Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave was unplugged,now it says reset.how do we reset?
Fans came on microwave because stovetop burners were left on.after they were turned off,microwave powercorg were disconnected and reconnected.screen says reset and no buttons works.
  • GE Master
  • 9,098 Answers
The membrane keypad has probably been damaged due to the excessive heat.
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
Feel free to contact us directly with your full model number and we can tell you if yours is one of these models, and if so, we'll also give you the part number you need to order and a link to the best priced supplier.
Either way, we can let you know what your options and costs would be and send you other helpful info.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 28, 2010
My microwave oven model 721.85033111 vent fan stays on
You probably have a bad fan thermostat. This thermostat is supposed to turn on the vent fan if the microwave oven gets too hot (caused by cooking too much or having too many burners turned on on the range beneath the microwave oven). It should shut off in about 15 minutes after your turn off the range burners. But if it comes on for no reason, or won't turn off, then You probably have a bad fan thermostat.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 10, 2014 | Kenmore Microwave Ovens
Boiling water caused large "Pop" sound/microwave not working now
I would guess that the boiling water may not have been the cause ...
If you are lucky ... try this first:
Unplug or turn the circuit breaker off (if it is a built in unit). Wait an hour and then repower.
Odds are that will not clear things up ... but it is easy to try. Probably one of the electronic internals broke.
A number of different internal component problems could cause this heating failure in the microwave. It could be the magnetron, the high voltage transformer, the PC board, the diode, and the capacitor. This type of problem will need to be diagnosed and repaired by a service technician. Microwaves are inherently dangerous to service. This type of repair is not something that you want to try to do yourself. Internal capacitors in the microwave can retain a lethal electrical charge even when the microwave is completely unplugged. A microwave radiation leakage test should be performed on the unit using proper testing equipment following any internal component repair.
Jan 25, 2018 | Sharp R-1480 Microwave Oven
In October 2007 I purchased a microwave oven Model # JVM1540DM2WW Serial # RM900254U. In the past week it has become overzealous. After use, instead of the vent fan turning off, it kicks into a REALLY...
This can happen when there is high heat on the stovetop (or the underside of the microwave).
Otherwise, it sounds like the fan control on your control panel is shorting or sticking.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
Aug 10, 2008 | GE Microwave Ovens
Over the Range Microwave Oven
my microwave oven have inside a a metal papel i remove becouse sparks when turn on .this pece of paper is necesari
thanks
alexas
Jun 15, 2008 | Magic Chef MCD1311ST Microwave Oven
Microwave Vent Fan
The only thing I did was to unplugged; turn off all the burners; and let everything cool off. I guess I can't have all the burners on at one time since the microwave is 13" from the burners......and from what I read "microwaves placed over the range" should be at least 30" from the burners...thank you, Rose66
Feb 20, 2008 | GE Microwave Ovens
Jenn-Air JMV8000BAW
I always recommend that folks use the vent / hood fan anytime they're cooking with the stove.
Was it on at the time?
If not, moisture can certainly get into the works and cause problems or damage. If it dries out, it's fine but if not, it could cause damage.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 15, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Exhaust fan
The fan pulls from the range top and either out those vents on top unless there is a vent in your upper cupboard. Then it is vented outside. Hope this helps.
Jan 07, 2008 | Maytag MMV1153A Microwave Oven
Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 14, 2007 | Hotpoint RVM1425 Microwave Oven
Fan coming on unexpectedly
Frannie, this is the way the oven is designed. There is a thermostat in there that is normally open. The thermostat will close at approx. 140 degrees and start the fan. When the temps. cool to about 104 degrees the thermostat will open again and the fan will shut off. Catriver..post back.
Nov 02, 2006 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
76 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
