Question about GE Refrigerators
How to adjust the temperature on a ge profile refrigerator
  • 1462 Answers
SOURCE: GE Profile Arctic Side x Side Refrigerator PSC23MGNA
check that compressor is not cutting out on overheat and hence cooling stops. feel compressor when it has been running for some time and see if it over hot
Posted on Jun 18, 2007
SOURCE: GE Profile Refrigerator PFS22SISBSS Bottom Freezer Temperature Indicators
I finally called GE about the non-working LED's and the temperature fluctuation. It's a known problem as many consumers have posted online. I called 800-386-1215 several times. What I found is I'd get different menu options nearly each time I called. The way I got to a 'helpful' human follows: Call above number; you will/may here a voice that states only 'for recalled appliances press 9' (may also have options for repair or parts) PRESS 0; next menu PRESS 5; you'll hear 'for less than 1 yr old press 1' and 'for more than 1 yr press 2'. In my case I pressed 2, then got a menu with 'for refrigerators PRESS 2'. Spoke to a woman who never denied that GE has a motherboard problem. She offered to provide a free motherboard but no labor. I asked (to be sure) if I would have to pay labor, she said yes or I could have $400 off a new crappy GE fridge. She said I would have to have a repairman come to diagnose the problem, then order the part and then come back to repair. I then said, 'You're telling me that I have to pay for TWO service calls to repair a known GE defect???? How much should I expect to pay for these TWO service calls???' She then asked me to hold, then came back on the line and told me that GE would pay the labor for the repair.
I also asked if GE was willing to do anything about the 25 cent door latch that cracked after 11 months (and is attached to the door gasket a $228.00 part) or the rusting wire freezer baskets and was told no. Hey, worth a try! The fact that they said no ensures that I will continue on my crusade to warn anyone who'll listen not to buy GE! Keep calling, after I got the right menu the wait was short the whole call was less than 15 minutes.
Posted on Sep 17, 2008
aasc
  • 1606 Answers
SOURCE: GE PROFILE REFRIGERATOR MOTHER BOARD PROBLEMS
Go into the diagnostic mode on your touch display .
1) . Press any button on the display 1 time except the temp adjust buttons.
2) Press the temp up and down on both the freezer AND refrig (all 4 at the same time)
3) when 0's show , release the buttons and press any button except for the temp adjust buttons .
4) NOW , fress the temp adjust buttons until the freezer side displays 0 and the refrig side displays 7 . 0 and 7 is for the thermistors test .
5) After 0 and 7 display , press any button again except temp adjust , and this will start the thermistor check .
6) You will have 7 thermistor tests , indicated on the refrig display , starting at 1 , then 2 then .......
7) The feezer display will tell for the corresponding thermistor , indicated by the refrig display , if the thermistor p = pass , s = short , b = bad (replace board)
After determining if or which thermistor is bad , then adjust the display to 1 on freezer display and 6 on the refrig display . This ends the testing procedure and resets the refrig back to normal .
Posted on Sep 26, 2009
woodchuck789
  • 4066 Answers
SOURCE: GE PROFILE REFRIGERATOR SIDE BY SIDE IS NOT COOLING
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Nov 17, 2009
  • 288 Answers
SOURCE: GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Posted on Nov 27, 2009
How can i get the temperature to stay on it keeps shutting off it wont stay cold since it was left open 2 days ago
[PDF]General Electric Pfcs1nfzss Quick Specs - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../general-electric-pfcs1nfzss-q...
For answers to your Monogram,® GE Profile™ or. GE® appliance questions, visit our website at geappliances.com or call GE Answer Center® ... Counter-depth configuration - Counter-depth configuration makes it possible to have the look of ... Adjustable spillproof glass shelves - Raised edges keep small spills from ...
GE Refrigerator Not Running - Appliance Repair Guide
www.appliance-repair-it.com/GErefrigeratorrepair.html
In this GE refrigerator repair guide, I will walk you through the steps in ... They also added an electric damper that regulates the airflow between the fresh ... If you have aGE refrigerator that is not running the most common problem is ... Once the cover isoff, you should be able to see the main board. ... Temperature ControlMissing: pfcs1nfzss
GE Bottom Freezer Refridgerator fix. Evaporator Coil drain ...
? 2:25
https://www.youtube.com/watch?v=IiPRhr6nk54
Jan 01, 2016 | General Electric PFCS1NFZSS GE Profile...
GE Profile Arctica fridge running too cold
You may want to check your damper assembly to see if the door is broken. If the door is broken it will air to migrate to the refrigerator compartment causing freezing issues. Also check to make sure that the damper door is not staying open. When you take the cover off with the door open the damper should close. If the damper is open then you need to replace the damper. Here is the damper to order.
Dec 05, 2012 | GE Refrigerators
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a ge profile side by side refrigerator model number psc25psta. The freeze is not getting cold. How do I reset the temperature.
Here is a link to the main GE Support page for your refridgerator:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=PSB42YSXSS
And here is a link to the Online User's Manual with the operating instruction for it:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60558.pdf
See page 5 of the User Manual for detailed instructions on how to adjust the fridge and freezer temperatures. It reads as follows in the manual:
To change the temperature, press and release
the WARMER or COLDER button. SET will illuminate in
the display, as well as the set temperature. To change
the temperature, tap either the WARMER or COLDER
button (while SET is illuminated) until the desired
temperature is displayed. Refrigerator temperatures
can be adjusted between 34F and 47F and
the freezer temperatures can be adjusted
between 6F and +8F.
Once the desired temperature has been set,
the temperature display will clear after 10 seconds.
To display the temperature, the DISPLAY TEMP button
may be tapped.
Several adjustments may be required. Each time you
adjust controls, allow 24 hours for the refrigerator to
reach the temperature you have set.
Good luck and please comment back here and RATE 4 Thumbs Up if this was at all helpful.
Just click on the highlighted links with your mouse in order to access the information described.
If the link does not open properly, you may need to download a PDF Reader program for your computer. The best reader can be downloaded free at www.adobe.com where you just click on the DOWNLOAD ADOBE READER button on the right hand side of the page and follow the on-screen instructions.
Just comment back here if you require any further assistance, I will be pleased to assist you in any way I can.
Thank you very much.
Joe.
Feb 14, 2011 | GE Profile PSB42YSXSS Stainless Steel (252...
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE profile side by side and the fruit vegetable drawers freeze what ever is in the them. The temparature in the refrigerator is 37 degrees F
If you cannot adjust the temperatures or close the air dampers on left side of the crisper contact me withe the model number. 38 degrees is perfect safe temperature for lower section. There are several styles of the Profile. That is why I asked for model number is to see exactly which style you have. For example PSS26MRSS would be what to look for. Sea Breeze
Feb 16, 2010 | GE Refrigerators
Ge profile bottom mount and temperature control
sounds like the mother board maybe bad. we replace alot of those , or 2nd i would say a display board .
Sep 13, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE not cooling properly
If you have changed temp and adjusted vents, then either your temp sensor may be faulty or thermostat itself may be faulty. Check compressor to make sure it is pumping and there is no freon leaks.
Jul 09, 2009 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
270 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
