Question about Maax Crescendo - 100085-000 Bathtub
I have a jet that is tipped way down and not good pressure. Can I just manually adjust the direction? How do I adjust the pressure? I am worried as this is the first jetted tub we have owned and I don't want to have break something and have a leak.
  • Maax Master
  • 717 Answers
Yes you should be able to adjust the eyeball. Simply grab it with your fingers and move it where you want it to be. Some jet trim are adjustable from the outside face of the jet. take a hold of the outside of the trim and turn it both directions until you feel more water pressure come out. this means the jet is open.
Posted on Sep 06, 2010
Burners on tankless Paloma PH-12m-Dn don't burn hot enough to heat the water
Check the flame color when it's on. Blue tips are correct. If the tip is orange or any other color but blue, the air mixture is out of adjustment. Check the owners manual for instructions on making this adjustment
Nov 19, 2014 | Water Water Heaters
How does a home well water system work?
Deep well.
Pressure valve located on front of above-ground-storage-tank will turn pump on-off depending on amount of water pressure inside tank.
When water is consumed inside home, the pressure valve responds to the lower pressure and closes electrical contacts... sending electricity to water well pump located deep underground.
The pump turns on and lifts water through a pipe into the above ground storage tank.
When the tank is full of water, the pressure valve senses the higher pressure and turns off electricity going to pump
Pump shuts off.
There is a one-way check valve on the water line going down to pump, and this keeps water from flowing back down into well.
The above ground tank maintains water pressure for the house.
When pressure is reduced by taking a shower, the pressure valve turns pump on again, and cycle repeats.
Aug 20, 2014 | Water Heaters
Wickes 102 combi boiler constantly loosing water pressure
It sounds like your thermostat could be the problem. Have you noticed the boiler cutting off at all, or does it run continuously until it goes out on low water?
You stated, "when boiler is on", so I am wondering how you get the boiler on. If your boiler is controlled by a thermostat, you need to check it for a cold draft possibly from behind the thermostat in the wall where the wires come through. The thermostat should never be on an outside wall. The thermostat could be defective.
An aquastat can also control your boiler. If you have an aquastat, check the setting, typically 175 - 180 degrees. You should also have a "high limit" which should be set at 210 - 220. Some people run that high side limit higher; not a good idea - defeats the purpose. If the aquastat is set too high, the boiler will operate too hot and the problem you have will occur.
"pressure rises and pressure relief valve opens" This could mean that your pressure switch is prematurely venting. Check boiler temperature to see exactly at what temperature the T&P valve purges. If it blows off below the high side setting, either adjust or replace. The T&P valves are usually not adjustable. That blow off temperature is stamped on the head of the valve. So, if it discharges too soon, replace it.
Have you actually seen evidence thgat the T&P valve is opening? You may have a bad bladder in your expansion tank and your system may have air in it. Your boiler should have 12 psi when cold and 20 - 22 psi when operating. Check your boiler pressure guage.
this eventually drops below the minimum operating pressure" Technically, there is set point for a NO MINIMUM OPERATING PRESSURE. That is a function of the amount of water in the boiler. If the T&P is blowing off, it will vent water from the boiler and the boiler pressure will go down. There is a minimum operating TEMPERATURE.
Your boiler could be low on water. You will have to manually fill the boiler. Be careful of thermal shock to the boiler. Feel the piping, and fill only when the circulator is running. Make sure the water is not going directly into the boiler. The supply water should go into the circulating supply side which feeds the radiators, radiant floor, or base board circuits.
All this will adversely affect your hot water. The heat exchanger for the potable hot water may have scale build up in it. Using the hot water keeps the boiler running, and a scaled heat exchanger will give you cooler hot water and the boiler keeps running. If this is a problem, you will need to replace the heat exchanger. A better idea is to not use the boiler for your domestic hot water. Why run the boiler in the summer?
Feb 02, 2013 | Water Heaters
No hot water code 11 keeps coming on had system for 5 years
Before calling service technician, open following link for error codes, Rheem chat, and possible manual:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Error codes are considered start-point for troubleshooting.
Error 11 is 'no ignition'
Without ignition, the burner will not turn on and heat water.
This problem can be caused by low gas pressure, air in gas line, defective tankless parts such as gas solenoid, loose electrical connections, improper electrical grounding, bad igniter, etc.
Problem can also be caused by combination of problems.
Good news is that error code shows 1 code and not multiple error codes that can indicate larger failure including PC board.
Each tankless instruction manual recommends yearly maintenance where technician will clean burner parts, bleed gas line, check gas pressure, check air and venting, etc.
Yearly service covers the cause for most common error codes.
Aug 07, 2011 | Rheem RTG-66DVN Direct Vent Natural Gas
Hot water went off
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 21, 2010 | RELIANCE ELECTRIC WATER HEATER
My Rheem 40 gal. LPG water heater has sat for two years. When I attempt to light the pilot manually, it goes out after I release the push button valve knob?
The pilots have to warm up, hold that button down for a min, then let it go, it should stay on. Then crank up the pressure, it should light. If you are worried about it, call your gas man, he will check it out. Hope this helps.
Mar 31, 2010 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
Wont light
Is there a spark? or do you need a long match? The button usually just opens the pilot so it can be lit. If its not electronic.
Jun 19, 2009 | Pilot Pen Pilot Ignition Gas Water Heater,...
One of the burner jets on my bosch 125bo unit is yellow (vs. blue) so I assume I have something clogging it, how do I get at it? Is there a repair manual for these units?
they make a long stem wire brush for this,, you will need to go to a plumbing supply house to get one turn it on and gently rub it over the burner make sure it is lit so the pressure from the gas will blow out what is there good luck
Jan 14, 2009 | Bosch AquaStar 125BO-NG 125BO Outdoor...
Maax Crescendo - 100085-000 Bathtub Logo
75 people viewed this question
Top Maax Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Maax Water Heater Expert? Answer questions, earn points and help others
