Question about HP DesignJet 120nr InkJet Printer
Error code 221 - HP DesignJet 120nr InkJet Printer
  • andyho18 May 25, 2010
    i knew about the error code respresent, but my ink cartidge are 80% full
  • 973 Answers
211 Error with main PCA, ink supply station or carriage
Posted on May 25, 2010
How can I fix the error c6400 on kyocera taskalfa 221?
Hi
I found this explanation of your error, although my understanding of it is not entirely clear.
Code: C6400
Description: Zero-cross signal error
Interrupt of the zero-cross signal does not occur more than 1 s.
Causes: Poor contact in the connector terminals.
Defective power source PWB.
Defective engine PWB
You can find this here:
Error Codes Kyocera Mita TASKalfa 221 Code C6400
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | Kyocera Office Equipment & Supplies
FUJI XEROX 016 757 ERROR CODE
Could be: The entered password is wrong or
Auditron security (A Xerox feature) is preventing users from Printing.
Then: Enter the correct password (Default 11111) or
Disable Auditron security settings from the Administrator menu.
Xerox Error Code 016 757 Tech on Tour
http://es.scribd.com/doc/21054313/Fault-Codes-Xerox
http://arts.ucalgary.ca/it/kb/221/xerox-printer-giving-016-757-error
Jun 25, 2014 | Dell 3100cn Laser Printer
No code for qmedia qtk 221
This is a very rare brand DVD player, I've ever heard. Try these codes. For more information http://electrohelponline.blogspot.com/
Nov 26, 2013 | Grundig 7 In 1 Universal Remote Control -...
Copier error code 221
We are assuming that you are talking about Error Code SC 221
This code is a Scan length detection problem.
1.Disconnected Sychronization Detector
2.Bad LD-Unit/BICU Board
SOLUTION: Replace the Laser Diode & Laser Sync detect board
Hope helps (remember to rating this free answer).
Oct 12, 2011 | Ricoh Aficio 1232C Color Copier
Code 221--- is this usually oxeygen sensor
If it is a Bosch LH 3.2 Jetronic System 221 =long term fuel mixture too weak in part load stage
If it is a Fenix 5.2 System 221=Lambda Operation; also Heated oxygen sensor (mixture too rich under part throttle)
/ long term fuel mixture too weak in part load stage
So yes
Mar 25, 2010 | Volvo 940 Cars & Trucks
Error code F 20 on Gaggenau EB 260/262 oven
Sometimes the error light will come on because of mixed signals sent. If everything works, then just ignore it. Unplug the oven or turn power off in fuse box. This may reset the light control. Be very careful around the power source. Wear rubber bottom shoes, have dry hands and floor. Don't touch exposed wires with anything. This is 240 volts that can hurt or kill you!!!!!!
Nov 03, 2009 | Gaggenau ED 220/221 Electric Single Oven
I KEEP GETTING AN ERROR ON MY RICOH CL 7000 THE ERROR READS SC 221-2
SC No. Item Definition Possible Cause Related
SCs Troubleshooting Procedure Type
SC 221 Synch.
detection signal
error 2
221-001: Y
221-002: M
221-003: C
221-004: K
Main scan length detection is
not properly completed ten
consecutive times.
The front (for C&M) or rear (for
K&Y) laser synchronizing
detector boards are used for
the main scan length
detection, which automatically
corrects the main-scan
magnification.
• Damaged or
disconnected cable
between front (C&M)
or rear (K&Y) laser
synchronizing
detector board and
the LD unit
• Incorrect installation
of front (C&M) or rear
(K&Y) synchronizing
detector board (the
beam does not target
the photo detector.)
• Defective front (C&M)
or rear (K&Y)
synchronizing
detector board
• Defective LD unit
After doing any of the following, print ten
jobs or more to see if the same SC code
is displayed:
1. Turn the main switch off and on.
2. Check or replace the cable
connecting front (for C&M) or rear (for
K&Y) synchronizing detector board
and the LD unit.
3. Check or reinstall the front (for C&M)
or rear (for K&Y) synchronizing
detector board.
4. Replace the front (for C&M) or rear
(for K&Y) synchronizing detector
board.
5. Replace the laser optics housing unit.
6. Replace the BCU.
If a synch. detector board cannot be
replaced, do the following as a
temporary measure:
• Disable main scan length detection
Sep 15, 2009 | Ricoh Aficio CL7000 Laser Printer
Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Feb 15, 2009 | Fuji M321SP Betacam Tape
Conextant HD smart audio 221 driver
u r not mention here your laptop/desktop model........plz mention this.
Dec 18, 2008 | HP Pavilion dv6000z Notebook
HP DesignJet 120nr InkJet Printer Logo
128 people viewed this question
Ben Johnson
