Washer
Kitchenaid kawe450vwho Clothes Washer
try cleaning the screen on the inside that is used to filter anything from getting into the pump propeller. if that doesn't work it could be a burnt solnoid valve
Nov 10, 2011 | Washing Machines
Describe your 24032 \ 24036 Top Load Washer Problem Washer washes, fills with water, but will not drain water out and spin water out of clothes
The most probable thing wrong with your washer thats causing it to not drain or spin is going to be a broken lid switch.This tip i wrote will help ya to see if it is the lid switch thats causing it,
http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
GENE
Sep 16, 2011 | Kenmore 24032\24036 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
1.- replace timer
2.- or motor has thermal fuse check continuity.
3.- replace lid switch
Jul 08, 2009 | Kenmore 24032\24036 Top Load Washer
KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Jan 31, 2009 | Washing Machines
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Washing machine
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 18, 2008 | KitchenAid KAWS850L Top Load Washer
Wahing machine kitchenaid won't completely drain water
Check drain pump for any blockage.Pump accessible by removing lower panel,on bottom front of machine.Also try liquid instead of wash powder,and make sure that you are using automatic powder as other will foam in machine.
Apr 01, 2008 | Indesit W 123 Front Load Washer
Spin Cycle
HP, sounds like your washer is not going through the neutral drain. After agitation the tub should drain for about 90 seconds before going into spin. You can verify this by doing a load with the lid up and holding the lid switch down with a small screwdriver. If it fails to go into the neutral drain, it's a gearcase problem and should be covered under warranty for 5 years. If it does go into the neutral drain, then it's another issue such as the pump or drain hose....Catriver..post back
Dec 20, 2006 | KitchenAid KAWS850LE Top Load Washer
KitchenAid KAWS750L Top Load Washer Logo
210 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
