Question about Dirt Devil Easy Steamer Upright Wet/Dry Vacuum
Where does hot water go, and cleaner go?
Not sure where hot water and clearer go.
  • 276 Answers
Check your model number.
From the Dirt Devil Website http://www.dirtdevil.com/products/details.aspx?id=MCE7000 on the right hand side is a User Manual link.
You can also find other user manuals for other models.
Posted on May 26, 2010
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
My Bissell carpet shampooer will not dispense water or cleaning solution, nor is the "flow indicator" spinning
most of the Bissell carpet cleaners that have the water heating feature stop pumping water at one time or another. Make sure the belt is still on the pump and if it is then the problem is probably in the heater core in the handle. Hard water deposits plug the tiny little water ways inside the heater core. Pull the heater core and take it apart and clean it with a strong scrub brush and I think vinegar works for cleaning I was told. I just use soap and a brush. Then flush all your lines with hot water. The cause is from hard water deposits or leaving the soap in the cleaner after you use it. Both will stop it from pumping water
Apr 29, 2014 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
Just need instruction on how to use
fill the solution reservoir in the back and on the bottom choose your desired setting, make sure the rubber clean water bladder is full of hot water and turn on. pull trigger and slowly move forward and backwards. Happy cleaning .Steve
Jun 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water not dispensing
Check the release valve on bottom of clean water reservoir unscrew if needed, once again if your not sure run hot water in the solution tank through the system to help remove old soap residue and always run hot water through to prevent future problems after cleaning carpet and storing.steve
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
Pro heat carpet cleaner will not pump solution to either cleaner head...sometimes, at first, pump will work for about 1 minute or so...tried re-seating the tank, but no good...what should I check?
The very best thing to do is to fill the dispenser tank with hot water....just plain hot water. Take it outside on concrete, so you can see what you're doing, and operate the cleaner heads. Alternate back and forth. What's happened is that the machine has set with solution residue in it, and it is stopping it up. The hot water will eventually dissolve the goo, and the machine will start working properly. It may take more than one tankful of hot water, but one will probably do the trick. To keep this from happening again, run another tank of hot water after you've finished. I do it on my carpet after shampooing, and it has the added bonus of vleaning the pickup side as well!
Best regards, --W/D-- please feel free to rate this solution....thanx!
Aug 01, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Sep 01, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Steam cleaner
Most upright steam cleaners like Hoover and Bissell, you put in the hot water, bissell does have a heater, but it only helps get the hot water a alittle hotter. But a model number would help.
Dec 12, 2007 | Vapor PC2200 Ladybug Steam Vacuum
Dirt Devil Easy Steamer Upright Wet/Dry Vacuum Logo
317 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
