Question about GE Spacemaker JVM1640SJ Microwave Oven
The inside ceiling in my 7 year old space saver is peeling...how can I fix it?
  • GE Master
  • 9,047 Answers
You need to clean it, sand it shiny, then clean it squeaky again.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
I would suggest you let it dry overnight with the door open before using the oven.
If your waveguide cover / stirrer cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
In the future, I would advise wiping down the walls & ceiling anytime steam and moisture have accumulated in the oven, or at least leave the door open until it dries out.
Posted on May 30, 2010
We have a GE JVM1540 space saver microwave. It is less than a year old. Will not heat and immediately starts smelling like burning plastic. Any ideas as to what is causing that?
CHECK THE MICROWAVE MANUAL LOOK FOR FACTORY WARRANTY ,MUST BE A BAD COMPONENT ,IF YOU MICROWAVE IS UNDER 1 YEAR WARRANTY THE FACTORY WILL REPAIR IT AT NOT COST TO YOU..CONTACT GE FACTORY.
Feb 18, 2011 | GE Spacemaker JVM1540 Microwave Oven
JVM1642WB004 We had a power surge now the screen looks like XXXXXXXXXX Nothing works GE Space Saver Microwave Oven
this is a comon fult if you get a power surge the shock blows the main bord,,and thats not a cheap part to fix, it would be wiser to just dump it and buy a new microwave there so cheap now, what throw good money at an old microwave,,,
Mar 14, 2010 | Microwave Ovens
Paint peeling
The paint you need is called microwave cavity paint. If they don't have it at your local hardware store, you may get it at www.appliance411.com/data.php?rc=277
Be sure to sand the area first with some emory cloth to remove any loose paint flakes.
May 07, 2009 | Rival MT660 Microwave Oven
Replace burned inside ceiling of microwave?
Do Not Use The Microwave. If You Need Parts Try Finding A Part Number And Use Ge To Order Parts. Click Here To Order Parts
Jan 15, 2009 | GE JEM31 Microwave Oven
Not heating properly
I have a GE over the range space saver microwave that was only 18 mos. old when it stopped heating. GE replaced the magnetron for us at no charge but since we did not have a service contract - they charged us $200 to install it. It only cost $375 new installed. Your choice.
Nov 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My space saver microwave will not heat. When I turn it on it sounds like somthing is getting zapped. I cannot use it. Can you tell me what is wrong and how much it would cost to fix. Model #...
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
In this model, it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
While you have the cover off, look for grease buildup or charring on the metal and the stirrer (an antenna or blade-like device).
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
After checking this, please let us know if you still have trouble.
Sep 02, 2008 | GE Microwave Ovens
PEELING COATING IN MY SUNBEAM MICROWAVE OVEN
Yes, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, you can have rust and arcing.
Aug 10, 2008 | Sunbeam Microwave Ovens
Peeling interior
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
You can sand the peeled area, even the rusted area in most cases, clean them squeaky dry, and repaint with high-temperature appliance paint available from places liek Wal-Mart, home improvement centers, and appliance parts stores.
No need to replace the microwave if you can clean and paint it properly.
Oct 16, 2007 | Goldstar MA-1011 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
101 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
