Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Troy bilt 5550 generator no start please help
I have a troy bilt 5550 generator. my problem is that it was running fine and it ran out of gas i filled it back up to restart it and it never started back again. i have tore down carb and cleaned twice replaced spark plug checked for fire checked compression still no start any help would be thanked upon.
  • 144 Answers
Fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
Posted on May 26, 2010
Testimonial: "thanks for the great help i did try fresh fuel and drained the carb bowl but still same prob its a head scratcher i really thank you for your input."
  • William Robinson
    William Robinson Aug 14, 2010
    Did you have a spark? And was there fuel in the bowl when you "drained" it? Did it start with the shot of ether or other spray? I'm still thinking it is related to the carb. When you tore it apart, did you clean out the jets, all the gaskets in good shape etc? Let me know and hopefully we can get this running for you.
    New Friend:
Briggs and Stratton is a questionable generator brand. For some reason, many people believe their generators are imported lower quality Chinese brand.
I linked a page the provides reviews and a little history about the Briggs and Stratton brand.
Briggs and Stratton Generator Reviews
Posted on Oct 01, 2016
Same generator same problem there is a small black wire that is connected to the on/off switch to the coil, mine rubbed through from vibration and tuching the flywheel , i replaced it and it runs like new, check for spark first, if you have spark replace your spark plug ,check comperssion , mabye your valve is stuck on, a seal once told me be persistant , you will prevail,
Posted on May 28, 2011
Troy bilt generator
pull the carby down and clean out the corrosion blocking the main jet
Jun 07, 2017 | Electrical Supplies
Troy bilt 5550 generator has no spark
you can clean the fly wheel where the magnets are an see if that helps . you might need a NEW mag.
Mar 30, 2013 | Briggs & Stratton Power Products 5,550...
My troy-bilt 5550 started yesterday - won't today
check oil levels look for any obstructions around blades watch your hands
Aug 28, 2012 | Cars & Trucks
What engine oil is used for a model 01919, 5550 watt Troy-bilt genertor?
The generator engine is shipped from the factory filled with
oil (API SJ or higher 10W-30). This allows for generator
operation in the widest range of temperature and climate
conditions. Before starting the engine, check oil level and
ensure that engine is serviced as described in Maintenance.
This is from toy bilt manual >Good Luck...
Aug 31, 2011 | Troy-Bilt Garden
I have a Troy weekwacker, and after sitting this winter, it WILL not stay running. The only way to even get it to start is to load the thing with starting fluid, and then it only runs til it eats up all...
Have you changed the spark plug on this unit? If all else has failed, this is more then likely the problem. Please let me no if it takes care of the problem.
Sincerely, Shastalaker7
Apr 14, 2010 | Troy Bilt Tb70ss Gas Trimmer
pull plug and try to pull start if moves than it was vapor locked clean plug and try to start if no movement with plug out than internal engine or pull cord jammed
Mar 03, 2010 | Troy-Bilt® Briggs and Stratton Chipper
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-Bilt® Briggs and Stratton Chipper
My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Mar 29, 2009 | Electrical Supplies
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
3,485 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
