Question about Continental Electric Portable Air Conditioner
What is the btu on the ce-pac1061-1 air conditioner you have alot of them listed but not this one
How many btu
Btu's are no longer used as size measurement in air conditioners
it is now kvw
reference can be found on line but quickly
9000 btu is equal to 2.5 and 32000 btu is around 7.5
if you have a knowledgable salesman that is honest they will be able to convert the rates for you
Apr 12, 2015 | Heating & Cooling
What is BTU's of this model
Hello Friend, that's a great question!
I show that your post is listed under Frigidaire air conditioner (FAS1084M2A). I show that your air conditioner has a cooling capacity of 18,000 BTU's. If this is not your model number, please provide me the correct number. You can typically locate the serial tag (which lists your model number) behind the front grill by the air outlet or on the side of the cabinet. Other possible locations are on the front edge of the chassis base or behind the dial plate of the control panel. If you need further assistance, please feel free to reconnect.
Jul 11, 2014 | Frigidaire FAS184M2A Air Conditioner
115 volt equals how many btu
Apples and oranges.
The 115 volts tells what "quantity" of electricity is needed to run the unit.
BTU's are the cooling capacity of the unit, which usually is about 5,000 for the smallest, up to about 18,000 for the largest.
Over 18,000 the electricity quantity is often boosted to 220 volts because of the larger size of the unit.
Jul 02, 2014 | Continental CE-PAC1062 Air Conditioner
How do i get my portable haier air conditioner cool off my house below 73
Air conditioners can only drop the temperature of the room temperature a maximum of 15 to 20 degrees F. A 95 degree F room temperature can drop to a maximum temperature of 75 to 80 degrees F. If the room temperature drops from 95 to 85 degrees F, Then the problem is having too small of a btu rating on the air conditioner or refrigerant has leaked out the sealed system which can affect the amount of cooling performance. You will have to buy a higher rated btu rated air conditioner if the temperature of the room drops by only 10 degrees F. Air conditioners are rated by how much heat that can be removed each hour. The more humid it is, the more work an air conditioner has to do. They cannot do more work than the btu rating that is listed on each air conditioner.
May 26, 2014 | Haier Heating & Cooling
What is the price of this unit??
It's hard to give you a price range, as that model has apparently been discontinued by the manufacturer.
Jul 13, 2011 | Continental CE-PAC1163 Castle Series 11000...
How many btu in heat mode does my amana heat pump condenser model arpf486016ab put out?
the compressor as you have listed is 12,000 btu so it depends on the energy effieciency rating for how many it actually produces in hot air..
Aug 18, 2010 | Amana PTH123B25AJ Heat Pump Air...
LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At http://www.paylessminisplit.com they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
May 16, 2010 | LG LM-2430C2L Cool Mini Split Air...
I have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Jun 30, 2009 | Amana Portable Air Conditioner
Amana window air conditioner 10000 btu
Mine has done this alot, mostly because I live in a state with ALOT of wind, and in an area with ALOT of dirt. Sounds like your coils are dirty. Try cleaning it out, or having it cleaned out. If you spray it with water just make sure your compressor is facing up and you don't use too much pressure. Hope this helps
Jun 12, 2008 | Amana PTC074B25AE Electric Heat Air...
Continental Electric Portable Air Conditioner Logo
66 people viewed this question
Top Continental Heating & Cooling Experts
Tim Whalen
Fotis Papastamatiou
jasbo
jasbo
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
