Question about Brother LS-1717 Mechanical Sewing Machine
The lever that lifts the foot has broken off. Is
The lever that lifts the foot has broken off. Is this repairable and where can I get it done locally in Newark, NJ.
    President:
  • 405 Answers
Follow the link below to find the nearest service center in your area.
http://www.brother-usa.com/service/default.aspx?PGID=3
Posted on May 27, 2010
Pressure foot won't stay up
The presser foot lift lever on many newer janome sewing machines will wear out with use. It can easily be replaced by a sewing machine repair shop or Janome dealer. Or you can look online for a "presser foot lifter" or "presser foot lift lever" making sure to find the correct one for your machine.
Mar 03, 2014 | Janome Sewing Machines
I have a Bernina Activa 145S; the pressure foot is stuck in the down position; how do I lift it?
Machine will require service from an authorized repair technician.
Presser foot mechanicals are broken.
Jan 30, 2014 | Sewing Machines
My singer 522 pressure foot lever has snapped! Can it be replaced?
I suggest taking the machine to a repair shop and ask them if
they can get the part
Nov 28, 2012 | Sewing Machines
The presser foot on my Janome MC9000 will not go up or down
yeah the cam lever is probably broken. Time for a new machine???
Oct 24, 2012 | Sewing Machines
When I raise the lever the presser foot only lifts a bit at the end of the motion and doesn't stay up. Is the foot supposed to remain up after the lever is raised? In the first 40 degrees of motion...
yes, pressure foot lever should stay raised, this sounds like the spring has broken in your machine. if you are comfortable with delving into the machine you could open it up and take a look. alternatively take it to a sewing repair man and get it serviced as well as clean and lube.
Jun 26, 2011 | Kenmore 15218 Mechanical Sewing Machine
I cant figure out how to install the buttonhole foot
Do you just need to attach it to the machine? Or are you having trouble using the foot itself?
It attaches the same way the other feet attach. Remove any foot that may still be attached to the machine. On the buttonhole foot look for the small silver pin that sits on the sliding piece with the small red line marks on it. Lift up your presser foot lever and attach the buttonhole foot's silver pin the same way you would attach any other foot.
As far as using the foot itself place your button on the back sliding piece snuggly till it fits in without falling out, adjust as needed. Pull the bottonhole lever down (it's located on the machine opposite the side of the presser foot lever) so that it rests behind the first lever on the buttonhole foot (small plastic piece raised on the left hand side of the foot that doesn't move). Slide the feed dog switch on the back of your machine so the feed dogs go down. Select your stitch and go. The machine automatically stops when done.
Hope this helps!
Feb 11, 2011 | Brother CS6000i Computerized Sewing...
The foot lever has gotten jamed and now i cant lift it or lower it. can the tension spring be the problem?
The tension has nothing to do with the foot lever.
However, the foot lever has an effect on the tension controller.
When the foot lever is up, the tension is open.
When the foot lever is down, the tension is closed.
If the lever will not release when you lift it as high as possible, you will need to take the machine in for service.
Mar 10, 2010 | Brother CS6000i Computerized Sewing...
Hi I have a Husqvarna 1+ when the pressor foot is in the down position a warning indicator states that the pressor foot is not down and the machine will not function.Any sugestions would be greatly...
The problem could be caused by a couple of issues. It is either with the switch that is located above the foot, that tells the circuit board when the foot is up or down, or with the circuit board itself. It could also be the lever you lift the foot up and down with. Inside the machine that lever has a plastic "fin" on it that touches the switch. It is possible that the lever is broken. Either way, you need to take it in for service.
Dec 29, 2009 | Husqvarna Sewing Machines
Pfaff 6122 Problem
Your machine just needs to be tuned up an the part inside that lower and raises the presser foot needs to be re-lubricated.  Lint, dust, dryness and the machine not being used can cause this issue with most pfaff machines (including my 7570).  A standard tune up from your local PFAFF dealer will remedy this.
Sep 24, 2008 | PfaFF Creative 7570
Brother LS-1717 Mechanical Sewing Machine Logo
85 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
