Question about Microsoft Windows Vista Ultimate Edition
Vista service pack!!! i have seen that finally the sp1 pack is out but why cant i get it on my update service??? is it because my laptop is not compatible? and if this is so how can i make it?
  • homez83 Apr 07, 2008
    thanks, i will check that when i get back tonight but i am pretty sure i have been keeping up with the updates, installing everything but the language packs (unless i should get them too!!) went on the update site, not sure which one i need, i am running the 32bit vista ultimate, If i download and install manually will i be able to remove it if something goes wrong?
    thanks for your help, i will try the automatic updates again, had a quick look at the notes on the web page about the update and it say i may need to update some drivers especially the coixent hd audio which i have on my system. How would i do this? is this not something that gets automatically updated?
    New Friend:
    Problem Solver:
  • 12 Answers
Guys need windows key can go site www.funkinyes.com to got. My key got here and after i used is great works. Hope can help you.
Posted on Mar 02, 2016
  • 24 Answers
I would agree with Solution 1. If you can't get HIS way working, go to Microsoft Online Downloads.
SM
Posted on Apr 08, 2008
    Novelist:
    Champion:
  • 214 Answers
I wondered the same until I had loaded all available updates, including optional ones (but I don't know if that last was necessary). Then "voila" SP1 was shown as an available update! You can manually download the SP1 from the update site, but this is a 400+ Mb download. Give it a try. Download and install all available updates (this may take several inspections and installs [each probably requiring a reboot in between] so persevere). Don't think that because you have installed all the (visually) available updates that you have in fact installed ALL the updates, some require a previous update be installed before the next update is identified. This is probably what happens with SP1. Good luck
Posted on Apr 07, 2008
  • 1 more comment
  • Les Clayton Apr 07, 2008
    Use the "Windows Updates" selection in the "All Programs" listing under the Start Button. This will select Available Updates for your computer (but as said above not all of them). Do this several times until you find that there are no more updates available.
    Note: The automatic Updater did not find and Install all the available updates on my computer.
    I would shy away from manually selecting the updates on the Microsoft Update page as most of these are not necessarily required for your computer.
    Hi again.
    Yes you can uninstall updates using the "Uninstall a Program" option in the Control Panel (found under the Start Button). The updates are usually listed under "View Installed Updates".
    A second method is to create a Restore Point before doing the Updates. This will allow you to Roll Back to a previous state if all goes wrong (but it shouldn't).
    The coixent(?) hd driver may need to be downloaded from the manufacturers site.
    Google the manufacturers name and go to Support or Downloads page. Select your device from the list and download and install that driver. Before doing so, check that it is Vista compatible.
SOURCE:
Asus g2s
Did you do ALL your windows update before the Service Pack? That SP has been out for years? Doesn't your laptop have Windows Updates set to Auto? Choose one or the other, Vista or Win 7 and do a Full Install.
May 09, 2013 | ASUS Computers & Internet
I have change my ops from vista to windows xp pro i cant not fine the drivers for vista ml3108b note book can you help me pls. thanks
Hello no1sugard, go to this "Website," and "Download the Updates" for Windows XP
(Service Pack 3)."
  • First make sure that you have [SP1 and SP2] already installed in your Computer?
  • To {check} which "Service Pack" you have already?
  • If not?
  • Then you must "Download SP1 and SP2 first!"
  • Open "the Computer Properties," by [Alt / Right] clicking on the Computer in the 'shortcut menu' of the "Start Menu."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Click here: http://windows.microsoft.com/en-us/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
Feb 21, 2011 | E-Machines eMachines Refurbished EMA...
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Sep 21, 2009 | Computers & Internet
Sound drivers
Please download from the link given below all drivers including sound drivers for your laptop :
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220EP&LOC=3#div_pos_5
Jul 16, 2009 | Sony VAIO VGN-CR220E/P Notebook
Cannot get out of Configurating updates: stage 3 of 3 screen
This is all I could find:
It's not only Windows Vista Service Pack 1 that isn't ready for general consumer availability. Some of the updates released on February 12, 2008, as a part of the Microsoft monthly patch cycle, have managed to effectively kill Windows Vista. Users are reporting that, following the introduction of the February 12 updates, Vista gets stuck at the finalization of the deployment of the updates displaying the message "Configuring Updates Stage 3 of 3 0% completes" and then entering
an infinite reboot loop. And there is absolutely no way out for the end users, because canceling the configuration process of the updates is a move equivalent to losing access to the operating system entirely. This will even happen in Safe Mode.
Microsoft has yet to officially respond to the issue, or to provide a resolve or at least a workaround. However, it does seem at this point that there is an issue with the deployment of the pre-requisite updates necessary for the smooth installation of Windows Vista SP1. Namely, the problem resides in the Vista installation software. The fact of the matter is that end users will have to first update the Vista installation software and only then deploy the remaining February 12 updates and only at the end Vista SP1 RTM.
If you are stuck watching the "Configuring Updates Stage 3 of 3 0% complete Do not turn off Computer" and in the endless reboot loop, then stop the cycle and boot from the Vista media. You will need to "Repair your computer," so select your Vista installation and restore it to a point before the deployment of the updates. After gaining back access to your operating system, you will have to install the service stack update, namely Update for Windows Vista (KB937287). Deploy this update before any other on your Vista, and only then install the rest. At this point in time, you should experience no more problems.
"Update 937287 is a prerequisite package that contains updates to the Windows Vista installation software. The installation software is the component that handles the installation and the removal of software updates, language packs, optional Windows features, and service packs. Update 937287 is necessary to successfully install and to remove Windows Vista SP1 on all versions of Windows Vista," Microsoft revealed.
Dec 18, 2008 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
I have Windows Vista installed on my laptop. I install all the automatic updates. Recently Vista downloaded Service Pack 1 and I installed it. After the installation my laptop stopped working. I can...
Your problem: "I have Windows Vista installed on my laptop."
Unfortunately, as with a lot of MS service packs, they can crash some computers. You need your windows vista disk and, booting from it, you can select repair your vista installation. This should take care of the problem. Then don't update to sp1 for a few months.
Jul 05, 2008 | Acer Computers & Internet
Acer Aspire 5630
Seems like your VISTA upgrade didn't sucessfully upgrade itself from XP to VISTA. Seems like M$ update program detects your OS as XP and tries to install the SP3 for XP. VISTA only has SP1 released. Its currently stuck in a loop that it doesn't know what to do. Restart your laptop into safe mode by pressing F8 before the VISTA loading page comes up and go to Safe mode and backup your data and use the ACER RESTORE CD OR ACER RESTORE METHOD to help you reload your system back to factory defaults then upgrade back to vista without install any updates or connecting it to the internet.
This is my best solution to get you out of this weird and unusual situation.
Jun 30, 2008 | Acer Ferrari 4000 Notebook
My display drivers and audio drivers not supporting vista ultimate
you shouldn't have installed vista service pack 1
its a known issue with vista service pack 1
if u had vista before and u updated it to sp1...i would suggest you to either do a system restore and uninstall sp1
or install XP back
Jun 04, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
277 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
