Question about Maxtor OneTouch 4 Mini 120GB External USB 2.0 Hard Drive
I have a Maxtor One Touch 4 Mini 120GB External USB 2.0 Hard Drive, I've previously used it multiple times in the past, importing AND exporting data. For some reason though after using it on one computer to back up data and later copying it over to the newly reformated computer, now whenever I plug it into the USB port of a computer it won't detect the external hard drive. The light on the external hard drive lights up and I can hear it running but the computers in my house refuse to detect it. It has the last remaining copy of many family photos and has many other important files on it that I'd much prefer not to lose. Could this be some sort of unlikely software problem within the hard drive or is it a hardware problem making it permanently unaccessable? I don't mind having to throw it out but I'd really want to recover those family photos and etc. P.S. The only 2 variables that I can think of that MAY possibly be slightly outside the normal use parameters is: 1. Data was backed up onto the external hard drive through a computer that was infected with several virus', but I believe I had the computer in safe mode at the time, but it's possible it wasn't. and 2. I am not using the original USB chord that was with the external hard drive, I'm using one with the same ports but the original was thicker and split off into 2 usb output ports as a option of hooking it up to two computers at once. (I don't think this would make a difference but the small things sometimes matter.)
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
Try testing it in another computer. if you have the same problem. then there might be an issue with the drive.
to recover your data. unplug external drive from the computer and open the external hard drive case. remove the hard drive inside. with you computer off and disconnected from the wall open the case to your computer. look and see how the hard drive inside is connected in your computer and add the external the same way. you might need a cable to connect it. you can simply disconnect the cdrom and plug the hard drive instead. make sure the external hard drive is not touching any electronics inside the pc. now you can turn on the computer. give the computer a minute to detect the new drive and assign a drive letter. navigate to my computer and select the newly added hard drive. copy and paste all the data you want to save. after everything has been backed up format the external drive to clear any bugs that may be causing it to be recognised in its case.
when finished remove the hard drive, plug in the cdrom, close the case, plug back into the wall, and return external drive to its case.
Posted on Feb 28, 2017
2 Suggested Answers
  • 32 Answers
SOURCE: Maxtor OneTouch 4 Mini 160GB External USB 2.0 Hard Drive
First let's try going into disk management and see if we can see your maxtor drive. Plug it in then right click on my computer. From there click on manage and then select disk management.
This will give you a list of your drives. If the Maxtor is there, what is the status? Can you right click on it and activate it? If you don't see the drive then let's try the next step.
If you go into your device manager and select your Universal Serial Bus Controllers. Right click on your on the USB Universal Host controller and select uninstall. This will uninstall the USB Driver, but don't worry, oncfe you have uninstalled all the controllers, you will reboot the machine and then Windows will come back and reinstall all the usb controllers. Once this is complete then plug the drive back in and see if you still get the same issue. If none of that works....
Download a linux bootcd called SLAX http://www.slax.org/get_slax.php?download=iso
use nero to burn the iso to a cd and boot from it. Once you're in there, you SHOULD be able to recognize or at least see the drive. If you can then format the ****** from Slax. Once that's complete, you should be able to see it as a raw drive in Windows and then you can format it using explorer or a command prompt.
Let me know how this goes.
Posted on May 05, 2009
Our MAXTOR Onetouch 4 mini is not recognized by computer. Can your software recover the data?
could be several issues to cause this fault, make sure your usb port is usb 2.0, replace the usb cable, take the unit apart and look for loose conections, try the drive in another caddy, or try another drive in the maxtor caddy. You will probably be able to remove the drive from the caddy and connect it into your computer if you have a tower and the correct connections.
May 02, 2011 | Maxtor OneTouch 4 Mini 120GB External USB...
How to repair the usb port on maxtor one touch 120GB external drive
You cant repair USB its to small to resoldure unless you are PRO, you could take it apart and connect it to a computer or another laptop and pull out the data here is a guide. http://www.gearhack.com/Forums/DisplayComments.php?file=Computer/Reusing_the_Maxtor_OneTouch_III_Mini_Edition_Portable_Hard_Drive
Mar 06, 2011 | Maxtor OneTouch III Mini Edition 120GB...
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
Portable hard disk fell its not being recognised
The drive has failed, Contact the manufacturer for a replacement and if u need the data back, contact a data recovery company :)
Apr 14, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
How do i find a usb adapter for my maxtor one touch 4 mini 120gb it broke?
You can buy a USB to USB mini cable at almost any store with PC accessories, even Walmart. Buy a high quality one since the drive is powered from the USB 2.0 port. Good Luck
Jul 23, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
Maxtor 4 mini usb 250 gb not recognized
Data Recovery Lab can recover data from faulty hard drives. They specialise in hard drive recovery, USB RAID data Recovery and laptop data recovery. For more information you can call 0207 516 1077 or visit www.datarecoverylab.co.uk.
  • No-data No Fee Data Recovery Service Guarantee
  • FREE data recovery analysis
  • Fast turnaround
Data Recovery Lab also provide FREE data recovery advice and consultation for all business and private customers in the UK.
Feb 18, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Code 10. The device cannot start
Go to, Start > Settings > Control Panel > Administrative Tools > Computer Management > Disk Management. See if the drive starts under Disk Management.
I sounds like the drive enclosure is shot. You may need just a case. Click this link: http://cgi.ebay.com/USB-2-0-2-5-EXTERNAL-HARD-DRIVE-ENCLOSURE-CASE-NEW_W0QQitemZ120099119775QQcmdZViewItem?hash=item120099119775
Or you can get the whole unit and swap out the drives so you won't lose your data.
http://cgi.ebay.com/NEW-MAXTOR-ONETOUCH-4-MINI-120GB-HARD-DRIVE-USB_W0QQitemZ160267138312QQcmdZViewItem?hash=item160267138312&_trkparms=72%3A552%7C39%3A1%7C66%3A2%7C65%3A12&_trksid=p3286.c0.m14.l1318
Aug 02, 2008 | Maxtor OneTouch III Mini Edition 120GB...
USB CONNECT ONE FOR POWER+DATA ? AND THE OTHER POWER ONLY?
It sounds like your USB ports just aren't putting out enough power for this device. Did the drive come with an external power supply? If so, does it work when you use the external power supply?
Jan 12, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor OneTouch 4 Mini 120GB External USB 2.0 Hard Drive Logo
80 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
