Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
THE WATER LINE GOING INTO THE FREEZER IS FREEZING UP. APPARENTLY THE VALVE IS BLEEDING BY A DRIP AT A TIME LETTING IT FREEZE RIGHT AT THE BACK WALL. I'M WONDERING DO I NEED THE ADAPTER TO ATTACH THE WATER LINE ONTO THE NEW VALVE? OR DOES THE WATER LINE COME ALREADY ASSEMBLED ON THE VALVE? IT LOOKS LIKE IT (THE LINE AND VALVE) COULD BE ONE PIECE?
  • 166 Answers
Most valves are one piece valves and they have "push-in" connectors that hold the tubing in the valve.
http://www.partselect.com/xq/aspx/Inventory.1991254/qx/PartDetail.htm?SourceCode=5&ModelNum=glhs269zdb
Posted on May 25, 2010
Why does my fill tube for my ice maker continue to drip and freeze up?
Usually a leaking water valve can cause this. This can be caused by low or high water pressure or just a leaking valve. Remove the tube from the valve and if water continues to drip from the valve it is bad or the water pressure is wrong. If it does not drip, leave the water line disconnected from the valve and dispense some water from the dispenser to see if it leaks. If it does the water is bleeding over and the valve is bad. If the valve is not leaking at all insure the fill tube that goes through the box and supplies water to the ice maker is seated properly and sealed off with permagum for instance. Also make sure the freezer section is not too cold ie -15 or -20 as this could cause issues.
Feb 19, 2015 | Kenmore Side by Side Refrigerator
Water keeps building up and freezing in the tube to the icemaker and on the wall where the tube comes in...
Replace the water inlet valve. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Dec 01, 2010 | Refrigerators
GE Profile Icemaker freezing up; water freezes down inside wall of freezer; icemaker making ice, very slowly, but will not dispense. Water is still dispensing
This sounds like your water valve is not completely closing allowing water to drip and freeze. First check to make sure that the water tube going into the cup of the ice maker is lined up correctly and not causing this problem - if it is lined up correctly then replace the water valve on the back of the refrigerator that your main line is connected to.
Jul 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Water is freezing when it runs down the water trough to my ice maker. I have the Freezer settings pretty low (my options are A the warmest, B or C the coolest and I have it between A and B). Are there...
The refrig water valve , is seeping . This means that it isn't closing completely , letting a slow drip run down the fill tube and freezing . Replace the water valve (piece the wall water line connects to on the back of the refrig ) and I believe this will solve the problem .
Sep 24, 2009 | Refrigerators
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
No ice
Pour about 1/2 cup of water into icemaker . If it freezes and dumps , the water valve is bad ( where the wall water line connects to the fridge ) . If it freezes and does not dump and the ice stays in the icemaker , replace the icemaker . Also check the fill tube ( the tube going from the freezer wall to the icemaker itself ) to see if it has frozen closed . If it has , the water valve is not closing completely , and letting a drop thru and freezing in the tube . Also an indication of a bad water valve .
Aug 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
The feeder tube for the ice maker freezes and water leaks inside
First we have to determine if the problem is a faulty water valve. Reason: faulty water valve can continue to supply water even after the IM or door dispenser is finished calling for water causing a drip feed freeze up problem, or water overflow condition in the ice maker (IM). Another common cause is unrelated, but caused by a blocked drain line often resulting in thick ice build up on the bottom of the freezer, water dripping onto the floor, or water dripping into the refrigerator (top freezer mount models only) and freezing near the lights or damper ducts after defrost. Fix for this problem is to remove evap panel and clear freezer drain line with hot water or compressed air. If this is not the case, and water is dripping out of IM supply line, remove IM H20 supply line from IM at back of appliance and see if the water seems to drip out, if so, replace the water valve. If water doesn't drip out at all, replace IM, or IM module depending on the model of refrigerator that you have as contacts in the IM are also responsible for calling for H20 supply. You will have no more problems after this.
Jun 17, 2009 | GE GSS20IEP Side by Side Refrigerator
I have an Kenmore side by side and my water is freezing in the water line that leads to the ice maker. So no water is getting to the ice maker. How can I fix this problem??
if water keeps freezing in the line you need to replace the water valve after you get it melted out again / valve is letting a little water seep into the line and freeze up / larry
Dec 12, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
