Question about Coleman Heating & Cooling
Inside unit freezes up in 15 minutes unit nearly 2 yrs old
  • 674 Answers
First check you air filters. Then make sure the coil isn't blocked by lint and dust. Too little air flow can cause this. Make sure the indoor fan is running also. If that is ok then it could be a low refrigerant charge. You'll need to get someone to check that unless you have some guages. Let me know if any of this helps.
Posted on May 26, 2010
Have a Rheem central air unit situated outdoors, 20 yrs/old. The condensers are contained within it. I can run it 2 days straight, no problems. As soon as I turn it off, water winds up inside.
If the unit is freezing you will begin to see frost building up on the larger diameter copper. Also if you take the panel off of the evaporator coil (section that the copper is entering) you should be able to dump some water in the pan And make sure it is draining. Slowly pour the water.
Jul 10, 2017 | Heating & Cooling
Screen freezing
Are you sure it is the TV itself and not the way the signal is received? By that, I mean check your input receiver such as satellite or cable box isn't the fault. Does it happen with a DVD or video player? The best way to do this is to disconnect all the power to the equipment. Don't just turn off or put in standby. Remove all the plugs and leave for 10 minutes then reconnect and see if that rectifies the problem. If it doesn't, then only connect and power up one piece of equipment at a time until you eliminate everything and prove it is the TV.
Jan 07, 2016 | Televison & Video
Frezzer is only 2 yrs old and already has defrosted on its own what seems to cause that?
This machine has an automatic defrost cycle that comes on automatically 4 times a day. During defrost the compressor goes off and the heaters inside come on and melt the frost from the coils. In about 20 minutes heat shuts off and compressor comes back on and freezes againl
Oct 18, 2010 | Continental Freezer Freezer display one...
Stops running after about 2 minutes
Question the manufacture about a new circuit board.
The Pool Tech
Jul 10, 2010 | Dolphin Maytronics Diagnostic Robot...
Fridge 14 yrs old. Unplugged for 2 yrs - now won't cool.
with the unit being that old , the compressor probably whent out the oils inside probably froze up ,,,,, to replace a compressor you are better off replacing the unit it is a major repair
Jan 31, 2010 | Fisher Freezers
Ps 3 games freeze after 10 to 15 minutes ps and ps 2 games play ps 3 games freeze after 15 minutes
unit maybe internally dirty not letting it cool properly get canned compressed air and bloww out throughly!!! :)
Jul 05, 2009 | Sony Playstation 3 (PS3) Console
Jobri Dolphin 2 yrs old, starts, than intermitant, than stops. Wait few minutes, starts up, does the same
Hello xthus, I suggest first call Jobri LLC at 800-432-2225 ask for Michelle of quality control. If she can't replace the unit ask for any or all technical information. With this info repair is possible with my guidance. Let me know of the outcome. Good Luck!
Oct 02, 2008 | Jobri Health & Beauty
GE Side by Side Not cooling/freezing
sounds like defrost problem. remove back lower panel in freezer. defrost all ice on coils, this will fix problem temporaily. I`m looking for the tech sheet to test system.
Jul 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire freezer, only 2 bottom slelfs freeze
If your freezer is six years old the compressor warranty is also over. Sounds as though the system has lost its refrigerant charge. A refrigerant leak in these smaller units is difficult to locate and somewhat expensive to repair. Your choice.
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
