Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG Tromm will not turn on.
Power is getting to machine.
Breakers working properly at breaker box.
Machine is not responding.
Is there a reset button or combination on the Machine.
It is a front loading machine.
  • 5 Answers
I have put mine on a surge protector. It is a computer after all. It is hard to say whether or not you have suffered damage to the motherboard. Trial and error testing to see if you have power at your outlet. Hopefully you can repower and all will be well.
Posted on May 30, 2010
LG Tromm Washing Machine no power unless I unplug it and reset it.
See if you can lift the top of the washer by unscrewing it from the back and you should find a code and test sheet in there. Very easy to follow and run the test.
Jan 02, 2016 | LG Washing Machines
My dryer is an lg tromm dle7177rm. it is 220v. it has ran fine for 3 years but now trips the breaker within 5 min.
If your breakers are old. I'll start by replacing the breaker to the dryer at the box. It is a common failure. Breakers wear out to. Check the power cord for any burnt markings and look at the outlet as well for burnt or discolor contacts. This will overheat as well causing the breaker to exceed the limit and trip it.
Nov 05, 2015 | LG Dryers
LG WM3455H won't turn on.
Unplugging to reset only works when the washer has power and on stand by. Start by checking the fuse on the noise filter, that is were the power cord connects to. If good than your main board is bad.
Apr 06, 2014 | LG Front Load Washer / Dryer Combo...
LG TROMM WM2233HS won't start
Obviously I switched the breaker wrong. We switched the breaker again and it worked.
Apr 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The on off switch is pushed in and won't respond
check all fuses and circuit breakers to make sure there is ample power
Jan 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG tromm electric dryer not heating up
Most likely you have a bad electrical connection, resulting in only 120 volts to dryer. (enough to run the 120 volt motor, but not enough to power the 240 volt heating elements) Turn off breaker. Make sure wires on breaker are tight. Make sure nutral wire is tight in breaker box. Take cover off dryer recepticle and check the wires in it to make sure they are all tight. Check that the connections of the cord at the dryer are tight.
Nov 04, 2008 | Whirlpool GGW3878J Dryer
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
WASHER will not respond or Turn ON
Lg wash machine do not normally have fuses. 90%chance the board is blown. Trace the power to the board. if there is power, boarb is faulty. there should always be am indicating light of a sort when power is applied even if you had other problems.
Apr 09, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
471 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
