Question about Roper RES7646KQ Electric Dryer
Dryer works but does not get hot
I took the control panel and the back off but can't find a fuse to see if its blown.
  • 619 Answers
The heater or the thermal cutt off is bad located on the side of the heater cannister.
Posted on May 25, 2010
  • Roper Master
  • 8,220 Answers
Number 5. Check for blockages or you will keep buying em. You gotta remove that filter chutedryer works but does not get hot - fa531d8.jpgto get it clean, more HERE5a0f26c.jpg
Eurotech washer parts
please follow the next step and fix it. God bless you
Power From The House
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dry to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switc
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replace the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
May 28, 2013 | Washing Machines
I have a duet electric dryer GEW9250 about 5 years old. It stopped working last week. The light inside works but nothing else (no control panel buttons or lights or the digital display). A repairman...
Hello there and thank you for choosing fixya
To tell you the truth i dont think the contrlole panel was the problem the control panel rarly goes out here is a list of the most common things that go out and are a lot more cheep to replace
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 05, 2011 | Whirlpool GEW9250 Electric Dryer
Duet dryer doesn't run. control panel lights up. push on button and all you hear is a click. what do i do?
No dryer function works when the motor cannot run and the common issue is a blown thermal fuse located on the blower housing and wired in series with the motor. There will be no power to the motor when the thermal fuse blows and the motor cannot therefore run. Bypass the thermal fuse and if the motor runs, the thermal use is indeed blown and needs to be replaced. Do not use the dryer with the thermal fuse blown due to fire hazards.
Disconnect power then open the dryer door and remove the lint filter. Remove the screws from the toe panel and remove the panel. Remove the screws securing the lint duct and remove the duct.
The thermal fuse can now be bypassed or replaced if necessary.
Bypass the thermal fuse by disconnecting the wires and taping them together or jumping a wire between them. Once done, plug the dryer in then start it. The thermal fuse is indeed blown and needs to be replaced if the dryer runs. The thermal fuse is part number 3390719. Reassemble the dryer in reverse order of the disassembly steps.
Oct 10, 2010 | Whirlpool Dryers
DRYER STOPPED RUNNING. ALL CONTROLS WORK, BUT WON'T START. HIGH LIMIT SWITCH GONE?
It's either of the thermal fuse on the blower housing or the thermal fuse on the heater enclosure is blown. These thermal fuses are wired in series with the motor and therefore, if any of them is blown will cause the motor not to run and hence the dryer not to work except the controls.
Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
Bypass the thermal fuse on the blower housing by disconnecting the wires and taping them together or connecting a jumper wire between them. Close the door then plug and start the dryer.
The dryer should start and heat up if the blower housing thermal fuse is the culprit. Otherwise, the other thermal fuse on the heater enclosure is blown. Unplug the dryer then bypass the thermal fuse on the heater enclosure in the same way the first is bypassed to confirm it.
Plug the dryer back then restart it. The dryer should start to confirm that the heater enclosure thermal fuse is blown. Replace the thermal fuse (part number 307473) together with the high-limit thermostat (part number 303396).
Unplug the dryer and unbypass the blower housing thermal fuse then plug it back and restart it. If the dryer fails to restart, replace also the blower housing thermal fuse (part number 33001762) together with the cycling thermostat.
Reinstall the front panel in reverse steps of the removal steps to complete the repair.
Aug 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer stopped working as it was drying, was real hot and will not start now. Kenmore 80 series electric
Problem common with blocked vent, need to check house vent...dryer has blown the thermal fuse. found behind the back panel small white fuse(usual two blue wires)....clear the vent and replaced the fuse. run on air dry first to check vent, should feel close to a hair dryer on low.
Jun 10, 2009 | Kenmore Dryers
Kenore Senor Smart 27-inch dryer control panel not working
May 20, 2009 | Kenmore 72062 Gas Dryer
GE electric dryer DBXR463ED1WW not working
Since you have power to your dryer check these two items:
May 17, 2009 | GE DBXR463EBWW Electric Dryer
Electric Kenmore Dryer
possible bad timer but first ck thermal fuse ..if top mount filter remove back fuse is small white object on blower housing ..if door mount filter remove bottom panel remove lint screen remove 2 screws each side holing lint screen housing in place fuse is behind it ..if fuse cks good suspect timer ..
Sep 07, 2008 | Kenmore 62602 Electric Dryer
Fisher & Paykel smart drive topload has lost power. It stopped half way through a cycle. Took the clothes out and tested the power point but it won't turn back on. There was a slight leak at times...
The small leak may have been enough to blow the fuse under the control panel.
I had the same trouble with my F&P smartdrive 701.
Take off the control panel by undoing 2 screws and you will see the blue plastic control box in the tray on the machine (not the other blue circuit board box under the push buttons). Open the control box (1 screw and click open) to see an ordinary fuse. Hopefully this is blown and the new fuse, a clean up of leaking water, and some plumber's thread tape on the hose connector to stop future leaks, and you should be up and running.
Good luck.
If it works - give a small donation to your favourite charity!
DIY Eddie.
Aug 28, 2008 | Fisher and Paykel Washing Machines
Dryer stays hot hours after using it
The heater has failed and/or is shorting to the case. Remove the rear panel. The heater is on the right side, attached to the heater housing with two screws.
Jun 25, 2008 | Kenmore 62802 Electric Dryer
Roper RES7646KQ Electric Dryer Logo
62 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
