Question about Toro 13" Corded Trimmer - 51358
How to reload the line on the toro trimmer #106 6016
2 Suggested Answers
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
How far in the gas tank does a toro trimmer fuel line need to go -- I assume not very far and not as far down as the filtered gas line, correct?
The gas line with the weighted fuel filter on it should lay across the bottom of it (somewhere near the opposite side) and the purge/return line only needs to enter the fuel tank 1/2" to3/4" to work.
Sep 11, 2011 | Toro Electric Trimmer
How do I replace the line in an 11 inch electric toro trimmer I can't turn the part that would come off to put new line in.
All I can do is refer you to the manufacturer's instructions. See page 5 after downloading your user manual. If you can not turn the cap off, then the cap is possibly cross threaded onto the shaft end and/or the threaded end if the driveshaft is stripped. See if the user instructions are of help to you.
http://www.toro.com/en-us/Homeowner/Yard-Tools/Trimmers/Pages/Model.aspx?pid=51347-11-Inch-Electric-Trimmer
Jun 08, 2011 | Toro& Electric String Trimmer
What size string does the 910 toro electric trimmer take
12' .050 trimmer line, like that shown at the link below
http://www.google.com/url?sa=t&source=productsearch&cd=1&ved=0CFkQgwgwAA&url=http%3A%2F%2Fwww.amazon.com%2FToro-88075-12-050-Trimmer-Line%2Fdp%2FB0000CBITQ&rct=j&q=910%20toro%20line&tbm=shop&ei=h2HNTd7aCunc0QGq_aDgDQ&usg=AFQjCNF826-xPNQy9XomBFrklrqkvIHGCQ&cad=rja&biw=1280&bih=630
May 13, 2011 | Toro& Electric String Trimmer
I cannot get more line out of my toro 15" electric trimmer. It cannot be empty, it has only been used once. The cutting line will not extend out any more. Should it not?
Sometimes the line can become fused together.remove the spindle and manually pull the line. Replace and the tap and feed should work fine.
May 12, 2011 | Toro& Electric String Trimmer
I have an electric 13"
you can try a smaller string size, this should help. Tim
Apr 24, 2011 | Toro& Electric String Trimmer
What causes a 2 stroke engine to have too much compression and therefore difficult to pull the recoil starter?
Nothing will do this...what is most likely the problem is either the recoil is going bad or you have the wrong spark plug installed.
Dec 03, 2009 | Toro& Electric String Trimmer
Jun 03, 2009 | Toro Electric Trimmer
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
May 26, 2009 | Toro Electric Trimmer
Toro 13" Corded Trimmer - 51358 Logo
366 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
