Question about Asrock K7S8XE+ SIS748 (K7S8XE+RAID) Motherboard
Power can i hook my power to the reset spot instead of the reset?
    Problem Solver:
  • 16 Answers
Plug the plud with (PWR LED)label on the soket with (RESET) on the mother board pannel
AYADI
Posted on Apr 07, 2008
My cd player in my 08 dodge grand caravan won't continue to play the songs after I turn the van off, when I start it up again, the cd starts over from the beginning. ....how do I fix this?
Sounds like a cd player that is an after market.... just hook up the power wire to a battery always live fuse... ie a power connection that isn't interrupted by the ignition. however be sure that the radio doesn't have an anti theft system or as soon as the Power wire is disconnected the radio will have to be reset.... there should be a wiring diagram on the top of the radio or on the bk... look for the wire marked memory and hook the power wire up to the same spot on the fuse box.... the memory wire runs the clock, channel selection and anything else that needs power at all times, even when the ignition is off and the keys are removed so it will be a great spot to hook your power wire to also... just splice into that wire with a splicer but, if your system is a high powered system run an independent wire from the battery through the fire wall so you do not blw a fuse or cause a fire.
Feb 26, 2015 | 2008 Dodge Grand Caravan
04 transit 90 t 350 power loss or surging at 2300 revs +
Does the check engine light come on? You need to check the throttle control rheostat. Instead of a linkage, there is a module that moves when you step on the gas pedal. This can get a bad spot in it and when you drive and go through that spot, it breaks connection and the engine stumbles.
Aug 30, 2013 | Ford Cars & Trucks
Hi my name is Mike and I have a problem with my mini spot. It was working fine for about 2 weeks. Now right when i start, instead of it going through its intitial 10 second or so boot up (with the red led...
hey Mike, I just got 2 brand new minspot rgbws and they worked for 3 days and now tonight the same thing!
they power up and goto a white light and dont move. no display on led panel either...
did you find a fix?
Apr 11, 2011 | Chauvet Minspot Rgbw Min Spot Led Mini...
I have got to the warehouse no. 12 with the grappling hook but cannot see a 'Hot Spot' above the doors to throw the grappling hook through .I can see the broken glass but no 'Hot Spot' The grappling hook...
Game Boomers has a lot of good walkthroughs, especially for these newer games. Check out their website (http://www.gameboomers.com/wtcheats/pcSs/sherlock holmesawakened.htm) to find your hotspot for the grappling hook.
Oct 08, 2009 | Frogwares Sherlock Holmes - The Awakened...
Can't get video to work so bose works with tv sound
We fixed it. We had everything hooked up right, but - stupid us - we didn't turn the sound off on the TV. Once I turned the TV's sound setting to off, I flipped the speaker switch a few times on the Bose remote, then turned up the volume on the Bose and it worked.
Sep 19, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Garmin Street Pilot c340 mount
Try a hard reset using the reset button under the silver trim on the front. Pull off the trim ring by hooking your fingernail under it right below the logo.
If that doesn't work, then take the unit off of the mount for a better look at the contacts. Re-seat the mount onto the unit and see if that helped. If the mount is damaged, consider getting a friction mount instead of the suction cup. For about $40 you'd get new power contacts and a new cord, and the unit would sit on your dash instead of falling off the windshield all the time.
All of this is assuming that the problem occurred suddenly after a fall, and that your battery is still good.
Oct 13, 2008 | Garmin StreetPilot c340 GPS Receiver
How to hook up flat screen monitor??
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Dan
Apr 09, 2008 | ViewSonic VE155b 15" LCD Monitor
Garmin nuvi 310 can not pick up satellites
You may need to reset the system instead of just power on and power off. There should be a small reset button on the back (usually under the antenna) with a triangle on it. Push this button to reset (note if you push and hold, it will erase all of your personal settings (except security settings) and set them to factory defaults.
Nov 15, 2007 | Computers & Internet
Asrock K7S8XE+ SIS748 (K7S8XE+RAID) Motherboard Logo
51 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
