Question about QuarkXPress 6.5
Default print style has vanished, been replaced with "Export print style" and only sees process cyan plate, halftoning option junk
  • 379 Answers
PRINTING IS DULL
A little short on information, but if your machine is Brother colour laser - reset the print output to VIVID. The default setting is more of a halftone print. If your machine is an inkjet, then I think dull is normal for a Brother. I would never recommend one for printing photograghs or high resolution images.
Dec 02, 2014 | Brother Office Equipment & Supplies
How to reset sylvania synet7wid
If original andfairly new: While Booting Up.
Dell XP = Ctrl+F11
Dell Vista = F8
EEEPC = Esc
Compaq = F11
HP Desktop Vista = F11
Emachine = F10
Acer = Alt+F10
Every manufacture has or uses different Function Key combinations to do a Factory Default Recovery. Also if it didn't come withdisks there is normally a program in the menus to create your own set of recovery CDs. This must be done before you ever putanything on the recovery partition d:, if you used d: for anything you need toremove what you put there or the recovery will not function.(As soon as yourcomputer is turning on press the F10 key and it will take you to the systemrecovery screen, click on the advanced option and click Destructive recoveryand click next. WARNING: before doing this backup anything on your computer youwant to keep pictures, videos, music etc. This will delete everything that didnot come pre-loaded from the factory, so if you have pictures of Aunt Fae'sClass reunion you should probably back those up if you want to keep them.)
Sep 29, 2011 | Sylvania G-Netbook
Want to reset my samsung 150 to factory settings
Dell XP = Ctrl+F11
Dell Vista = F8
EEEPC = Esc
Compaq = F11
Emachine = F10
Acer = Alt+F10
Sep 28, 2011 | Samsung N150 (36725723009) Netbook
Forgot my password
Resetting password & user name on Windows:b>*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
Sep 24, 2011 | Sylvania G-Netbook
Cannot print in a cyan color after having the cyan cartridge refilled. How do I cure this problem?
Often these newer style of ink cartridges utilize a chip which makes it that much harder to find a good compatible ink cartridge to work.
You can follow this link for a run down of replacement ink cartridges, genuine brand HP or Compatibles and give a replacement cartridge a try to see if it fixes it:
http://fusers.com/index.php?type=extended&make=12&type=714&model=32399&dispatch%5Bproducts.search%5D=Search
Jan 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
The Bizhub C351 is printing the colours wrong the red and yellow comes out pink and a yellow smudge line prints on the top of every page how do i fix it?
print off halftone for each colour
utility/counter,metercount,stop.0.0.stop.0.1test mode.halftone.cmyk start.this will print off each colur, the "failed" one will be easy to see
Jun 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Docucolor 12 printing nothing from glass
The only fuses it could be are the 24v fuses going to the ROS. In general it would "normally" be the ROS and Halftone pwb or the Vsel pwb. Both of these might not be sitting right/loose ribbon cables etc, depending if you have been working in that area.
The other option is a defective cleaner clutch for the IBT. This "normally" leaves with just the black left on the print however. You will have to watch the machine and see if there is actually an image being produced on the drum. If not, the ROS (ROS and halftone pwb must always be replaced together)
Jan 19, 2009 | Xerox DocuColor 12 Color Copier
Creating Halftone Dots
in photoshop you can use a filter to create dots you can actually see on screen, cant remember exactly where it is, but it is in the filter menu. Also to print halftone dots you hit print and go into the print preview dialogue box, click on the screens button. another dialogue opens uncheck use printer defaults. This allows you to specify what frequency angle and dot shape you would like for each color you are printing. By default CMYk are specified for the layers visual space, other spot colors can be added using channels and will show up within this dialogue along with CMYK options. however, you can only have one channel selected at a time to get it to print correctly.
Similarly in illustrator, the options are in the print dialogue. detailed info about each of these processes can be found in the help menu of the respective programs. you may want to check out this link. Many of these questions are answered in this forum all the time. http://screenprinters.net/articles.php
Sep 13, 2008 | Adobe Photoshop 7.0 for PC
Epson Stylus 1520
Two possible causes
1. printer software option are incorrect
Check: Print quality and set it to economy
Highspeed On
Choose Black ink
No halftoning
2. Change your default spool directory and other settings
Jan 16, 2008 | Epson Stylus 1520 InkJet Color Printer
Computers & Internet Logo
65 people viewed this question
Top Quark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Laxman Bisht
Laxman Bisht
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
