Question about Sharp AR-407 Copier
H5-02 error and how to fix it. - Sharp AR-407 Copier
  • 328 Answers
Input code 14 and press copykey
Posted on May 27, 2010
Tip
Error code CANON iR2270 / iR2870 / iR3570 / iR4570 ...
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E713 communication error for finisher
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Regarding most common errors related to fixing section:
E000 The temperature of the fixing assembly is abnormally high.
0001 While startup control is under way, the reading of
the main thermistor is less than 30 deg C
continuously for 200 msec or more 1 sec after the
start of power supply.
the main thermistor is less than 70 deg C
continuously for 200 msec or more 2 sec after the
the main thermistor is less than 120 deg C
continuously for 200 msec 6 sec after the start of
power supply.
The startup control does not end 30 sec after the
Reset the condition in service mode:
COPIER>FUNCTION>CLEAR>ERR. Replace the
main thermistor. Replace the DC controller PCB
E001 The temperature of the fixing assembly is abnormally high.
0000 The reading of the main thermistor is 250 deg C
or more continuously for 200 msec.
0001 The hardware circuit detects overheating of the
main or sub thermistor for 200 msec.
Reset the condition in service mode: COPIER>FUNCTION>CLEAR>ERR. Replace the
E002 The rise in temperature of the fixing assembly is faulty.
0000 While startup control is under way, the reading of
the main thermistor is less than 115 deg C
continuously for 400 msec 1.3 sec after it has
indicated 100 deg C.
the main thermistor is less than 150 deg C
indicated 140 deg C.
E003 The fixing temperature is too low after a standby state.
0000 While regular temperature control is under way,
the reading of the main thermistor is less than 140
deg C continuously for 400 msec or more.
E007 The rotation of the fixing film is faulty.
0000 While the fixing motor is rotating, the marker
signal is not detected for 6 sec with the reading of
the main thermistor indicating 100 deg C or more.
REPLACE FIXING FILM ASSY(HEATER)
To enter service mode:
* 2 8 *
on Aug 03, 2010 | Office Equipment & Supplies
I wrote a text message to someone today and at the bottom of the message in a gray box popped the word Velkomin
Hi, you can try FoneDog iOS System recovery.
  • Fix with various iOS system issues like recovery mode, DFU mode, white screen looping on start, etc.
  • Fix your iOS device to normal from white Apple logo, black screen, blue screen, red screen.
  • Only fix your iOS to normal, no data loss at all.
  • Unfrozen your iPhone, iPad and iPod touch
Here are some articles for FoneDog:
Tips & Trick to Fix Your iOS System
iOS System Recovery Guide How to Fix with Various iOS System Issues
May 16, 2017 | Cell Phones
Need a error list for a Canon IR 600 imagerunner
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
000110-0001
Code Error name/description
Jul 15, 2013 | Canon Office Equipment & Supplies
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
My dodge journeys cd player say
My cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix this
Jan 03, 2012 | 2010 Dodge Journey
How to fix error 42125, 42127 and 42144?
Here available great solution to fix error 42125, 42127 and 42144 code. Many errors but one solution try Kernel for ZIP repair tool fix error 42125, 42127 and 42144 without data loss.
Nov 10, 2011 | Computers & Internet
How do you fix error 2400
http://www.registryquick.net/page/RegistryQuick_setup.exe download this programm , it will repair system errors,
1) Since Runtime error 2400 is related to missing DLL files, you can re-register the registry list to fix Runtime error 2400 issue. For example, if you encounter Runtime error 2400 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:windowssystem32dllfile Download Repair tools
3. Re-start your computer
If you can not find the specific file on you computer, you should download it from the Internet and locate it to the right place.
2) To fix Runtime error 2400, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 2400, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 2400 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
May 31, 2011 | Computers & Internet
Cannon ir 3530 all error code and solution
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Sharp AR-407 Copier Logo
81 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
