Remote Control of SAMSUNG DVD HOME Theater System HT-SK5 does not work. Repk=lacing the batteries with new one won't help.
  • ykim4745 May 25, 2010
    I want to fix it rather than replace it.
  • 17,970 Answers
When this devices failed, the better solution (and less expensive) is replace this part; check this LINK for find it.
Good luck.
Posted on May 25, 2010
  • ZJ Limited
    ZJ Limited May 25, 2010
    At FIX-MY-REMOTE.com we supply users
    everything need to fix and test your remote control with links so you
    can fix your remote control no matter what remote control it is,
    including remotes for TV, VCR, Audio, DVD, HDTV, TV/VCR, TV/DVD, DVR,
    SAT and Cable remote that you need. We have direct links to universal code websites. We have direct links to
    replacement remote controls for most brands. 1st Test your remote control
    What you need:
    - Good working batteries installed
    - Digital camera or camera phone
    - Remote control
    Steps to test your remote control
    1.Place good batteries into remote control
    2.Turn your camera on
    3.Point the eye of the remote towards the lens of the camera (shown
    below)
    4.Press each button on the remote while viewing through the digital
    viewer on the camera
    Results: (Read all the way through)
    While looking at the camera screen you will see
    the remote (similar to picture below).
    If working then you will see a flickering light
    coming from remote (right image) when a button is pressed(not all buttons will work, see below).
    Buttons that will not
    work on any remote control:
    1. Record button (This button
      might work if you also press the play button at the same time)
    2. TV / DVD / VCR / Cable / AUX
      button
    3. Program button
    If the remote control works you will see a flickering or
    steady light coming from the eye of the remote through the camera
    screen. Check every button on the remote to make sure
    they all work. If all buttons show a light than there is no need to
    repair or buy a new remote, this means that your TV/VCR/DVD/etc device
    needs to be fixed, or the remote control needs to be reprogrammed if it
    is a universal.
    If some of the buttons do not work, than your
    remote may also work for a DVD/VCR/Cable/Aux/etc, if so than you will
    have to click the DVD/VCR/Cable/AUX/etc button (This tells the remote
    that you are switching to this device and the remote will then allow a
    signal for the features of that device to transmit) and then some of the
    buttons that didn't work, may now work.
    If the remote partially works than you will see a light with only some of the
    buttons being pressed. Or you will not see a light until you press a
    button hard enough; this is do to the wearing of the remote keys. This
    problem is easily fixed either by sending the remote to us for repair
    (Click here for more Information), or Repair the remote yourself by
    ordering our Key-Pad-Repair Kit with simple, step-by-step instructions.
    Most common buttons to not work do to the
    wearing of them:
    1. Power
    2. Channel up/down
    3. Volume up/down
    4. Keypad numbers
    continue...
  • ZJ Limited
    If the remote does not work you will not see a light for any of the buttons
    pressed. We can help you with this, there are a few options that we
    offer:
    1. Go to
      www.theRemoteDoctor.com for more information about Our Repair Services.
    2. go to www.ReplacementRemotes.com and order a new original replacement remote
      control.
    3. You may also try www.KeyPadRepair.com.
    Hope help with this.
  • 1,284 Answers
Hi, since you have replaced the batteries and the remote control is still not working, you have the option of taking to a tech to check if it is repairable (because most remote are not repairable) or get a new one...
Take care
  • Shehu Pro
    Shehu Pro May 25, 2010
    O.k, try opening the place the battery is inserted, take a screw driver to scratch the positive and negative contact side where the battery stays and insert the battery back. If it does not work, then you need a tech...
I can't get player to read DVD disc. I've disconnected and reconnected it. Don't know what else to do but I'm truly frustrated!
hello,its the LENS of your dvd player that is weak,so therefore,your dvd player cannot read disc.
All you need do is just to get a new lens and get the dvd player to an authorizes repairer to fix it for you.
kindly rate me if this solution is helpful.
Take care.
Apr 10, 2010 | Samsung HT-SK5 System
Casdasd
Replace amp ics. Check for any dc voltage on speaker terminals. replace ic that correcsponds to that channel. These are PWM amps.
Nov 21, 2009 | Samsung HT-SK5 System
The remote isn't working at all with the home theater system. The tv is also a samsung i disconnected everything and reconnected but the problem still exist. any ideas of what i should do?
First of all, what is the remote control that you're using?
If you are using the remote control that came with the HTS unit and it's not working with the home theater, press the DVD RECEIVER button. That should work.
If not try this. Take out the batteries on the remote control and hold down the POWER button (without the batteries!!).
Hope this helps!
Jun 26, 2009 | Samsung HT-TZ312 Theater System
Dvd home theather system
The audio amplifier IC are fried and need to be replaced
Mar 31, 2009 | Samsung HT-X40 System
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 17, 2008 | Samsung HT-Q100 System
Hooking up TV Guardian with Samsung HT-SK5
Just purchased system, didn't come with any speakers, but when hooked up to tv get picture and no sound unless I put headphones in.
Jan 07, 2008 | Samsung HT-SK5 System
HG-SK5 Jumbo Universal Remote
http://www.jumboremotecontrol.com/guide_to_programming_the_remote.html
this link will take you to the jumbo remote site and the instructions and codes for it.
Nov 30, 2007 | Samsung HT-SK5 System
when you turn it on, hold the power button until it has fully loaded
Sep 02, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
146 people viewed this question
 Grubhead
Grubhead
