Question about Dynex Multimedia Keyboard
When I plug in the usb for Dynex Keyboard, it doesn't work.
Well I bought this Dynex Keyboard like 2-3 months ago and now it doesn't work anymore. Like I have Dynex Mouse too, but the mouse works fine, but when I plug in the Keyboard, it makes the mouse stop working too. I don't know what to do i mean this used to happen like last week and to fix it I just restarted computer and then the keyboard started working. But now when i plug in the keyboard it makes my mouse stop working too. I have a Toshiba laptop and please help me fix this. I tried to update the drivers too but it didn't work. I really need the keyboard.
    President:
  • 2,653 Answers
Sounds like you've got a bad keyboard.
You should contact Dynex direct for in-warranty replacement.
You can reach them here.
  • When I plug in the usb for Dynex Keyboard, it does - usflagicon.gif1-800-305-2204
Posted on May 25, 2010
osborne382
  • 306 Answers
SOURCE: cannot connect wireless keyboard and mouse
check to make sure the drivers in the device manager are working properly. Once its connected to the PC they sould at least be recognised by the PC. If they are and still nothing....shut down pc, remove all power supplies, push the power button on the PC then reconnect power supply and start up....should fix the problem......let me know
Posted on Nov 12, 2007
yooperbud
  • 8637 Answers
SOURCE: Trust keyboard and wireless mouse
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try typing to see if it is working. If not try pressing the button on the receiver and then on the keyboard. Try typing, should work okay.
Hope this helps. Bud
Posted on Jan 19, 2009
fixyathing
  • 341 Answers
SOURCE: Keyboard only works if mouse isnt working and vice versa
does it come with a synchronization or reset button? try it...usually press the one on the receiver first then with the mouse and keyboard.
Posted on Aug 10, 2009
sawdust46694
  • 398 Answers
SOURCE: Logitech CE0560 keyboard and mouse; first keyboard
First put new batterys in the mouse and key board. if you don't have a tester use a flashlight. pen light. push the remote pickup. light will blinknext push key board button and the mouse next. then try it and see if it works.
sometimes do the mouse first, Then the key board
lonewolf1996
  • 142 Answers
SOURCE: wireless mouse not working
You can use them both at the same time.Make sure the batteries are good.There should be a sync button on the bottom of the mouse.you need to check the wireless receiver to see if there is a button on there as well.If there is you need to push the button on there first,then the mouse.
The easiest way to fix a sticking key is to remove it from the keyboard and clean it out.Then replace the key.
Posted on Sep 02, 2009
My microphone stopped working about 30 minutes ago after i tripped over the cord which unplugged it from the usb port. I can't figure out why it wont recognize input anymore.
1) Have you tried a new device in the USB port?
2) If so, and it still does not work, the port must be damaged.
3) If not, replace the mic.
Hope this helps!
Nov 02, 2013 | Dynex Audio Players & Recorders
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
Number,one,three,five seven and zero not working and back space aswell
Is your keyboard connected via USB (a flat rectangular connector), PS/2 (A round connector, often it is purple), or AT connector (a round connector that is roughly twice the size as the PS/2 port for your mouse)? More than likely, it's connected via USB. Especially if it was bought within the last five or six years. If it is a USB keyboard, try plugging it into a different USB port and see if that helps. If that doesn't help then most likely the cord on your keyboard is damaged (kind of like when you have a pair of headphones that will only sound on one ear unless you jiggle the wire). If it's not the USB port (or you have a PS/2 keyboard) I would recommend you buy a new one. You can get one for as cheap as $10.
USB Connector: crasher35_6.jpg
PS/2 Connector: crasher35_7.jpg
AT Connector: crasher35_8.jpg
May 29, 2011 | Computers & Internet
Need to use a Dell L100 keyboard on my old Win 98 SE computer (custom built). No USB on computer so tried an adaptor. Doesn't work at all. Do I need to download a driver? Where can I find this to...
Those USB to PS2 adaptors are hit and miss. They shouldn't need a driver. What you could do is buy a USB PCI controller, which will allow you to connect USB devices to your legacy system. Best buy sells one for $20 and it works for 98 SE - Windows 7.
http://www.bestbuy.com/site/Dynex%26%23153%3B+-+2-Port+USB+2.0+PCI+Card/7833785.p?id=1142298626004&skuId=7833785&st=usb%20pci&cp=1&lp=2
Regards, Chris
May 18, 2011 | Dell 0Y3740 Keyboard
Dynex Multimedia Keyboard not working
Check and install drivers for your multimedia keyboard which is came along with the Keyboard. Also check whether the USB drivers has been installed properly and check the status of the same.
Revert back for more assistance. Also give your valuabale feedback/rating on the same.
Feb 07, 2010 | Dynex Multimedia Keyboard
IOGear 2-port KVM Switch (Keyboard Issue)
I have had the same problem off and on since I bought my Iogear 2-port kvm switch over a year ago. I have a DYNEX wired, multimedia, usb keyboard and a Dynex wired usb mouse. The operating system on my desktop is Windows XP, SP3 and on my laptop it's Windows XP professional.
Yesterday, my keyboard "died" on me about 8 times and each time it requires unplugging the keyboard usb cable from the switch and my laptop, rebooting, then plugging the usbs back in. Really, really frustrating and annoying. I'm not a techno guru, but I got to thinking that maybe the keyboard driver might be the culprit. I decided to go to Control Panel, clicked on Keyboard, then Hardware/Properties/Driver/Update Driver. I clicked on "update driver" and let it find one automatically. It took what seemed like a long time for it to find the driver but it found one. The device name changed to KeyMaestro P2360, the driver updated, and I noticed 2 additional files were added to the System 32 directory.
It's only been a day but so far so good. My keyboard hasn't failed yet since the keyboard driver update. I don't know if this is the solution for you or not, but it seems to be the one for me. I'll know for sure if I can through a few days without it failing again.
Dec 04, 2007 | IOGear GCS632U 2-port KVM Switch
Dynex Multimedia Keyboard Logo
798 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
