hi the fuses are located under the drivers side (jdm version) on the side of panel under a black plastic cover, just look for the blown one as the locations are all written in japenese
These are prone to power spikes...and for that reason have a fuse located on the power supply board...known as fast blow fuses...which are glass and easy to see if they have blown..sometimes all you need to do is replace the fuse on the rear of the unit if you can locate a fuse cap...just unscrew and replace....Always unplug televisions and audio equipment and routers during power outages and thunderstorms as a preventative to blowing psu panels on electrical devices connection to your house mains for this reason .
It could be the actual headlight switch. Or if you have trailer wiring make sure that it is ok. No tail lights is usually either the switch or trailer wiring problem.
There is a special *amp fuse inside on the back bottom of the machine. It is next to the pump. There is a gray cover over the power filter where the fuse is ;located. You can see the power wires going into the cover. There is also a special .35maT fuse that is on the back of the power board.
hello sterling home the fuse is located in the lower right hand corner of the main power board that is located just off center of the tv to the right a bit.. then there is another 2 fuses on a board located to the right of that and another fuse on the board all the way on the left side of the tv ..hope this helps ..oh and by the way if you end up having a bad power supply i do have 1 for that model ..
