Question about Frigidaire ATF6000ES Front Load Washer
My frigidaire front washer says EFO at the end of a cycle. What is this, and I still have suds in my clothes.
  • 15,935 Answers
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 16, 2010
Im getting the efo code on normal cycle stops at 38 on a 46 cyclewhats wrong im guessing out of level
It can mean one of two things. You did not use an HE ( High energy detergent) or you used to much so there are too many suds in the washer. It can also mean that if you are using warm water, the hot water is not coming in, so you would need to make sure the hoses are connected correctly, the hot water is turned all the way on and that the little filter at the end of the hose (washer end) is clean.
Feb 10, 2011 | Frigidaire Washing Machines
EFO code cameup.
Its not EFO its EF0 .Theremust be some thing blocking the pump .For example socks,underwear etc. The water was not cycling through properly. Cleaned it out and everything works fine.Use proper detergent mentioned for your model because even SUD formation can cause this error.
Jun 18, 2010 | Frigidaire Affinity ATF7000E Front Load...
While washing the letters EFO flash. what does this mean?
If your washer displays EFO it means that you are not using HE detergent. You must have used too much detergent on a particular load.You have to use He detergents to fix this issue or else not using it will ruin your washer because regular soap makes too much suds.
Thank you!
May 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
Flashes efo on display halfway through cycle
May 20, 2010 | Frigidaire Affinity ATF7000E Front Load...
Affinity ATF7000E Front Load Washer: where do i find what efo means on my affinity wash...
May 16, 2010 | Frigidaire Affinity ATF7000E Front Load...
What does it mean when washer says efo on screen
Thank you!
May 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Code efo is in window while clothes are washing
Oct 12, 2009 | Frigidaire ATF6000ES Front Load Washer
EFO error code
Jul 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
My front loader washer displays the letters "EFO", what does it mean
Thanks
Jul 01, 2009 | Frigidaire Affinity ATF6000F Front Load...
EFO, E10 error Message
Feb 09, 2009 | Frigidaire GLTF2940E Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
64 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
