Question about GPS
I deleted the gps flash memory and now my computer does not recognize it.
    President:
  • 524 Answers
Hello Mauricio,
First of all what is the model number of your GPS and the company name. if you had map and firmware in the GPS and you deleted that you will be able to recover all that just have to download new maps and firmware. Then drivers for your computer and you will be good to go
But in order to further assist you i need these information.
Thanks.
Posted on May 25, 2010
  • 1 more comment
  • mauricio449 May 25, 2010
    It's the Magellan RoadMate1220.
    Thanks.
  • CIROC TECH SUPPORT
    CIROC TECH SUPPORT May 25, 2010
    Hello Mauricio,
    Here's the link where you can buy maps for your GPS rather i would suggest you to call cutomer support and ask the company for the free map since it got deleted by mistake.
    Please let me know how that goes.
    Thanks.
    Or the whole new nevigation with MAP for the same price
    http://www.amazon.com/Magellan-RoadMate-...
How do I delete files on SD card
Connect your device to a computer, it should be recognized as a Removasble disk. Open folders and delete files you want to delete.
Depending on device you are using, you might need a driver fro your Operating system to get your card reconized
May 12, 2015 | SanDisk Electronics - Others
Lexar Echo MX not being recognized
Try this: Go to Start, right click on My Computer, select manage. In the left pane click device manager, scroll to Universal Serial Bus Controllers. Delete all of them. System may not allow some to delete, thats fine just delete all that it will allow. Then leave your usb connected to the PC and reboot. OS will reinstall all usb drivers on its own, and it may then see your stick.
Jun 11, 2014 | Lexar Electronics - Others
How to delete video and music on a pny 4g flash drive
Plug the USB flash drive into a USB port on your computer. An Explorer window will popup once it's recognized by Windows.
Click on the file you want to delete so it's highlighted. Right click and choose delete. It's that simple.
Dec 06, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Disk needed for GPS updates
Make sure you have the little tab on the left of the card in the right postion. Try it both ways.
Sep 17, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
May 31, 2009 | Dell Inspiron 6400 Notebook
My computer not recognized the USB Flash memory, but it recognized other device like the mouse, webcam scanner, digital camera ... Thanks for your help
if usb flash memory is working on other computer/laptop then do the following step.
Insert the usb flash memory.
Goto desktop, right-click my Computer, click Properties, click on Harware tab, click Device Manager button.
There should be yellow exclamation(!) sign showing Unknown Device
Right-click and select UnInstall.
Reboot your laptop
It should work.
May 30, 2009 | Dell Inspiron 6400 Notebook
My Garmin 660 will no longer plot a destination...
Have you loaded a lot of JPGs or MP3s on the internal memory? If so, you have reduced the amount of memory available to the 660's OS. Not sure if the 660 stores calculated routes directly to the internal flash memory, but it is very likely, since it keeps your route when you power it down.
To unload the internal memory, consider buying an SD card - they are cheap right now. As a matter of fact, I just ordered an 8GB SD card for my 660 from Amazon for $13. The 4GB and 2GB cards are available for about $7 and $3 respectively. Drrrrrt cheap!
You can access the internal memory of the 660 on your computer with the USB cable you got with the 660. The two folders to focus on are the JPEG and MP3 folders. Simply copy these folders' contents to the root directory of the SD card, and then go into each folder in the GPS memory and delete the MP3s and JPEGs you added - should work better. The 660 will recognize the files on the card if left in folders named identically to the folders in the internal memory.
If you didn't add any content to the internal memory, that is a different issue altogether, probably something to discuss with Garmin. Could be as simple as upgrading the firmware. Make sure you select the correct version though, or it could be a fancy brick! Go here for the nuvi 660:
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=164&pID=31946
Good luck, and I hope this helped!
Jan 05, 2009 | Garmin Nuvi 660 GPS Receiver
Pny usb 2.0 flash drive memory stick
windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
May 27, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
Oct 27, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
GPS Logo
27 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
