Question about Refrigerators
Overflow on the automatic defroster overflows into the fridge. It is a GE top freezer about 12 years old
  • 619 Answers
There should be a tube going down the back wall with a s trap attached. this black trapped is more than likely clogged. this twists out for easy cleaning.
Posted on May 25, 2010
My 1 year old Danby DBC514BLS tray in back is overflowing on the floor/hardwood. What could be wrong?
Its probably the defrost tray. Most fridges / freezers allow the defrosted water to run into a pan at the back of the unit where it evaporates away. If there is too much water, the tray cant handle it and it overflows.
Nov 20, 2016 | Danby Refrigerators
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Defrost pan overflow
check and see if the door to the ice chute is closing all the way, moisture can get in there and cause excessive frost build up also check the location of your defrost thermostat behind the back panel in the freezer, it should be attached to the top of the evap coil. also check your water system and be sure that there are no leaks under the refer dripping into the pan while the unit is cycling for ice fill or dispenser line.
Sep 19, 2009 | Frigidaire FSC23F7D Side by Side...
GE Profile - fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Ice collecting and water overflow from bottom freezer GE
IF YOU TAKE THE BACK OFF THE INSIDE OF THE FREEZER IT IS LOCATED UNDER THE EVAPORATOR COIL IN THE CENTER, IT IS A PIECE OF ALUMINUM SHAPED TO CATCH THE WATER, MELT THE ICE AND BLOW THE HOLE CLEAR
Aug 11, 2009 | GE Refrigerators
I opened the door on this frig this morning and water poured out like a small river! It filled the frig, and leaked below into the basement. Horrible! I noticed the water streaming out of the built-in...
obviously a filter leak. the water shuts off when the filter is removed. either it wasn't installed properly or it has a bad gasket. as for the fridge getting warm, the water probably collected and froze to the evaporator coils and now resrticts the cold air flow. you need to turn off the fridge, empty it out, leave the freezer door open, and let the coils defrost on their own. or remove the back panel in the freezer and defrost the coils with a hair dryer. you will need to soak up some water, but not nearly as much. once it's defrosted, dry it out, close the doors and turn it on while it's empty. when it's cold enough, replace the food.
Jul 31, 2009 | GE Profile PSC23MGTBB Counter Depth Side...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Candy Futura Fridge Freezer
very simple fault - drain hole is blocked. push something flexible down the hole till it clears and water flows away freely
Aug 28, 2008 | Candy CPCA240FFK Bottom Freezer...
Kelvinator fridge
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Feb 09, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
