Question about Makita Angle Grinder 7" 6600 Rpm, 15 Amp
WHAT SIZE EXTENSION CORD FOR GA7021 SHOULD I USE AND MAX LENGHT? BURNING UP GRINDERS
    Novelist:
  • 145 Answers
Well for 15A the minimum wire size in your cord should 14 gauge, Length can't really be specified but you want to go for less resistance in the cord, thicker wire and less length will give you less resistance (more so thickness). If your grinder works fine without the extension cord, I would recommend getting a heavy duty extension cord with 12 gauge wire and trying that.
Posted on May 25, 2010
When i put the tstat on high fan it goes back and forth from high to low
Need to check the cap on the unit it is a silver can may be shorted
May 20, 2014 | Dometic Rooftop RV Air Conditioner
WHAT ARE THE MOST COMMON PROBLEMS WITH RIDGID GRINDERS?
Most common problems with small grinders in general (all brands) fall into two main catagories. Low power situation and lack of lubrication /debris or maintainance. Electric power tools are used with an extension cord. If too long of cord or improper gauge wire is used, the tool will heat up and burn the brushes, switch or copper winding (lower life of tool). If you feel the tool getting hot either let it cool or check power supply. Tools such as grinders generate lots of dust/debris that enters the tool. Abrasive dust entering tool prevents proper cooling and eats varnish off winding / wears carbon brushs and commutator. Grinders/polishers get packed inside with fluff coming off bonnets preventing cooling. All this overheating prevents grease from properly lubricating gears. Check gearcase for good lubrication and keep inside of the grinder clean. Good luck
Jul 13, 2011 | Ridgid 23983 Grinder 412" Angle
I left my Makita 9555NB angle grinder out in the rain overnight. I brought it in out of the rain the next morning and left it to dry inside the shed for two days. It now seems dried out. Would it be safe...
Ive had some power tools left underwater in wheel barrows that filled up.
It is not the safest thing to go trying. But if it is dried out, I would plug it into a surge protector, switch it on, and set it away from you, then turn the surge protector on.
Jun 17, 2011 | Makita Angle Grinder
Can I buy a new cord for my dremmel multi max? my dog chewed it up and can I order it?
If there is one ck with (ereplacementparts.com) you will need your mod. # good luck
Nov 28, 2010 | Dremel Multi Max Kit
17202 8'' bench grinder 3yrs old hasent run 1 hr needs on off switch wilton stated after 6mos of waiting for soposed back order that co that maid these for wilton is out of business they said try lowe;s...
go to your local marina and buy a simple on off switch or take the wires off the switch on your grinder and hook them up to a extension cord and put an inline light switch on the cord.
Oct 21, 2010 | Wilton 17202 8" Bench Grinder
What gage wire extension cord to use with B&D 19" electric mower
I'm assuming this isn't a rechargeable model, as you didn't list the model number. These usually have a 12amp motor. The cord size would depend on the lenght. At about 50' a 14ga would be fine. At 100' you should go to a 12ga (copper)
Aug 11, 2010 | Black & Decker 19" Electric Lawnhog...
Used extension cord on freezer then it stopped getting cold.
never use a extension cord unless it is of a larger gauge wire size eg: #12. as opposed to standard #16 or #14. the compressor/motor will not get needed power and burns out.
Jul 12, 2010 | Frigidaire Freezers
Torque setting for peugeot 206
hallo
If you have normal 1.6 liter 206:
max bolt lenght:176,5mm
20Nm and aditional 240°
1,6 liter 16valve engine
max bolt lenght:122,6mm
20Nm and aditional 260°
Marko
Sep 25, 2009 | 2006 Peugeot 504
Compressor did not kick back on
make sure your are plugged into an outlet that will support the amps the compressor draws on start up if your plugged into an extension cord make sure its the right size for the lenght of cord ie.if your 50 ft from the outlet you should use a 12-3 cord,100ft 10-3, so on and so forth.
Jan 17, 2009 | Campbell Hausfeld 02-Gallon Air...
Lenght , Weight, High of Mercedes Benz 709D bus
LENGHT 20 feet
width 7 feet
height 8 feet
weight 6,600kg
max train weight 10,000kg
so can tow max 3,400kg
Jan 03, 2009 | 1994 Mercedes-Benz C-Class
Makita Angle Grinder 7" 6600 Rpm, 15 Amp Logo
81 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
