Question about Hitachi 53UDX10B 53" Rear Projection Television
The image has yellow and blue lines around them.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
It sounds like a convergence problem, see attached photos.
It can be a do it yourself repair if you have some skills--it involves getting at and replacing the two STK-392-150 CONVERGENCE chips this set uses for this function.
Total parts cost for a do it yourself repair should be under 30 dollars and I can tell you what you will need and where to get the parts at the best price.
If not a do it yourself person shop around your area for someone who has done this repair before and do not accept "It has to go to the shop" as I have done hundreds of these in the customer's home and the repair takes about a hour or less to do.
Let me know if you have questions or need advice--I am here to help.
SD TECH
Posted on May 25, 2010
Images have some ghosting, but convergence lines seem to be OK. For example, white images have a yellow shadow to the right of image. Any suggestion?
Some easy steps to determine where and what your problem is:
1) In customer menu select convergence and then advanced (done with the Mitsubishi remote) look to see if grid of lines straight and if "yellow" is seen there.
2) Look to see if it happens when DVD etc played; If only on component from a cable or sat box but not on tuner or DVD inputs it is not the set.
3) Go to a channel that is in black and white and in customer menu turn COLOR all the way down: is problem still there or not?
If problem is not convergence and is present on all inputs it will be a problem with one of the three CRT boards; they plug onto bottom of each of the the three picture tubes this set uses; yellow suggests a problem with the blue one______loss of blue may give you a yellow smear around things/ red and green equal yellow.
You do not need to take the set apart for this.
Let me know what you find, the more you rule out the easier it is to know where the problem is.
SD TECH
Jan 10, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Color problem with Toshiba
tv is on it's 'hospice' end of life routine..unless you want to gut it completely, and replace all the electronics..
Apr 19, 2008 | Televison & Video
Color dots on tv
u have a bad optical block , this part is very costly , but call sony costumer service , u tv maybe onder recall because of this problem
Apr 15, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
White areas in the image are yellow and the black are blue-green
you have a few issues. first is the yellow in white. the light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you may have to replace the whole optical engine. as for the flashing horizontal lines, the power supply isn't cooling down and the caps are drying out, causing fluctuations in voltage. so, replace the power supply.
Jul 04, 2009 | Toshiba TLP S30 Multimedia Projector
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
Double imaging
exact same problem.. please email me if you find out the fix..
frmeek@yahoo.com
Feb 18, 2009 | ViewSonic PJ860 Multimedia Projector
Color is mostly yellow and blue with double images
you have lost the convergence IC`s in your set, this really isn`t a diy repair unless you are very proficient in un-soldering and re-soldering components, once replaced there will be an alignment procedure as well that will require the service manual also, if you have more questions feel free to ask away, video-tek
Feb 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Wires from the wall are 2(orange/white), 2(blue/white) 2(white/orange and 2(white/blue) my phone outlet which is wired has 1(black), 1(blue), 1(yellow) and 1(black. How are my wall wires to be attached...
Take a look at this image:
0d5b58e.jpg Notice that the Line 1 will typically present on pins 3&4 and Line 2 on 2&5. I would think in your case Black/Blue is Line 1 (3&4) and Yellow/Black is Line 2 (2&5).
If you have a 1 line phone and only have 1 line active, then typically blue and blue/white can be connected to the Blue and Black of your Jack. If this doesn't work, switch with the Yellow and Black.
Please let me know if you have further questions. Good Luck!
Aug 11, 2008 | Lands Phones
Convergence Problem
sounds like 1 of the convergence chips are gone theres 2 of them and better off replacing both as the other would just go a month down the line there might also be a resister or 2 gone, the price for that kind of job is around 150 +vat.
hope this helps
Feb 10, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Yellow/blue outlined image while viewing
reset the settings to factory default. the resolution and phase is off. also make sure the projector is not too close to the screen.
Nov 29, 2007 | InFocus LP 735 Multimedia Projector
Hitachi 53UDX10B 53" Rear Projection Television Logo
97 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
