Question about Zyxel Prestige 660M (P-660M-61) (91004397010)
Cannot connect to Internet
Have changed my internet password and since then cannot access the internet have contacted my ISP for help but nothing seems to work, have used 1234 to connect but will not do anything, the Internet light is not showing on the modem.
Any help you can give would be much appreciated
Hi
Looks like there is a problem with the modem, you can either connect through bridge mode or replace the modem from your ISP.
If u are still not able to connect then u have to check the loop length from the CO. if it is a dedicated loop then there is a problem with the line........
Posted on Jan 17, 2009
If the default password does not work for accessing the modem's setup page you will have to manually reset the modem using a toothpick or paperclip on the reset button in the back of the modem. Hold the button down for about 10 seconds and the power light will flash.
However if the Internet light does not light up on the modem then the ISP needs to do something to fix the connection.
Posted on Apr 19, 2008
  • 123 Answers
Janig,
try to reset ur router or modem..
Posted on Apr 07, 2008
How do i connect to the internet i changed me service?
hi Inga.
see if this helps you out.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections. If your DSL or cable modem is always connected and your ISP does not require a user name and password, you do not need to run the New Connection Wizard.
How do you get access to the Internet? Internet Service Providers (ISPs) If you want to access the internet at home, you'll need an Internet Service Provider (ISP) and a router to connect to the ISP. ISPs often provide a router with their service. This means more than one computer or device in your house can use the broadband connection at the same time.
you could also go to this link and its a step by step way of finding out how to connect tp the internet,
How to connect to the internet
Nov 19, 2017 | Internet Computers & Internet
Acer Aspire willnot take WLAN password
that is a password for you ISP(internet service provider) not your computer. You need to setup a connection through your computer with your ISP to get internet access. best bet would be to contact your ISP and they could walk you through it.
Jan 31, 2013 | Acer Aspire V3-771G-6851 - 17.3" - Core i5...
I cannot reset my password
Im presuming its your internet connection password ?
Your Internet service provider (ISP) requires a username and password to access service features, including Internet and email.
Your ISP should provide this information when you set up your Internet service.
Typically, once you complete the setup and save the information, your router or modem transmits it behind the scenes when you try to access the Internet.
As a result, the username and password can be easily forgotten because they are not used daily.
If you reset your router or simply forget the password, gaining access to network resources and the Internet becomes a challenge.
Call your ISP's technical support department.
Many ISPs set a default username and password for their routers.
If you didn't change the username and password, your ISP can provide the original information.
Before you hang up, make sure the information is correct by entering it and trying to connect to the Internet.
If the information is incorrect and you still cannot get a connection, keep the information for later reference.
Call your router's manufacturer.
The manufacturer of your router sets a username and password prior to shipping the device to your ISP.
Look at the router for the contact information of the manufacturer.
Call their customer service or technical support department and ask for the default information.
Reset your router.
If you changed your router's username and password and cannot remember what you entered, you may have to reset the router.
Insert the resource CD into your computer's CD drive.
When the software installation program starts, search the screen for "Resources" or "Documentation" or "User Manual."
Click the documentation link and search the table of contents for resetting the router.
When you reset the router, the username and password return to the default set by your ISP or manufacturer.
Enter the information provided by your ISP or manufacturer.
Hope this helps.
Nov 15, 2012 | Computers & Internet
I was trying to change the security pass phrase on my modem with the system settings online. It looked like it was in the process of making the change and now I cannot connect wirelessly.also the wep is...
when you configure the modem there are two types user name and passwords you give,
first user-name name and password are for opening modem configuration, once you in,
there are also username and password there and it is providede by your ISP (Internet Service Provider)
once you change it you will not able to connect to the internet.
if you don't mind i suggest you to contact ISP soon as possible.
Jan 15, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
All the lights on my Westell Model 6100 are green except the internet light is red. What does that mean? Thank you!
The reason why your internet light is red for the westell model 6100 is because it is not yet configure. You need to access the gui of this modem. Enter the username and password for your internet connection. You will get the username and password from your ISP. You can contact your ISP provider so they can walk you through for the steps on how to configure your new router.
Apr 06, 2010 | Westell Wirespeed LiteLine 6100...
Cannot connect to internet. router modem and globe lights blinking amber.
If the modem light is blinking it means that there is activity, so this is normal.
However, the globe/internet light needs to be solid green. If it is blinking it means it is attempting to connect to the internet.
Make sure first that the internet connection is working when directly connected to the modem. If yes, then the router might not be configured properly. To check the configuration on the router, access the setup page by using a web browser. Type 192.168.2.1 in the address bar.
By default the password should be left empty.
Once in the setup page of the router, go to Internet WAN. Select the connection that your ISP is using. Either, PPPOE (requires a username and password from ISP) or Dynamic, (the settings are obtained automatically from the ISP). If you are not sure, contact your ISP.
I hope this helps!
Mar 01, 2010 | Belkin (F5D5231-4) Router
Lost vpi and vci settings, do i need to contact isp for this or not?
Well normally, you need not contact ISP as the router will pick it up automatically. If it does not then you need to contact your ISP to get the values. Perform the below steps to configure the router:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).  2. Connect the computer to the router using any one of the 4 available ports.  3. Open the browser(Internet Explorer or Mozilla Firefox).  4. Access the router (usually http://192.168.0.1).  5. Login to the router (Username = admin Password = password unless you have changed it).  6. Click 'setup wizard'(at the top of list) from left menu.  7. Select yes and click next.  8. It should give you a "PPPoA Detected" and then click next.  9. Enter the login and Password of ISP click apply.  10. Once the settings are updated click on 'router Status' and click on 'connection status' button(at the bottom of the page).  11. Click on connect button.  12. Connecting to server should show 'connected'.  13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.  14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards Anand
Feb 16, 2010 | NetGear DG834G Router
I am trying to connect my HP Pavillion dv600 to the internet using a wired connection and i cant, please help!
Make sure the computer is connected to any port from 1 - 4 on the router.
The modem should be connected to the WAN/Internet port of the router.
On your computer, access the setup page by using a web browser. In the address bar, type 192.168.1.1.
Leave the username blank and then the password is admin.
The settings on the router differs depending on your ISP.
If you have cable connection, the Internet connection type should be Automatic configuration or Obtain IP address automatically (DHCP).
If you have DSL connection, usually the internet connection type is PPPoE. You will need to enter the username and password provided by your ISP.
If you are not sure of your connection type, contact your ISP.
Hope this helps!
Nov 19, 2009 | Linksys (WRT54GC) Router
Connecting a 3com hl-542 to my new broadband provider
please change the DNS ip as your new ISP given.
Jun 09, 2009 | 3Com OfficeConnect Router
Can not connect to the internet in trying to setup the router.
Yes time warner is a cable connection and they dont require a username and pasword. You can set up the router manually by accessing its set up page. By default the router's IP is 192.168.2.1. Make sure to set the wan connection type to dynamic, change the wan mac address or clone your pc's mac. Then save the settings. Check your internet connection.
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Zyxel Prestige 660M (P-660M-61) (91004397010) Logo
682 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
