Question about Campbell Hausfeld Tools & Hardware - Others
I have and OLD bench 1
I have and OLD craftsman bench 1'' belt sander/8 with and 8 inch disk sander. I'm looking for new brushes for the motor. Sander model # 361.226110
Moter model # 113.12970 1/2 HP 1725 rpm
  • 2,100 Answers
The local hardware store has brushes in all different sizes in a box, next to the switches, fuses, plugs, cords, tool type stuff. They are standard sizes, should be able to find them no problem. Hope this helps.
Posted on May 25, 2010
Testimonial: "Thank you for your help, now all I need to find is my manuel to break it down."
How do I get the wheels to pop back out after changing the sanding belt on my old craftsman belt sander #31511720 model?
The tracking adjuster will tilt one wheel in so's you can start putting the belt on. After it gets about halfway, you will need to adjust that the other way and just bump the switch a bit a few times as you adjust and it'll work its way back on.
Feb 03, 2015 | Craftsman 3 x 21 in. Belt Sander, 8 amp
How to clean a clogged belt sander
I assume you mean you want to clean the belt itself? You can use a rubber stick made for this. It looks and smells like a giant pencil eraser, about 1 inch square and about 10 inches long. However, if the belt is clogged with melted paint, that won't do much - but a stiff wire brush works OK. If the wire brush doesn't work, get a new belt. You can avoid the melted paint buildup (or at least reduce it) if you keep the sander moving rapidly over the surface, and use a good quality scraper to remove as much paint as possible before sanding.
Sep 19, 2012 | Makita 9404 4'' x 24'' Belt Sander
I have an old 3 x 21 inch belt sander. I put on a new belt, but the belt tightening device is locked in the "open" position. How do I unlock it so it tightens the belt?
I have that same sander. Know what you mean. I usually end up using a hammer to trip the roller and get it to release by hitting the side(end) of the roller with the hammer. Good luck.
Aug 06, 2010 | Craftsman 0.5 amp 3D Sander
I need an owners manual for a Craftsman 6" x 9" Belt & Disc bench top electric sander. Where may I go to "download" a copy. The specs for this sander are : 6" x 48" belt at 2700 FPM ...
Go to: Searspartsdirect.com and enter the full code number minus the decimal point. That will take you to a series of drawings with parts lists. Hopefully, they still list the owner's manual. Good luck!
Aug 04, 2010 | Garden
The belt on the sander doesn't turn. The sander has power when plugged in and the motor runs when you press the button. But the Belt and track don't turn.
Likely the gear belt that drives the drive rollaer has failed. Either it is totally gone or the teeth in a spot have been destroyed and the motor is just spinning the sprocket in the belt. The belt is about 1/2 inch wide and is covered by a belt guard.
Jun 13, 2010 | Makita 3 x 24" Belt Sander
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
Dewalt DW433 belt sander stop working, why? While sanding shutters, my sander just stopped. Any fixes?
Check the brushes for the motor they may have gone bad or broken, I have seen this happen before on dewalt tools.
Apr 02, 2010 | Dewalt DW433KT Heavy Duty 8 Amp 3 Inch By...
How do I release the lock on my Craftsman belt sander to lighten the belt. It's an old Model # 315.1172
I checked Searspartsdirect.com for that model number and they listed that number, but with an extra 0 at the right end. I couldn't find a belt release lever illustrated anywhere like that on my old Craftsman belt sander. On mine, you just flipped the lever either forward or back to release and tighten the belt. (still works great) There is a spring that pushes the front roller assembly forward when the lever is operated.
Dec 03, 2009 | Cars & Trucks
Tools & Hardware - Others Logo
95 people viewed this question
Top Campbell Hausfeld Tools & Hardware - Others Experts
Are you a Campbell Hausfeld Tool and Hardware - Other Expert? Answer questions, earn points and help others
