Question about Samsung RB215LASH
My fridge and freezer temperature go down and then it goes back up What is the problem??????
  • Samsung Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezermy fridge and freezer temp - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 26, 2010
aborcass
  • 2651 Answers
SOURCE: does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Posted on Nov 21, 2008
  • 87 Answers
SOURCE: fridge not cool, freezer fridge temp
The most likely fault is a problem with the defrost cycle. The most likely is the defrost heater which should be a solid bar which is located directly underneath the coil. If you are capable then you can generally unplug the connectors for the heater and check that you have a resistance across the ends if the heater is faulty it will be open circuit. If it is not open circuit then it could be the defrost sensor or defrost timer at fault. You can also generally tell if the heater is warped or cracked. Hope this is of some help.
Posted on Sep 06, 2007
SparkGap
  • 363 Answers
SOURCE: temperature
I think you have a refrigerant gas leak. This is very common and another symptom will be that the compressor is nearly always running constantly.
This can really only be solved by a professional because of the equipment required.
First make sure your warantee is not expired.
Posted on Oct 13, 2007
heatman101
  • 43501 Answers
SOURCE: fridge broken, freezer is temp. that fridge should
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: Freezer temp on GE profile
This is by design. It should be warm. This is where the heat exchanger is located to save space.
No worries.... right now it is being over-worked until it reaches operating temp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 05, 2010
Testimonial: "thanks! Wow, I didn't know about this site before. This is great! Problem was w/ a french doors/bottom freezer model....answer still applies?? "
Hi Iv got a Hotpoint fridge freezer iced diamond rfa52 it keeps switching on and off it seems when the fridge gets warm it turns back on my freezer is not defrosting but the fridge is then freezing again...
Okay, have you adjusted your cold temp knob inside the fridge part? There are two switches one in the freezer and one in the fridge you will need to watch it day by day until the optimum temp setting has been achieved same goes for the freezer if it defrosts that is the exact point where your freezer is at best! It takes patience so be patient and your problem will be solved! Good luck and thanks again for using fixya.com
Oct 09, 2014 | Hotpoint Refrigerators
My refrigerator display shows "Of" how do I get it to normal when I reset the temp for the fridge or freezer the display goes back to "Of"
I just had the same problem with my Samsung. OF means it is in demo mode. On my fridge I had to press "Energy Service" key and "Power Freeze" key simultaneously for at least 3 seconds to bring the fridge out of demo mode. Hope this helps.....
Jan 28, 2013 | Samsung Refrigerators
Freezer works fine, but fridge is not cooling very well at all. I turned freezer temp down and fridge temp colder but nothing seems to be changing. It is a small 5ft. tall top freezer model.
Check to see if you have airflow in the freezer and that it is also blowing into the fridge section. Also, check to see if you see any ice buildup on and behind the back wall of the freezer. Post back to me here.
Jul 20, 2011 | Whirlpool Refrigerators
What is the purpose of two temperature control nobs when there is a single compressor in my samsung 280 lts fridge
1.If this is only a fridge the one knob will be for the min and the other for the max.
max. : As soon as you switch the fridge on it will cool down the fridge to max cool down temp. example -2deg.
min. : As soon as the fridge reaches the max cool down temp and it had switch the compressor off, the fridge will start to warm up slowly, by the time it reaches the min allowed warming up temp, it will switch the compressor back on and do the cycle all over again.
2. If it is a fridge/freezer setup, the one knob will be for the fidge and the other for the freezer. If the temp in the freezer is fine a fan is activated and blows all the cool air to the fridge and controls the temp. by activating the fan.
Sep 06, 2009 | Refrigerators
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
Jul 03, 2009 | Refrigerators
Not cold enough. ice on back of freezer but not making cubes
sounds like you might have a deforst problem or your drain is blocked not allowing the water to drain when the fridge goes into defrost.
Apr 24, 2009 | Freezers
Fridge and freezer not cooling down
It seems it's the defrost sensor (freezer side). Waiting for it to come, ordered this morning. It appears to be a defrost fault, having read on the web it seems you can check the defrost sensor with a meter across whilst holding the actual sensor in your hand tightly to see if the resistance changes, anyway it didn't. Will post when the new one comes and I change it.
Sep 12, 2008 | Samsung Refrigerators
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RB215LASH Logo
533 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
