Question about Garden
My Hayter Harrier 41 lawnmower starts but keeps cutting out? what could the problem be?
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
Where is the oil drain on hayter harrier 41
quite likely it is under the desk where the blade is .
Jul 12, 2015 | Garden
Which way does the bolt turn to remove the blade from a hayter harrier 41 mower
You can figure this out by checking the direction that the blade turns when it is operating and the bolt will tighten the opposite way because if it turned the same way it would loosen off when the motor was turning the blade, so almost univerdsally it will loosen clockwise and tighten counterclockwise.
Sep 19, 2014 | Garden
Hayter lawnmower manual
whats wrong with it i might be able to help
Aug 25, 2014 | Garden
Hayter problems
if it has the green trigger you pull up to move height adjuster it is common that they snap or the roll pin comes out. simply take out the 2 cross head scews from the handle and remove handle, the trigger will then be free to remove, there will be a compression spring on the trigger dont loose it!!!! the triggers are quite cheap and can be bought online at ebay etc, just slide trigger back into handle bot forgetting to reit spring. refit handle to chassis and refit the 2 screws
May 22, 2014 | Garden
Hayter 41 fuel starvation
Take your fuel cap apart. Or try start with cap off, if it starts it the cap.
May 04, 2012 | Briggs & Stratton Briggs Stratton...
The distance from the coil to magneto,should it be touching or is there a feeler gage setting on Hayter harrier lawn mower 41
hi this should have a gaged gap to be honest i cant remember what it is, but is definitely should not be touching...hope that helps sorta..
Jun 05, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
THE STARTER CABLE ON MY HAYTER 41 PETROL LAWNMOWER HAS JUST BROKEN. HOW DO I PLEASE REPLACE IT, OR DO I NEED TO TAKE TO A HAYTER SERVICE ENGINEER? BRIAN TAYLOR
hi,if you can remove starter housing and think you are up to replaceing cord then you can get replacement cord from any repair centre but may be as well to take starter along and they should do it for a nominal fee ,which is cheaper than if you damage it doing it yourself,it doesnt have to be a hayter dealer since the engine is a briggs and stratton ,hope this helps
Apr 07, 2009 | Garden
Garden Logo
1,424 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
