Question about Maytag 18.9 Cu. Ft. Top-Mount Refrigerator - White
Freezer not defrosting
Buildup of frost
  • Maytag Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorfreezer not defrosting - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 26, 2010
4 Suggested Answers
  • 183 Answers
SOURCE: Frost buildup on ice/water dispenser
Your problem is definatly caused by air entering freezer either from the ice shute flap or door not sealing correctly, try putting a bright torch in frezzer and closing door look for light escaping around edge of door, if you can see the light then change door seal, the fault cannot be anything else. Regards Advisor
Posted on Aug 30, 2007
  • 25 Answers
SOURCE: Freezer not freezing
your defrost timer or defrost heater could be bad,
Posted on May 21, 2009
  • 35 Answers
SOURCE: excessive frost buildup in bottom freezer section of Kenmore refr
In my case, this happens when the drawer does not seal properly. If I am aware of this, I don not have the snow build up. My problem is why the drawer doesn't always close properly, and it is inconsistent. There is no adjustment. Anyway, if the drawer seal is the slightest bit open, snow-like frost will build up in freezer. Mine is a GE pds20mcrbb
Posted on Jul 01, 2009
Testimonial: "Very helpful description and pictures."
I have a whirlpool refrigerator model m#EB9FVBRWS05 and the water leaks from freezer, freezer not defrosting and frost buildup . How do I fix this problem?
There are three main components in a defrost circuit, the heater, the thermostat and the control device(either a timer or and ADC board). One of these are not working.
Dec 24, 2015 | Whirlpool Refrigerators
Defrost not working heavy ice build up around coils
Hi
Frost is a natural occurrence on the evaporator coils in the freezer compartment of your refrigerator. To prevent frost buildup, a self-defrosting refrigerator warms the coils using a defrost heater several times each day to melt away the frost. This frost melts into water and flows out of the compartment through the drain. If any part of the defrost system is not working properly, the result can be heavy frost buildup that may affect the cooling capacity of the refrigerator.
The defrost timer is a mechanism that tells the defroster how long to run to melt the frost. The limit switch measures the temperature in the freezer and helps to maintain it, while the heater is the key element that melts the frost. Any one of these components could need replacement at a given time, which will result in this over-frosting.
Also check this bellow link:-
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
My admiral fridge freezer has suddenly become warm. Freezer is defrosting and fridge is warm. Lights are still on so there is power.
Check your compressor area for lint buildup. Is the fan running down there?aa4623f.jpg Is the compressor running? Both should be running when the control is calling for cool and the inside fan is running. Looks for signs of distress associated with the compressor relay.7842c79.jpg4e4f405.jpg If all of that is good. Look for frost buildup on the freezer wall, a sure sign of a defrost problem. Remove the freezer service panel and look for frost buildup. You could have a bad heat or terminator.644d73c.jpg
Jun 27, 2010 | Refrigerators
Frost Buildup in freezer section
check the defrost heater in the evaporator compartment at the rear of the freezer for continuity,then check your defrost control if the heater is o.k. be it either an adaptive defrost or a timer type defrost control
May 23, 2010 | Viking Professional VCBB363 Bottom Freezer...
Fridge not cold enough and frost buildup in the
Your problem is probably one of the following:
* defrost thermostat
* defrost heater(s)
Contact an appliance service company.
Feb 16, 2010 | Frigidaire Freezers
We have Kenmore side-by-side door refigerator, recently we found a problem with freezer, all the items any type of containers are getting iced in the form of a thin layer.even the sheves and most of the...
1)The door gasket on the freezer door helps keep the cold air in and the warm air out. If the gasket is dirty or damaged, it may prevent the door from closing properly, which can lead to frost buildup on your freezer walls. To make sure the door is sealing, slip a dollar bill or a sheet of paper between the gasket and the freezer and then close the door. If the bill or paper pulls free with little or no resistance, the gasket isn't sealing properly. Wipe the gasket with a damp cloth to remove dirt, grease and other residue. If the gasket is damaged, replace it with a new one. Sometimes frost can accumulate on the back panel of your freezer if the door is open too long or too often. When you open the door, you let warm, humid air inside, and this condenses and freezes. Make sure there are no packages preventing the door from fully closing, and limit how often you open the door by removing what you need all at once.
2)Ventilation is important because it ensures your freezer stays cold. If something inside the freezer blocks the internal vents, the freezer may become warm, causing condensation to form on the walls, and eventually leading to frost buildup. When loading your freezer, make sure there are no items resting against the rear wall of the freezer and space the contents out as much as possible to improve ventilation.
3)Side-by-side refrigerators with a built-in ice maker may accumulate frost if the flap on the ice dispenser doesn't close properly. This allows warm air to enter the freezer side, condense and freeze, causing frost buildup over time. Open the freezer door and examine the flap inside the ice chute. It should be flush against the housing. If it is not, empty the ice bin and make sure there is no ice or debris preventing the flap from closing.
4)If your freezer door closes properly and nothing is keeping it open, frost buildup on the back panel may indicate a problem with the freezer's self-defrost system. The self-defrost system turns off the compressor for a short time every six to 12 hours so it can turn on the defrost heater. This melts any frost buildup on the freezer coils, and the water drains to the pan beneath the freezer. If this component fails, frost continues to build. Move the contents to another freezer and turn your freezer off for 24 to 48 hours to manually defrost the interior. If frost builds up again, contact a qualified appliance repair technician to inspect the defrost timer and repair the problem.
Oct 29, 2017 | Whirlpool GR9FHMXP Top Freezer...
I have a PFS22MISBBB. refrigerator registers 60 degrees (set at 38) and freezer is 25 (set at 0).Talked to a repairman who advised me to be sure there isn't any dirt buildup around the coils; then added to...
The repairman is correct. If the coils are clean the next check would be to see if there is any frost buildup in the freezer section. If there is it's not defrosting. The common causes for that is a bad defrost timer, defrost heater or a defrost thermostat. Another test is to unplug the refrigerator and open the doors for 24-36 hrs. to melt everything. When you plug it back in it will run at the right temp for a few days until it builds back up with frost.
Aug 24, 2009 | Refrigerators
Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Jul 13, 2009 | Amana 19.6 cu. ft. / 555 liter Upright...
The fridge section of my LG GRB218JUDA has stopped working and the temperature indicator reads Err FF. Can you help
Side by side and other refrigerators are controlled or cooled by one system. Look to the freezer side for frost buildup on the back wall of the freezer. Frost buildup on the back wall of the freezer stops the air that cools the refrigerator from circulating. Frost on the back wall indicates a problem in the defrost circuit related to the timing device, heaters or defrost thermostat.
Jun 02, 2008 | LG Refrigerators
Maytag 18.9 Cu. Ft. Top-Mount Refrigerator - White Logo
100 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
