Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Inner drum seal wvf2402gb/02
Hi, could you please let me know the official name and part number for the seal that goes on the drum under the thick metal band? Not the door seal.
Is it a straight forward job to replace? I have been quoted £85 labour to do the job and £10 - £15 for the part by a local firm.
The washer dryer is a Bosch Classixx Maxx WVF2402GB/02
Thank you, John
  • pmonkey Jan 12, 2009
    the metal band on the drum where the seal connects to is leaking any ideas what part to order and how to fix it?
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch WVF2402GB/02 front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Posted on Jul 23, 2013
Just purchased a seal from 1st Call Appliance (support@ukapplianceparts.com)
£22 inclusive
No instructions for fitting but can't be that difficult - heard that it is a good idea to use the opportunity to clean gunk from around frame before fitting new gasket
Posted on Jun 17, 2008
Samsung wd9652c8w washing machine tub bearing nos?
Hi Purnachandra.
If you intend doing a repair job yourself you probably only need to contact the distributor of Samsung parts and ask for the individual parts by name.
You should also consider replacing the shaft which is attached to the inner drum. This can become damaged and will not give a good seal..
Try Googling your model number for a parts distributor in your area.
Good luck.
Nomess
Apr 02, 2015 | Samsung Washing Machines
How do you take the inner drum out of a Frigidaire front loading washer?
Make sure you have plenty of well-lit space to work as well as lay out the parts removed. Remove the cabinet top by removing several screws from the rear, slide it back somewhat, then lift up. Remove the back panel by removing screws along the top rear, then lift up. Pull loose the rubber boot (it's glued to the cabinet front opening as well as to the outer drum face) CAREFULLY from the front panel opening. After uncoupling the drum motor, wiring, hoses, and suspension components, lift out the entire outer drum assembly. The case splits after removing a handful of bolts from the split circumference. Remove the large drum pulley and any snap-rings holding the large shaft in place. The inner drum should pull out of the rear case, but leave the bearings and seal in the case. The inner bearing and seal are prone to failure over time. The official fix is to replace the rear case (with new seal and bearings) for some 300 to 400 dollars. We chose to replace the bearing and seal from a local bearing supply house for about $16. It's still working well after over 10 years. Assemble in reverse order. Use 3M automotive trim cement for gluing the rubber boot back to the cabinet front. Hope this helps!
Jul 25, 2010 | Frigidaire GLTF1670A Front Load Washer
Replace door seal
its not to easy to do but,,,
look at the bottom of the washer were the door closes the seal is held on with a spring wire,,unhook this wire and fold the seal inside the washer,,look for the inner drum there is another spring wire holding the inner part of the seal to the inner drum undo this as well,, pull old seal out through the door hole,,,now fold new seal so that the inner wire can be fitted round the new seal first to the inner drum,,then pull the new seal through the door hole and fit the outer wire to seal,,,
and then job a good un?,,, not easy a,,well i did tell you this!
Jul 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Drum seal replacement
Hi. You need to remove the two screws located under the lint screen lid. Now take a flat screw driver and pry upward between the top and the front panel. Now you look inside upper corners and you will see two 5?16" screws. Remover them and the front will lift up off the clips at the bottom.
Notice the belt and how it threads through the idler pulley and goes on the drive motor pulley. It can be difficult so look closely.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
May 17, 2009 | Dryers
Brown stains from wash machine
Hi!!! Your tub inner seal is worn off its a seal which protects the inner tub fron the transmission..Need a new tub seal..Good luckk..
Jan 03, 2009 | Washing Machines
Inner drum of my 7 year old washer WFD 2460 rattles on spin and seems unsupported. The rubber surround is intact, is it the only means to support the drum? Thanks. J.Reeve
Hi there!
I would say it is the rear drum bearing which needs replacement. This is what supports the load of the entire drum. The seal is just a water seal.
The good news is that it's a bosch, and replacements are easily available. You are lucky to get 7 years use without problems. Cheaper models give up after 12 months!
Check online for spares under the model number, or have it replacd by a local technician. It is the main drum bearing you need.
If this assists to a solution, Please take a moment to rate as fixya! Thanks.
Jun 18, 2008 | Bosch Washing Machines
Candy drum bearing replacement
Hello
This is fairly straightforward but little hard work to remove and fix. If you have Candy Washing machine such as model CE430 which is fully automatic electro-mechanical with AC motor , the replacement will be as follows that I have done successfully
1. Remove the belt and motor, then remove the hex nut on then drum pulley. But pulley may not come out. It is suggested to remove the hex nut whiled drum on the frame because it is easy to remove while it is on the frame.
2. Take the complete drum assembly out of the washing machine frame.
3. Leave the drum assy on a bench with pulley side upward, use puncher to tap onto the center of the drum spindle, make sure that you will not damage the screw threads on the spindle. the spindle should go down the pulley should pop up.
4. Then keep punching until drum spindle and the “Y” arm assemble comes out.
5. Now you will have the pulley and drum and Y spindle removed. the 2 bearings and water seal still in the drum casing.
6. Use rust cleaner chemical or spray to dissolve the rust off. Then use either bearing puller or use iron puncher to tap on the bearing gently but hard , may use 1kg hammer and take each bearing out. The inner bearing will come out with the water seal.
7. How to get the spare parts; these parts are very common in this geographical region ( Asia). You can buy generic parts. Get the mechanical specifications on the bearing to buy the bearing. The water seal which is generally referred as oil seal, look for specifications such as specs will have inner & outer diameter and the height ( width) ie 22 mm, 40mm and 10mm for water seal of the Candy CE430. Make sure you have the exact shape of the water seal as the original one.
8. Install back the new parts: you need to smoothen the spindle and clean the area as well. to have less friction , smoothen the spindle surface using sand-paper, it will be easy to press the bearing and the spindles.
9. 1st you install the bearings. You need to add thick lubricant in between the inner bearing and inside of the water seal. Then insert the water seal as well.
10. The drum spindle can be inserted to the bearing, you cannot use iron hammer because it will dent the drum, you need to push and may use wooden plank warp with thick cloth like towel to batter on to the center of the drum gently, if the spindle is smoothen properly it should go in with out a hassle. Make sure that drum rotates freely, then pulley can be installed.
11. The drum bearing replacement is completed
12. Re-install the other parts back.
Pub
Jun 12, 2008 | Candy AQW130 Front Load Washer / Dryer
HOBART D 300,SERIAL NR. 94.819 808, ML NR.116 12
hi i work for hobart and these part numbers dont sound right.you have to make sure you have the ml number or spec number to get the correct parts.you can call your local hobart branch and they will help you further.
Oct 21, 2007 | Hobart D300-6036 Mixer
Replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Aug 29, 2007 | Zanussi FJS1225W Front Load Washer
Dropped drum
probable that the bearings have collapsed. remove back panel.undo wiring to heater and stats and make a note of where it goes. remove back plate of the tub assemby held by a clamp right round. drum andback plate then come out complete. take off pulley and put back bolt in shaft. tap bolt and you should be able to knock drum from backplate. you can then check bearings. you will need to replace bearings, lip seal and backplate seal.parts are not too expensive. check also condition of journal lip seal runs on. this must be in good condition.
May 07, 2007 | Siemens WFXD8400UC Front Load Washer
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
383 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
