Question about Sony CDX-M800 CD Player
Face panel Screws
I lost one of the 2 face screws of my Sony cdx-m800 car stereo. It's a very small screw that has raised smooth top that the face moves on with regular threads on the end. Any assistance on where I could find a replacement?
Thanks
trini
Weigh the focking thing in its ****
Posted on Apr 30, 2008
Buttons on my sony CDX-GT540UI stopped working
Sony car radio cdxgt540ui buttons non responsive - remove four screws on reverse side of faceplate, pry open with fingernails starting at the top right or left corner of the face plate once opened remove board on the reverse side of the LCD there are small brackets holding the LCD use a needle nose to pry each bracket in straight position then remove LCD for ten seconds then place back on to board and been brackets back in place. After these steps the front buttons should work again this process worked for me.
Mar 16, 2012 | Car Audio & Video
Just installed an XDM7615 Dual stereo and the face plate won't detach. Can anyone help? The manual says there is a button behind the face when it's in the 'eject' position but pushing this button does...
There are 2 very small screws on the back of the face plate that need to be removed. Once these are removed, you may then remove the face plate.
Feb 10, 2010 | Car Audio & Video
Sony CDX-M800 inside face (buttons and display) do not work
you more than likely have a bad flexible cable(s).
Dec 23, 2009 | Sony CDX-M800 CD Player
Just a question as to how the base attaches to the tv?Don't have the unit, at a friends house and wants to know how to remove, looks like it attaches at the bottom, is this correct?
Most tvs have four to six screws that go in the back just above were the mount goes in at the bottom of the unit. look for a 8 to 10 inch raised area or 3 screws in a row, 2 rows. Face the tv face down on the bed with the base hanging over the edge. Some tv's like L.G.base just push into the bottom with 2 or 4 screws holding it in place. The screws will look much heavyer then the ones going around the set. maybe round top not flat topped
Nov 26, 2009 | Sansui HDLCDVD260 26 in. LCD Television
Black out
this is a coincedence. The CDX-M800 had a HUGE problem with the ribbon cable on the face going bad, causing this exact problem.
$14.00 and some time will put it back into perfect condition.
http://cgi.ebay.com/ebaymotors/Fix-your-Sony-CDX-M800-flexible-ribbon-cable-CDX-M800_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ43947QQihZ020QQitemZ300287945333QQrdZ1QQsspagenameZWD1V#ht_2258wt_1213
Jan 21, 2009 | Sony CDX-M800 CD Player
Sony cdx-m610 BIG PROBLEM
yal ever fix them? its the ribbon cable between the face and the circuit board inside the unit the ribbbon cable is very cheap on ebay just google for example cdx-m610 ribbon cable now for the repair close ur face before u take out ur radio assuming u guys still have ur remote to do so theres 3 screws on the bottom of the face when u go to carefully pop the front panel off after pullin them hold ur deck facing down (this will keep ur reset and open buttons from fallin out then theres 4 screws holding in the face's circuit board roll the board out of the face very very carefully pry open the little black lock holding the cable in the connector then open ur radio up pull out the cd player assy same thing with that connector then ull notice the cable goes thru a tension roller pull each end of the cable to unroll it hold it there while removing the cable and sliding in the new one then slowly let go of the roller reattach the cable ends and put everything back together with the face remember its easiest to hold the deck face down those 2 buttons will stay in place hook the top of the face's cover first then put the deck back in ur ride and enjoy these ol sonys r worth a $20 fix specially if they still work good hope this helps yal
Aug 30, 2008 | Sony CDX-M610 CD Player
Cd player
DOES IT TRY AND SPIN THE CD>?
or does it just kinda click and then spit it out?
May 30, 2008 | Sony CDX-M800 CD Player
I am going to replace ribbon cable. How can I connect cable to face?
The Face cover is snapped in, so you need to use a small flat tipped screwdriver  and run it around the black and silver plastic cover, and it should snap off. Take Your Time!
Mar 12, 2008 | Sony CDX-M630 CD Player
Lost function of remote and front panel buttons
it seems like the ribbon cable,the one connects the face to the main board is damage.
I don't know if you can replace it by your self,because you need a little bit of experience on stereo repair,but you can try.you can order the part from pacparts.com
Part number 168795211
Dec 03, 2007 | Sony CDX-M800 CD Player
Sony CDX-M800 CD Player Logo
50 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
