Question about Broan-NuTone Broan Elite E661 Under-the-Cabinet Range Hood
Electronic control panel has gotten pushed into unit so it can't be operated
    President:
  • 3,085 Answers
Go here toBroan Company and talk to Service Dept
http://www.broan.com/display/router.asp?docid=38
Posted on May 25, 2010
When pluggged in, all lights behind the buttons on control touch pad panel light up, then go out. When the 'on' button is pushed, nothing happens. Can you tell me what the problem is? Thanx
First thing to try is turning off the power to the machine for a minute and then turn it back on, if that does not fix it then electronics have a brain problem. I have noticed that appliances with electronic panel controls are having many problems, my washing machine electronic control panel is bonkers but never had problems with the old mechanical controls. In order to fix mine I would have to order the whole panel as you cannot replace parts, I'm sure you unit is the same.
Mar 12, 2018 | Frigidaire Heating & Cooling
Tip
Sabb or Sab Explanation for Kitchen Ranges
Here is a useful tip in identifying a frequently reported problem on some model ranges and wall ovens equipped with an Electronic Range Control (ERC) or Electronic Oven Control (EOC). An “error” code display of “Sabb" or “Sab” will be displayed and the range or oven will not function. This is called “Sabbath Mode" and it may be costing you unnecessary charges in service call fees. This is NOT a problem, but actually a feature provided by some manufacturers to enable customers of certain religious faiths to honor the Sabbath. The range will not function at all during this period and cannot be reset by unplugging the unit or turning it off. In your owner/operator's manual there should be a section that refers to "Sabbath Mode" under the control panel features and operation. This "problem" is a minor operator issue and is not a malfunction of the appliance. This is commonly reported by customers to service companies to have corrected, but the repair is unnecessary, and usually NOT covered under the manufacturer’s warranty. The reason: It is a designed feature of the appliance and considered “operator error” in most cases. What this means is you may be paying someone big money to push a couple of buttons and “fix” something that could have taken you minutes to correct yourself. Sabbath Mode can inadvertently be activated by pressing the wrong sequence of control panel buttons, or following a power outage. The procedures for turning Sabbath Mode on/off are referenced in your owner operator manual under operating instructions. Manufacturers provide different procedures for activating and deactivating the mode, so instructions may differ. I hope this helps avoid the need for a service calls in the future and saves you money.
on Dec 09, 2009 | Kitchen Ranges
Refrigerator is not cool
check the damper-vent door located between the freezer and refrigerator compartments to see if it might have gotten iced over and stuck shut,if so take a hand held hair dryer and thaw it out,then check for operation,if it still doesn't move when the refrigerator temp control is adjusted,then it can be the temp control itself,or if its electronic it can be a motor operated damper-vent door and the motor could be bad or a control board if its electronically operated such as a digital temperature read-out unit
Dec 23, 2010 | Haier (688057301716) Refrigerator With Ice...
Maytag Dishwasher MDB6100AWW - control panel short??
If you can take the panel out dry it with a blower.You can use the hair dryer to remove the moisture. Do not point the hot air on the components for more than 20 seconds. Repeat it. If you notice any white/green fungus remove it. Check the connectors also.
May 17, 2010 | Dishwashers
What does F7, an error signal, mean, and how to fix it?
F7 Means a stuck key on key pad or a short to the control panel
the control and key pad has to be gotten to threw the back of the stove make sure to unplug the stove first ...
Shorted key panel membrane switch; Check Electronic Range Control (ERC)
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Nov 20, 2009 | GE Kitchen Ranges
Sears elite he dryer stopped working
Bad control panel. Replace the control panel at repairclinic.com. When your control panel clicks like that it means that a resistor or solder joint has gone bad and it is cheaper and easier to just replace the board
Feb 19, 2009 | Kenmore Elite HE4 Electric Dryer
How to reset the control unit?
press heated Dry , Nornal, Heated dry Normal: The machine will go into diagnostic mode. this may reset your control.
If not clear the fault, unplug the power cord,open up the electronic control panel again and check your connection, maybe the wire harness to the drain relay pin is not connected correctly.
Jul 26, 2008 | Dishwashers
Electronic Control Panel Problem
Anyone else experiencing this problem might want to try the following. We removed all affected rubber push buttons, exposing the electronic printed circuit panel behind the protective glass. We sprayed a soft rag with "M.G. Chemicals Heavy Duty Flux Remover" and pushed it in each opening in the glass panel, twisting it to clean the circuit panel behind each push button. We then cleaned the back side of each rubber push button with the same flux remover chemical. Since then, the push buttons require the slightest touch to activate. Surprisingly, when pressed firmly they don't work as consistently. We're hoping this is a lasting solution.
Mar 10, 2008 | Kitchen Ranges
Kitchen Ranges Logo
219 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
