Question about Toshiba 19AV501 19 in. HDTV LCD TV
Input menu pops up randomly
How to reset toshiba lcd tv?
welcomejee
  • 10594 Answers
SOURCE: My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Posted on Feb 24, 2009
tlm931
  • 273 Answers
SOURCE: The menu screen keeps popping up?
there is a firm ware download for many of these sets at philips site that will correct this problem
Posted on Oct 25, 2009
Testimonial: "Found it, thanks http://tinyurl.com/PhilipsTVupdateInfo"
circuitworld
  • 335 Answers
SOURCE: 42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
Posted on Nov 03, 2009
  • 8457 Answers
SOURCE: A black box randomly pops up on my tv screen constantly...
It part of the caption functions is on.Tries find in ur tv menu,goto captioning functions like CC1,2,3 and Text 1,2,3.Turn it all off.These radom black boxes and trying typing somethings,should stop.
Posted on Jul 21, 2010
SOURCE: toshiba 32av615db tv - keeps scrolling channels
On the back of the TV, where the main board is (the one with many AV inputs to it) there are several cables going into it.
Find the one that leads to the buttons on the TV - it won't be too hard to trace - and after turning on the TV disconnect that cable.
Or, if the cables for the buttons and the front LED and IR sensor are separate (sometimes they are) you disconnect the one for the buttons and then turn the TV on with the remote.
Either way, see if the problem persists with the buttons panel disconnected.
if it does then the problem is in the main board and likely you'll want it replaced. The way they make them these days it's really cheaper to replace the whole thing than to look for a problem among components the largest of which is about a millimeter long.
if the problem is in the button/cable connector...you'll probably find it easy. Often it's because that same cable has been trapped between the front and back covers and broken or shorted by the friction and pressure.
Hope this helps....would appreciate a review on Google if it does!
bobby
www.coppelltvrepair.com
Posted on Oct 09, 2012
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers ยท Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
Tv switches to off/standy
Check and replace its front/side panel switch board. Contact any service technician. Gopakumar Gopalan Google
Feb 27, 2014 | Toshiba 32BV502B 32 in. LCD HDTV
Tv keeps changing input
It sounds that the main digital processor board has the fault. Your TV need a through check up. Contact any service technician.
May 27, 2013 | Televison & Video
Input selection menu randomly appears, how to fix?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Mar 12, 2017 | Toshiba 37AV52U LCD TV
How to reset the TV menu on my sanyo vizon 24k40?i think a menu pop out and someone in the house mess it up?can't access the whole menu and remote control isn't working?
Hold down "INPUT" Button at TV panel, while you press "INFO/A-B" button in your remote.. Or...Hold down "INPUT" Button at TV panel, while you press No.1 chnl on your remote..
Sep 04, 2011 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Jul 20, 2010 | Olevia 237T 37 in. LCD TV
I have a Toshiba 40RV525U LCD TV. Wondering how to
if it is with hdmi input call toshiba--free software upgrade
Jul 12, 2010 | Toshiba 40RV525U 40 in. LCD TV
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
W2606c lcd tv
Nothing appears on my LCD TV display
1 Ensure the LCD TV display is turned on.
2 Verify that all the cables are properly connected to the LCD TV
display, including the power cable.
3 Check to see if there is a blue or amber light on the lower,
right-hand corner of the LCD TV display. A blue light indicates
the LCD TV display is on. An amber light means the LCD TV
display is in power save mode.
4 Ensure the proper source is selected in the Input Select menu.
See "Input Select Menu" on page 24 for more information.
5 Reconnect any devices that are currently connected to the LCD
TV display. If you are using multiple devices, connect and test
one device at a time.
6 Connect another device that you know is working properly.
7 Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset.
Problem Possible Solution No sound
1 Ensure mute is not turned on. Pressing the Mute button on
the remote control turns the mute function on and off.
2 If only certain LCD TV channels do not have sound, then you
need to correct the Input Select menu in the TV Menu (see
"Input Select Menu" on page 24).
3 Verify that the audio cables are firmly connected to both the
audio input connectors on your LCD TV display and audio
output connectors on your devices. Ensure that the cable colors
match the connectors colors.
4 Also, ensure that the audio cables are connected to the same
row as the video cables. See "About Your LCD TV Display" on
page 5 for the location of the connectors.
5 Reconnect the device using the same type of connector. For
example, if you are using the composite connector on the
bottom, try connecting the device to the composite connector
on the side of the LCD TV display. See "About Your LCD TV
Display" on page 5 for the location of the connectors.
After you connect the device, change the input source in the TV
Menu. See "Input Select Menu" on page 24 for more
information.
6 Connect the device using a different connector. For example,
if you are experiencing the problem using a composite
connector, try using the component connector.
NOTE: To connect to a different connector, you need the
appropriate cables for that connector. See your device
documentation for a list of supported connections.
information.
7 Test the device on a different TV.
Jan 05, 2009 | Dell Televison & Video
TOSHIBA 35 TV 35A44
don`t know if this will work for yours but I have heard of menu coming up all by itself randomly and the fix was to remove the batteries from the cable boxes remote and the tv`s remote, partially stuck on buttons were the cause, replaced the remote end of problem, hope this helps on yours.
Nov 29, 2007 | Toshiba 35A44 35" TV
Toshiba 19AV501 19 in. HDTV LCD TV Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
