Question about Tecnik TKR6620 Bottom Freezer Refrigerator
Fitted fridge not correct temperature
Fitted fridge (top half of fridge freezer) will not reach correct temperature - i.e. thermometer registers above 0 although fridge is set to highest level (7). Drops of condensation of the back wall of fridge freeze and then melt - but (two) thermometers show that fridge is too warm. Thermostat appears to be working (can here it cut out when turned from '7' to '4') and can hear motor etc. Have checked nothing is blocked (e.g. drain hole) and door is closing properly. Problem has been ongoing for one week. Freezer working OK.
Is it worth repairing or should we look for replacement?
2 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: Fridge freezer installed 3 weeks
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Nov 02, 2010
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
I have just purchased the above unit and has been plugged in now for 24hrs with no food, the high humidity warning sign Is illuminated constantly Is this correct?? Also I have yet to witness the operation...
You didn't include a manufacturer or model, so I can only offer general help with your problem. If you choose to provide this info later, you may get better, more specific help. The freezer compartment contains the cooling coil for the freezer and fresh food compartments. This fan in many fridges are not visible - but yours may be. Yours may also have circulation fans specifically for moving air around the fresh food compartment.
Generally, the coil is located in a protected area of the freezer (behind the back panel). The fan is arranged to pull air from the freezer floor through the coil to be cooled and blown out the top of the freezer compartment. Openings between the freezer and fresh food compartment allows a portion of the cold air to be blown into the fresh food compartment.
The first thing to do is to see what the temperatures are in both compartments. The fresh food should be about 36 degrees and freezer -10 to 0 degrees Fahrenheit. Place a glass thermometer (capable of displaying 32 degrees and up) in a glass filled with cold tap water, and place in the fresh food compartment. Place another thermometer in the freezer (capable of reading -10 and up). You can also use thermometers designed for fridge / freezer temperatures if you wish.
If there is nothing in the fridge and the door remains shut, the temperature should be seen in an hour or so. If the temperature range is obtainable, it is not likely that there is a humid condition INSIDE the fridge. You may have moisture collecting on the OUTSIDE of the fridge near doors, etc. If so, locate a humidity switch and turn it on. Many manufacturers provide this switch to turn on electric heaters in the outer part of the fridge cabinet where moisture tends to form in humid climates. These heaters operate to evaporate the moisture on the cabinet and usually come on when the freezer defrost circuit is on.
May 16, 2011 | Refrigerators
My fridge does not seem cold. Temperature in freezer is fine.
The cooler side is serviced by blower vents in the back top and bottom of the refridgerator. In some the lower portion has a movable vane blocker so that you can adjust the "meat keeper" colder. Check to see if those air inlets are being blocked by jars etc. The thermostat operates the blower, so you will have to check if your thermostat is working. you can use a thermometer and set your thermostat up or down and see if the difference is registered on the thermometer. a room thermometer will do nicely. This will check to see if your thermostat is fairly correct.
Feb 04, 2011 | Samsung RS2534 Side by Side Refrigerator
I am just trying to find out what are the recommended settings for a 8.8 cu. ft. energy star rated Frigidaire chest freezer.
I would suggest getting a fridge/freezer thermometer and use that to set the temperature. They are marked with the recommended temperatures. Also many times the setting on the nob in the freezer are not very consistent so it is better to actually set the temperature by turning the knob up or down to reach the desired temp on the thermometer
Sep 18, 2010 | Frigidaire Freezer 8.8 cu. ft. Chest...
I am having LG GR-B352 YC , what is the best temperature that i can keep initially and future??
Generic instructions to set temperatures in fridges:
Many manufacturers design these appliances to operate at 0 degrees F in the freezer and 34 to 36 degrees F in the fresh food compartment.
To set the temperature correctly, fill a glass with water (8 to 12 ounces) and place a thermometer capable of indicating 32 degrees and up into the glass with water (if the temperature goes below 32 degrees, the water will freeze - so no need to find a thermometer that indicates any lower). Place the glass with the thermometer in it on a shelf and wait. Putting the thermometer in a glass of water helps preserve the temperature reading while the door is open. You can skip the water and glass if you want - but you'll need to read the temperature as soon as you open the door.
The freezer will require a thermometer capable of displaying 0 degrees F. Place it on a shelf where it can be seen readily - but preferably in the rear - between items (to prevent the warm air from driving the indicator up when opening the door to read it).
It will probably be easier to set the freezer temperature first. Adjust both the freezer and fresh food thermostats to mid-points (if the fridge is empty - otherwise skip this step). Adjust the freezer thermostat up or down as needed to reach the desired 0 degree F temperature.
Once the freezer adjustments are complete, adjust the fresh food compartment thermostat as needed up or down to reach the desired temperature for it.
If you fridge is fully stocked, it may take some time for the temperature to stabilize and warm / cool the fridge's contents completely. This is further affected by how often the door(s) are opened and for how long. 24 hours is often claimed - but you might be able to sneak an 8 - 12 hour soak before reading the thermometers.
After the temperatures are set, you may find that the lower part of the fresh food area is partially freezing - simply adjust the thermometer up *slightly* as needed.
Please rate this reply if it was helpful - good luck!
Aug 11, 2010 | Refrigerators
Zanussi fridge freezer alarm keeps sounding
If the refrigerator and freezer are both working properly. Then the only problem would be the alarm, It's either the placement of the alarm thermometer or the alarm thermometer is stuck closed.
Mar 15, 2010 | Freezers
Salad in salad tray keeps freezing
contact the people who made the frig, sounds like a service call might be needed. you are paying for food that is destroyed, the service guy may save you money in the long run.
Oct 03, 2017 | Refrigerators
Overheating condensors
Bad compressor. Anytime a compressor on anything gets to hot to touch that is a sign that the piston is applying to much pressure to work which in return causes the compressor to go bad if not caught right awya
Jun 03, 2009 | Sub-Zero 690 Side by Side Refrigerator
Freezing all veggs in fridge
The temperature in the fridge should be from 32-40 degrees. Go buy a little fridge thermometer and place it in there. They are cheap and you can pick one up many places. I leave mine in year round. Then adjust your settings accordingly. Don't do anything drastic adjust, then check in twenty-four hours then readjust if necessary to reach the proper temperature. No visible frost inside the unit anywhere right?
May 21, 2009 | Amana ATB2135HR Top Freezer Refrigerator
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Tecnik TKR6620 Bottom Freezer Refrigerator Logo
57 people viewed this question
Top Tecnik Refrigerators Experts
Charles T Nevin
Charles T Nevin
richie46
ray gallant
Are you a Tecnik Refrigerator Expert? Answer questions, earn points and help others
