Question about Ford Vehicle Parts & Accessories
HOW TO RESET IMMOBILISER ON FORD MONDEO 2008 1.6 PETROL
seaniepie
  • 250 Answers
SOURCE: how to connect to ford mondeo
You can go two routes for this, wireless or cabled. Wireless is of course good because it has no cables but the sound quality is not that great - ok, but not great. So my suggestion is to go the cabled route which actuall ends up being neater anyway and gives pretty much 1:1 quality. There's plenty of people out there that creat adaptors and cables but check these guys out:
http://www.nexxia.co.uk/iPod_MP3_Adaptors/ford.htm
They range from about £50-100 - and doing a search on eBay for 'Ford iPod Adapter' comes up with similar devices at a similar cost.
All the best
Sean
PiDigital
Posted on Dec 27, 2008
ghost4548
  • 776 Answers
SOURCE: 2008 Hyundai i30. 2.0 litre petrol.
Interesting problem.. since not US spec. Is there a 'remote keyless (fob)' programmed for this vehicle? That's the only way to DE-arm the immobilizer (anti-theft) feature (based on US specs). Unless you have this key fob (keyless entry remote... which must also be programmed for this vehicle), the only other way is wait 5 minutes with the existing key in the ignition, then it should start (US specs). You will still need to have an 'ACTIVE' keyless remote programmed for this vehicle... otherwise, you'll continue to run into this problem.
Posted on Jun 20, 2009
  • 172 Answers
SOURCE: 2001 Ford Mondeo 1.8 petrol. engine went in the
Check ECM (aka) Electronic Control Module (COMPUTER)
Posted on Aug 11, 2009
madadam1965
  • 79 Answers
SOURCE: ford mondeo 2001 has misfire and wont tick over
Any engine will have trouble ticking over if only 3 of the 4 cylinders are working. Check the spark plug for a consistent spark on all cylinders. Check the connections to the fuel injectors on the cylinder head, and check the compression in all cylinders (take spark plugs out and use a compression tester whilst turning the engine over on the key). Low compression in one cylinder may mean head gasket failure, valves out of adjustment (staying open) or bigtime piston or piston-rings failure.
Posted on Sep 07, 2009
Testimonial: "thanks"
Danniboi
  • 1098 Answers
SOURCE: how hard is it to change a clutch on a ford mondeo
If your savvy with cars then its still a bit of work! but you can do it in a day that is about 5/7 hrs all being well. they are quite awkward to get out and re-align
Get a quote from an independent garage i estimate about £170-£220. it's one to avoid if you can.
Regards
Dan
Posted on Feb 01, 2010
Immobiliser bypass mondeo
Sorry it is off to the dealer on this one.
Apr 21, 2016 | 1999 Ford Mondeo
My car wont start, when i turn the Key it indicates "ACTIVE IMMOBILISER"
Sound like the chip is still in the old key fob put your old key back to the way it was then turn the ignition on and see if that works
Apr 11, 2016 | Ford Cars & Trucks
I have a ford mondeo lx battery died so fully charged it and now car will not start at all it saying on the raidio vehicle id how do I get this id thanks
Try using a scanner to reset the ECM for the engine start problem ( immobiliser program corrupted). it may reset the radio but I suspect that you will need a radio code to get it to work.
Jan 24, 2015 | Ford Cars & Trucks
What should I do if immobiliser active light comes on? car won't start
You need the dealer to use a special tester to scan the system and see what is causing this issue.
Jul 13, 2014 | 2008 Ford Mondeo 2.0
Disconnect immobiliser
have to take it to ford usually an ecu problem
Mar 20, 2014 | 1999 Ford Mondeo
Immobiliser activated
Charge the vattery and wait for the immobilizer system to "time out" (may take about 30 minutes). At that time, it will start if you are using the correct key for the vehicle.
Apr 30, 2012 | 2008 Ford Mondeo 2.0
Mondeo tdci turns over but wont start
my ford mondeo zetct turns over but wont fire sparks are fine petrol fine leads are fine new battery new coil what next ecu checked cam sencor checked
Apr 04, 2012 | 2003 Ford Mondeo
Vehicle Parts & Accessories Logo
912 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
