Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Leaks from under frig. I think it is the hose
Leaks from under frig. I think it is the hose that directs the water to the drip pan but don't know how to check
    Scholar:
  • 59 Answers
In the freezer section. Behind the lower rear wall is the coils and just below that is a drain. If you will remove any ice and use a coat hanger or screw driver to push down through that hole you should be able to get it unclogged. Take a small cup of water to verify that you have it unstopped and your done.
Thanks for asking.
Posted on May 25, 2010
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My water filter was not clicked in all the way so water leaked and filled up the drip pan under the refrigerator and started leaking out onto my floor before I noticed anything was wrong. I put the water...
Hello Terri,
The pan there is for the defrost water that drains into it durning the defrost cycle,that water eveperates automatically so this water too will evaperate as well may take a bit longer since its more but it will evaperate. Also as you know there is no way to remove that pan,but tomorrow it will be empty anyway
Gene
Aug 08, 2011 | Kenmore Side by Side Refrigerator
I found water under my amana refrigerator Model Number ABB2222FEW does this model of refrigerator have a drip pan to catch water I can not find any reference to a drip pan in the book I received when I...
Hi
Look on the ceiling in the back by the compressor do you see a small hose on the ceiling. There's an access panel at the lower right corner. That's where it is ,there's a drain pan just under the hose remove that panel its right there.
Also check this link to have a detailed idea:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itleaks
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 01, 2011 | Amana Refrigerators
Our frig. Leaks a small amount of water from inside about every 3 days
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination.... This is all you need to do....
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 10, 2010 | Kenmore 64802 Top Freezer Refrigerator
The fridg has a pool of water under the front door that keeps appearing even after we wipe it up. It has suddenly appeared today. It is a Silhouette 442 Frost Free model.
check drip pan under frig.remove ft bottom of frig under door/ck drip tray?full? old frig?-time to buy new one.could be working to hard(age,compressor going bad)will cause frig to sweat.producing water under it.hope this helps.:)
Nov 24, 2009 | Lands Phones
Water leaks from under the middle but not all the time maybe once or twice per month
condensation normally drains thru a tube at the bottom of the frig to a drip pan under the condenser coil (under the frig) .. the water normally just evaporates from the pan .. if there is too much moisture in the frig, that usually means a door is ajar (not closing completely) or the seal on the door is not sealing properly .. warm moist air from the room getting in will cause too much condensation .. the drip pan may overflow ... you should check the drip pan for damage (clean the condenser while you are down there) .. also check the tube that carries the condensation (back bottom of the frig) .. it has a one way valve (lets water out only) that becomes stuck sometimes and needs cleaning.. if there is a large amount of moist things in the frig then that an cause the problem as well .. just put those things in plastic bags or containers to eliminate that problem ..
Nov 21, 2009 | Amana AFD2535DES French Door Refrigerator
My refrigerator is leaking water underneath it. the ice maker is not hooked up
Is it leaking water INSIDE the fridge at the bottom - if so that is an indication of a clogged defrost drain - if you have a drip cup in your refrigerator, that connects to a tube at the back of your fridge, to carry the water from the defrost cycle down the drip pan at the bottom.
If you see water OUTSIDE your unit, the only explanation is an overflowing drip pan ! Water from the defrost cycle drains and drips on a pan that sits on the compressor or besides it - the hot air from the compressor will cause water in the pan to evaporate quickly - either through a fan or when the pan is placed directly above compressor. If your model has a fan at the bottom next to compressor, that blows the hot air on it, check to see if it's working when compressor cycle is on.
There is no reason for that drip pan to overflow otherwise, it is quite big enough, and the water from the defrost cycle is usually around 2 ounces and should evaporate quickly.
Oct 09, 2009 | Whirlpool Refrigerators
Water starting to pool (two tablespoons) under front of frig under door, is there a pan in the bottom of this unit?
Most fridg's have a water pan below. Need to drain occationally, especially after defrost cycle.
Apr 30, 2009 | Refrigerators
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
WATER LEAK IN FREEZER POOLING AT BOTTOM & FREEZING THEN MELTING
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Bob
Nov 07, 2008 | Refrigerators
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
313 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
