Question about VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09)
No powr/reset plugins
NO CASE POWER/RESET PLUGINS!!!! I have a zodiac case by platinum systems, is there a motherboard that would more suit the flashy nature of this case? i have alot to plug in from case
  • Anonymous May 06, 2008
    HEY!!! in the bottom right hand corner the pins are labeled "PWR8TN" above "RST" . the power goes above the reset, both together both there, it's the pins under "power LED" pins ;)
My audio driver is not work properly via asrock k7vm3
Posted on Jul 04, 2008
SOURCE:
Linux dvd player codec
yum localinstall --nogpgcheck http://download1.rpmfusion.org/free/fedora/rpmfusion-free-release-19.noarch.rpm http://download1.rpmfusion.org/nonfree/fedora/rpmfusion-nonfree-release-19.noarch.rpm NOW you will install all codecs, yeah yum -y install gstreamer-plugins-bad gstreamer-plugins-bad-free-extras gstreamer-plugins-bad-nonfree gstreamer-plugins-ugly gstreamer-ffmpeg yum -y install gstreamer1-libav gstreamer1-plugins-bad-free-extras gstreamer1-plugins-bad-freeworld gstreamer1-plugins-base-tools updates gstreamer1-plugins-good-extras gstreamer1-plugins-ugly gstreamer1-plugins-bad-free gstreamer1-plugins-good gstreamer1-plugins-base gstreamer1 ffmpeg
yum -y install ffmpeg
Mencoder
yum -y install mencoder
ffmpeg2 theora
yum -y install ffmpeg2theora
Mplayer
yum -y install mplayer
Play dvd, yeah
yum -y install libdvdread libdvdnav lsdvd libdvdcss
Also you can use PostInstallerF
or you can use http://www.mplayerhq.hu/design7/dload.html this to play movies..
Jul 17, 2012 | fedora Linux Operating System
I need the wiring diagram for replacing the power supply for a HP Pavilion 515n
You don't need a wiring diagram. Just pay close attention to where things are plugged in while the old power supply is still in the computer once you remove the case. There are only a few connections and some of them will only fit in the correct slot on the motherboard. For example, the main power to the motherboard will be the largest connector, then you will have a connector to the hard drive, the dvd/cd drive, etc. What you could do it take a piece of masking tape and and fine tip marking pen such as a Sharpie and write where that wire is being plugged into the motherboard. Then when you remove it and put the new power supply in, just refer to where the plugins go based on what you marked on the old plugins. There will also be some plugins that go nowhere. They are there for future expansions and upgrades that you might do.
Mar 13, 2012 | HP Computers & Internet
DISABLED CHROME PLUGINS BY MISTAKE, HOW DO I GET BASK THE PAGE TO ENABLE THEM
there is an easy solution, type this to your google chrome browser chrome://plugins/ , then find below your plugins to enable or disable. bye.
Sep 22, 2011 | Computers & Internet
Media player wont play movies but will down load muisc and write information to cd
Media player requires special Codecs and plugins in order to watch movies! Most cases they are not free, but here is the site which you can acquire them.
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx
Now, on the other hand you can buy software of dvd suits that will play DVDs
http://www.cyberlink.com/products/powerdvd/overview_en_US.html?&r=1
Also, there are various free players out there you can download and use to watch movies for free.
http://www.videolan.org/vlc/
http://download.cnet.com/Easy-DVD-Player/3000-7970_4-10104512.html
http://www.dvdvideosoft.com/products/dvd/Free-DVD-Player-Software.htm
Aug 19, 2011 | Microsoft Windows XP Professional for PC
Zmazany operacny system a neviem sa dostat do biosu pyta passvord
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 15, 2010 | MSI K9N Platinum Motherboard
I need help with the tiny pin-out on an XP motherboard +PLED Reset switch -PLED power switch these are 2 hole plugins I need to put them back right
want the pictures of mother board connections how to connect the connections and where to connect particular connection
Oct 09, 2008 | ASUS Computers & Internet
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
Open Questions:
See all VIA ASRock K7VM3 Socket A/ Questions
VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09) Logo
103 people viewed this question
Top VIA Computers & Internet Experts
Thomas F. Schneider
Ekse
Sunil Karickom
Level 1 Expert
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
