Question about Dryers
I have dle1310w LG dryer . No power except the light comes on when the door opens
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Also check the door switch as if the door is not closed properly it wont even start. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 25, 2010
  • jimswiderski May 25, 2010
    I don't think I gave you enough information the front digital display is also output no lights so I can't see it allows power to the motor or heater. I look at what looked like the thermal fuse but no power is going out or into the themal fuse. The only thing that is recieving power is the door light in the drum.
    Thx jim
  • Rylee Smith
    Rylee Smith May 25, 2010
    From what you have described it seems to be the control panel that has gone bad and needs to be replaced.
LG dryer dle1310w won't start. There is power but the control panel looks dead.
first take top off(two screws in back and then slide top back about 2" and lift top up and off)
check for wire connections being fully seated to the control panel.
check that the drive belt is there and tight around drum. if broken, it disconnects a power switch to the motor.
also check repairclinic.com or appliancepartspros.com for repair videos
Oct 28, 2016 | LG DLE1310W Electric Dryer, White, Super...
Dle1310w amazingelectric
a putty knife will do. you need to release2 clips towards the top. about5 inches from both side
Oct 23, 2013 | LG DLE2532W Electric Dryer
How to change the sensor on the LG DLE1310W
Moisture sensor? Why would you need to replace that? Is it tearing your clothes up?
Feb 08, 2013 | LG DLE1310W Electric Dryer, White, Super...
Lg electric dryer DLE1310W will turn on but won't get hot
It might be the heating element. Have you checked to see if it is getting any power?
Feb 27, 2011 | LG Dryers
I need a manual for a DLE1310W Dryer. Can you send me one.?
go to this web sight and down load your manual.
http://www.lg.com/us/appliances/dryers/LG-electric-dryer-DLE1310W.jsp
Feb 03, 2011 | LG DLE5977 Electric Dryer
Dryer will not start
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 11, 2010 | LG DLG5932W Gas Dryer
Lg dryer dle1310w, just delivered, machine can't spin
IS THIS A BRAND NEW DRYER? IF SO DELIVERY PERSONEL MAY HAVE NOT REMOVED SHIPPING BOLT/S. GO TO www.repairclinic.com ENTER MODEL NUMBER AND SCROLL ALL THE WAY DOWN TO THE RED 100 CLICK IT AND LOOK FOR PART NUMBER 1266806 OR 1266805. OR CALL WHERE YOU BOUGHT THIS AT AND HAVE THEM COME BACK OUT .
Apr 12, 2009 | Dryers
Dryer will not start,put a new start button,
The dryer is electric? not gas? If so you may have 110 and 1 side and not on the other. Reset the breaker and make sure you have 110v on each hot leg. You say start button I assume you mean door switch for the light? Have you checked the bulb? If this is already yes to this point open the top up and look at the wires coming to the door switch 1 of them is most likely chewed into by a mouse or something. the light has to have power to it all the time the door is open no power no light because I dont believe it gets any power except from the main power terminals not the timer or anything else .
Mar 11, 2009 | Dryers
Dryers Logo
180 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
