Question about Husqvarna Viking 1
Bobbin threading it sews about one stitch and then pulls tight as if in a knot
  • 135 Answers
You don't have the top tension threaded seated bween the disc
Posted on Aug 12, 2010
The bobbin thread is showing on the top stitching
Your tension is too tight. It is pulling the thread from the bobbin to the top of the sewing. You need to set it so that the knot is in the middle of your sewing.
Aug 04, 2015 | Sewing Machines
I have a singer 500/550 .I'm trying too sew a straight stitch ,but I'm having trouble with the tension. What's the best setting? And i can't sew with needle in the middle position. Why
500/550? wow, that an old one. have you check your timing? or the bevel gears?
what type of problems are you having with the sewing. is the thread knotting up on the back side of the fabric? is the thread just breaking? or is it just missing stitches? does the needle hit the bobbin case?
I have a 600 series and I found that if i put the tension around 2 or 3 it sews the best.
too tight the tread breaks, too lose the thread knots up on the back.
I had to change out the bevel gears and have the machine re-time to stop the miss-stitching.
also may want to check your bobbin tension.
May 29, 2015 | Singer Sewing Machines
I can't sew with any thread below T-40 without the thread knotting every 10-20 stitches on the bobbin side.
sounds like the upper might be too tight and possibly the bobbin is too loose .
Mar 08, 2015 | Sewing Machines
I have juki 1541industrial machine . It started sewing upside down . Instead of nice stiching on top show side it on bottom. Any ideas
This is caused by the tension between the bobbin and needle threads being out of balance. If the knots between the stitches are on the bottom side, then you need to tighten your needle thread tension a little at a time until the knot is in middle of fabric. The reverse of this is if the knots are on the top, then either your bobbin tension is too loose or your needle thread tension is too tight. If this occurs, then loosen your needle thread a little at a time to see if knot goes down in middle of fabric. If it does not, then you need to increase the tension on your bobbin thread. This done by taking bobbin case out and tighten the small screw located in the middle of the spring on the side of the case. You only need a slight, steady pull on the bobbin thread - the more you put on the bobbin, the more you are going to have to put on the needle thread.
Feb 13, 2015 | Juki Sewing Machines
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
Keeps skipping stitches and knots thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Bobbin thread keeps breaking
Could well be that the bobbin tension is too tight, you should only just be able to pull the bottom thread through with slight resistence, if it is too tight slacken the screw on the bobbin case anti clockwise about a quarter of a turn at a time and test until you get it right,
Mar 05, 2010 | Janome 659 Mechanical Sewing Machine
Bernina Aurora 440 knotting below my fabric and into bobbin area.
Are you sure you have the bobbin the right way round in the holder....when you look at the bobbin and tug the thread, the bobbin should move clockwise.
Pull out the foot pedal and use bsr2 with the start/stop button.
Bring bobbin thread to top of work before starting to sew. This may help knotting problem
May 25, 2009 | Bernina Activa 140
Zigzag stitch pulling tight, looks wrong
Try adusting the bobbin thread instead of the top. Always make sure to insert the bobbin so the thread is pulling in a clock wise direction. Both threads top and bobbin should have about the same resitance when pulled.
May 08, 2009 | Euro-Pro Shark 60 - 384
Sudden knotting under fabric
I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
Jul 01, 2007 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
