Question about Xerox DocuColor 12 Printer
Doc 12 fuser oil leaking
I have a Doc 12 and I replaced the fuser oil and now it is leaking everywhere and I don't know why or how to fix it. Please help
  • nathanbryant Apr 07, 2008
    Thanks for your comments. Do you know a reliable vendor here in Mississauga on?
    President:
  • 2,072 Answers
It needs to have the fuser taken apart and rebuilt.
There are wicks and wiper blades that wear out.
Then they do you get excessive oil on the paper and
pretty much everywhere.
If your doing it yourself I can provide you a good and reliable vendor.
Posted on Apr 07, 2008
  • Rick Kasper Apr 07, 2008
    If your looking for parts, Call here.
    https://www.partsdrop.com/store/
    Ask for Britt, tell him Rick had you call.
    But if your looking for service. you can go to Xerox.com and look for a service dealer or company in your area. They all should be listed on that site.
    the kit is what you will most likely need. Not very cheap though.
How do you replace oil seal on 1992 Toyota pickup
You likely need a valve cover gasket, to confirm this is the leak clean the engine with a pressure washer and then drive it, if the cover is the leak tighten down the retaining bolts first, the gasket gets flattened and leaks, this works one time in most cases on this engine.
Sep 03, 2012 | Geo Prizm Cars & Trucks
Oil leak
How long is a piece of string ? without a good look under the bonnet i couldnt say but make sure the engine breather is clean and not clogged as this would cause a build up of back pressure which will cause the oil top leak from everywhere possible
Feb 08, 2012 | 1988 Chrysler LeBaron
1998 pontiac firebird V6 3800...NO oil pressure and noisey valves. Have replaced oil pump and oil sending unit,claned oil pan,pick up tube and all parts....I dont know what else to do. Could someone please...
For oil pump,oil pump pressure,oil warning light,oil low,oil ewplacing and other car engine oil problems,the help links are provided below.Click the link to go through the procedure :-----Oil light came on and the car died?http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html--------How to replace Oil filler cap or breather cap?http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html---------Oil pouring out from left front of engine?http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html------Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html--------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html--------Oil change details?http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html---------Low oil pressure light?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html ----------
Car Turns OFF due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
Feb 05, 2012 | 1998 Pontiac Firebird
Oil leak from head gasket can it be replaced
For leaking head gasket it has to be replaced.For head gasket leaking and other troubleshooting,there are help links provided.Its suggested to click the link below and go through the troubleshooting procedure to confirm the issue :-----Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
-----------Water in engine oil? http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
-----------How to replace head gasket on car? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-head-gasket-on-1994.html-------------How to know what is faulty Cylinder head or Head gasket? http://schematicsdiagram.blogspot.com/2011/12/how-to-know-what-is-faulty-cylinder.html
-------------- Can I just replace Head Gasket on 1991 Buick Century? http://schematicsdiagram.blogspot.com/2011/12/can-i-just-replace-head-gasket-on-1991.html Location of Head Gasket ?
http://schematicsdiagram.blogspot.com/2011/12/location-of-head-gasket-on-1994-grand.html
HOW TO REPLACE A HEAD GASKET
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-head-gasket.html
How to replace Exhaust Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-exhaust-manifold-on.html
How to replace Intake Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-intake-manifold-on-acura.html
How to replace Cylinder Head ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cylinder-head-on-acura.html
Is it Easy to replace head gasket?
http://schematicsdiagram.blogspot.com/2011/12/is-it-easy-to-replace-head-gasket-on.html
Should I only replace head gaskets or complete head gasket assembly? http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
-----------FOR oil leak issue check the following help links:---Common Causes of Car Oil Leaks? http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html --------Troubleshoot Car Oil leak? http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
---------Car oil leak?
Car oil leaks from valve cover gasket? http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
---------This will help.Thanks.
Jan 30, 2012 | 2006 Scion tC
-----------How to replace head gasket on car?http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-head-gasket-on-1994.html-------------How to know what is faulty Cylinder head or Head gasket?http://schematicsdiagram.blogspot.com/2011/12/how-to-know-what-is-faulty-cylinder.html
-------------- Can I just replace Head Gasket on 1991 Buick Century?http://schematicsdiagram.blogspot.com/2011/12/can-i-just-replace-head-gasket-on-1991.html Location of Head Gasket ?
Should I only replace head gaskets or complete head gasket assembly?http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
-----------FOR oil leak issue check the following help links:---Common Causes of Car Oil Leaks? http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html --------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
Car oil leaks from valve cover gasket?http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil leak use too much oil
open ur fuser oil unit
clean it with cloths
all pipes and oil blade
check for leakage
and replce oil blade
Nov 06, 2009 | Xerox DocuColor 12 Printer
Blue,black thick line and print is not so glossy
I work on the doc 12 every day. first look at fuser web once out look at the metal roller in side the web slot make sure there is no build up..the large gray fuser rolls should be covered with oil coatting so make sure the oil is pumping.
Jun 30, 2009 | Xerox DocuColor 12 Printer
Error 10186 docucolor 12
10-186 is a fuser problem.Check for jammed paper in fuser or low fuser oil.Might have bad fuser lamp or fuser thermal fuse.
Apr 23, 2008 | Xerox DocuColor 12 Color Copier
Docucolor 12 spills fuser oil
Pretty much all you can do is rebuild the fuser, either the meterins blade or wick are work out.
Mar 19, 2008 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Printer Logo
176 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
