Question about Microsoft Windows XP Home Edition
Hello, I swapped out memory in an old HP Pavillion a700n, going from 512 MB to 2GB. The memory only works when I boot in safe mode. If I boot regularly, Windows XP will load to a desktop display, but will not load desktop icons. You can use Task Mgr to activate programs, like IE, but they will not work, although Windows Explorer allows you to navigate and you can see folders, etc. If I swap the memory back to the original 512, I get my desktop and everything works, albeit slowly. I get the same results described above if I use one memory stick instead of both sticks. When booting to safe mode, I believe programs work (it was last week when I tried, though, so I can't rembr for sure). Any thoughts?
    President:
  • 803 Answers
You may want to update your bios they might not support that much memory update them and windows
Posted on May 25, 2010
Installedmemory now pavillion ze4610 just beeps and shuts down.
Make sure your battery is removed, unplug, reseat memory mods, make sure they are inserted fully. I assumed the 512MB are used? New? There is no reason , that I can come up with, they should not work? I have upgraded many memory mods without incident.
Dec 03, 2012 | Computers & Internet
How much RAM can hp pavillion a700n computer support
I can support 2G i have that same comp and i got a 1g stick and a 512 stick.
Dec 11, 2010 | HP Pavilion A700N (PJ516AA) PC Desktop
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
I bought the proper matching two 1Gig sticks of memory to upgrade my 2G mHz TC4200. I installed them and it wouldn't boot, so I swapped back the 1G stick to the original 512mHz chip and it booted. Then I...
Ok, Rob, did you buy the memory from Compaq/HP? Or is it a 3rd party set (ie. Viking, PNY, etc.)? Sometimes, Compaq/HP computers are VERY picky about the specifications of the memory that the mother boards will use.
If you bought them from a 3rd party vendor, I would recommend taking them back and exchanging them for another brand or even just another set of sticks, but, before we go that route, let's try something else.
Install a 1gb stick and the 512Mb stick and then go into the BIOS and see how much ram is being registered there. If it reads all 1.5Gb of ram, then we know it is something else, if not, then we have somewhere else to look.
Assuming the BIOS registered the full amount of ram, try removing the 512Mb stick and then boot the computer, enter the BIOS and see if it is reading the 1gb stick properly. Assuming it did register the 1gb properly, swap the 2 1gb sticks out and repeat. If it did NOT register the lone 1gb stick, try moving the 1 gb stick to the other socket, and checking the BIOS again. If that works, then swap the 1gb sticks out, repeat the BIOS check.
Assuming that after you swap out the 2 sticks and they both work as lone sticks, go back into the BIOS and look for an advanced page or an option to turn on a "Diagnostic Mode" or "Memory Test", and run the memory test on each stick- one sitck at a time, to see if there is a minor/major memory addressing issue, with either stick.
If they both pass individually, then, try reinstalling them both together and check to see if you can reach the BIOS with them both in place. If not try putting the 512 in the 0 or first memory slot and the 1gb in the second slot, then repeat the memory test, swap the 1gb sticks again, and repeat the memory test on the second stick- (the thinking here is that if it is not the memory sticks themselves, perhaps it is the motherboard or one of the sockets for the ram that is bad).
If you can reach the BIOS with both 1gb sticks in place, but, not actually boot to the operating system, then it is possibly a timing issue- this SHOULD BE AUTOMATICALLY configured, but, if you are an overclocker or a "performance wonk" you may have changed a relevant setting in the bios that controls the speed at which the memory and the processor interact. Or it could be a problem with windows hardware monitor not accepting the changes to the amount of memory in the machine. To test this possibility try going into "safe mode" at boot up, after the BIOS screen/Compaq logo has come and gone.
If you can boot into safe mode and not into regular mode, it is a problem with something in windows. Sometimes, just booting into safe mode alone will fix it, sometimes, it is necessary to run the restore DVD on the computer to fix the problem windows is having/ or alternatively reinstall windows without running the restore DVD, using this method will usually fix windows, with out deleting all of your data. You might have to reinstall a few programs afterward, but, your pictures, mp3s, document files, etc. will still be on the drive. Running the restore DVD almost always deletes your data, so USE THAT SOLUTION AS A VERY LAST RESORT, ONLY AFTER YOU HAVE TRIED EVERY other option I have given you.
Good luck, and hope this helps.
Sep 02, 2009 | Compaq tc4200 Tablet PC
What is the ram limit of HP Pavilion 061 DW234A-ABA A530N I have two sticks of kingston 512 in it right now but want to put in two sticks of 1 GB each. Can I? Nvidia 7800 GS OC with 500 watt power supply,...
From the HP specifications page for Pavillion A530N:
Memory type DDR Memory speed PC 3200/2700/2100/1600 Memory sockets Two DDR DIMMs (184-pin) Maximum HP/Compaq approved memory Two x 512 MB DDR-DIMMS, 1024 MB total (1 GB)
Mar 10, 2009 | ASUS Computers & Internet
Memory confusion different readings
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Jan 17, 2009 | Mach Speed (S755) Motherboard
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Wanting to upgrade the memory on a hp pavillion a6220a
Standard Memory:
256 MB or 512 MB or 1 GB (Removable)
Maximum Memory: 2 GB Memory Expansion: 2 Sockets
256MB Memory (PC2-5300) 396519-001, PX974AA, PX974AT KHEW974
512MB Module (PC2-5300) 396520-001, EK477-69001, PX975AA, PX975AT KHEW975
1GB Module (PC2-5300) 398038-001, PX976AA, PX976AT KHEW976
You can upgrade your system to 2GB MAX
Your memory type is PC2-5300
Please be sure to get the right memory (above listed)
Have a great day
Pablo :-)
Let me know if you have some questions about this issue...
Oct 22, 2008 | HP Computers & Internet
Memory upgrade problems
sex just change the mother board old mother board get slower by time. so' buy new core 2 duo or core 2 quad wich I am using.
Apr 08, 2008 | Lite On NA115 Motherboard
Microsoft Windows XP Home Edition Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
